Old Dec 09, 2011, 10:52 PM
larryross is offline
Find More Posts by larryross
Registered FFF Addict
larryross's Avatar
Grand Junction, Colorado
Joined Dec 2007
Jay
It looks to like you have a good plan there. I think you will have enough plane there to do 3D which that design does very well. I think I would consider reducing the size of the elevator and ailerons some not a lot, but some. I didn't do it on the elevator on my 250% version and wish that I had, but I have the wing plan drawn up with proportionally smaller ailerons. My 250% will be way over powered with 4 1200watt motors. Using smaller batteries I will only run them at 400 to 600 watts. I plan on doing a 25 foot B-17 if and when I finish this one. I will use the same motors for that one. It will be a big challenge to make it light and some what scale.
Good luck with your giant cargo. I think it is a good idea to mod that tail gear and use it as a front gear. If you want to look at what I am doing with my 250% cargo, here is the link:
http://www.rcgroups.com/forums/showthread.php?t=1408158
Later
Originally Posted by bombardierJay View Post
well then i will do a 130% scale TWINS 75"( WS) with thoose motors and 30 amp esc's .
might come out to 3 lbs auw ? with the enclosed wing
I want to make this out of FFF and some 1/2" Dow Board . will that work ?
Yes it will be a full enclosed wing made from FFF and 1/2" Dow board for ribs .
fuselage mostly FFF and all Bulk heads 1/2" Dow Board .
all tail surfaces will be 1/2" dow board .
main gear . i might use 4 of them for the main gear .http://www.hobbyking.com/hobbyking/s...dproduct=9835/
Nose gear gona fab it up . and if possiable i will put a servo on it since i will not be buying a v tail mixer .
http://www.hobbyking.com/hobbyking/s...idproduct=3755
larryross is offline Find More Posts by larryross
Old Dec 10, 2011, 01:39 AM
bombardierJay is offline
Find More Posts by bombardierJay
Joined Oct 2011
Originally Posted by larryross View Post
Jay
Later
LOOKIN GOOD LARRY !!!!
little update on the 130 % build . i will use the following :
Two 20C 3000Mah 3S LiPo's
Two HK Red Brick 30 Amp ESC's
Two D3128-1550 Brushless Bell Motor's ( 250W ) Each
Two GWS HD9050 3 blade prop's (1) C.R.
Six Servo's (4) HXT900's (control surfaces) (2) 12G Metal Gear Servos ( nose gear and cargo door servo's )
bombardierJay is offline Find More Posts by bombardierJay
Old Dec 13, 2011, 09:49 PM
Joined Oct 2011
ok went to Lowe's and bought a FFF Bunch of new stock Dow 1/8 Underlayment .
and one sheet of 1/2 " 4' X 8' blue Dow board . Think this will work good . i will use the 1/2" foam for the load bearing structures . and basic layer it with the FFF .
with this being a 75" WS Twins . i need to have a removable wing how should i do this ? i don't like using ruberbands on something this big ?
Old Dec 13, 2011, 10:10 PM
Joined Oct 2011
if i up scale the full page plans to $130 % how is that gona effect the SLot & Tabs system ?
its gona mostly still bee 6 mm FFF . with some 1/2 Dow for the bulkheads and wing ribs . ?
Old Dec 13, 2011, 10:32 PM
Wilfor is offline
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Tabs will be fine you'll just have to resize the tabs . not a big deal , i do it all the time when using dollar store foam .
Wilfor is offline Find More Posts by Wilfor
Old Dec 13, 2011, 11:23 PM
Joined Oct 2011
how do i resize the tabs ?
Old Dec 14, 2011, 12:57 AM
RogueTitan is offline
Find More Posts by RogueTitan
Foam Av8r
RogueTitan's Avatar
In Teh Garage (Rossville, GA. USA)
Joined Sep 2008
you lay the tabs out the size you need on the foam.
mark the center of the tab then split the diffrence of the thickness of the material you are using.
RogueTitan is offline Find More Posts by RogueTitan
Old Dec 14, 2011, 05:37 AM
Wilfor is offline
RC Adddict
Wilfor's Avatar
Joined Jan 2010
LOL i miss typed . tabs will be fine SLOTS will have to be resized . As RT said just lay them out once the plans are printed , pretty easy . With the Tabs , leaving them on the long side is helpful as once glued together you can cut them off flush for a nice clean finish .
Old Dec 16, 2011, 09:01 PM
Joined Oct 2011
Jay
Later
How much should i reduce the elevator and aileron sizes on this 130% build ?
Old Dec 19, 2011, 04:40 AM
Joined Oct 2011
130% build update !!!!!
I build the wing tonight . came out to 74" WS . How big to make ailerons ? and Elevator ? any idea's ?
So far the wing is done besides cutting and hinging the aileron's .
Wing Weight is 1 Pound 1 Ounce . or 480 Grams .
here are some pics . please need some dimensions on the control surfaces ?
Old Dec 19, 2011, 06:22 AM
CrocEnd is offline
Find More Posts by CrocEnd
CrocEnd's Avatar
Darwin
Joined Aug 2002
Guys please whats the good glue to use on depron
Cheer's
CrocEnd is offline Find More Posts by CrocEnd
Old Dec 19, 2011, 10:23 AM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Gorilla Fast dry, Sumo although IT turns yellow later,
Foam-Tac, poxy, Hotmelt ( but not too hot - seriously )
birdofplay is offline Find More Posts by birdofplay
Old Dec 19, 2011, 07:29 PM
mndbndr3d is offline
Find More Posts by mndbndr3d
Lakewood, Ca.
Joined Sep 2001
Glue
I just finished framing my 2nd cargo foamy (dollar tree foam) and I've used mostly hot glue to put it all together. I also used the new Gorilla glue II which dries 2x faster than the original. complete dry to the touch within 30 minutes. just make sure you moist the both surface when you apply glue this will make it activate faster. I used it on critical sections such as the wings...
mndbndr3d is offline Find More Posts by mndbndr3d
Old Dec 19, 2011, 07:44 PM
lennyboy is offline
Find More Posts by lennyboy
lennyboy's Avatar
Joined Oct 2009
Up-date on larry ross
Well I Skyped with Larry today and,,,
he looks great but still going thru Kimo...
His spirits are up ,,,
But Both his computers are hurting..
We managed to talk using his laptop..
Not Larrys style..
But he will return soon ..
He's doing some building ,but taking it easy for now...
For some of you new guys ..........Larry was our own PDF pro..
And thanks to him for alot of plans,,,
He could make a set of PDF of a fly,,
if you could send him some good photo's
The twins cargo, seadart, Skycart, and polaris among many other sites on RC Group..
So Larry will be building and fixin his confussers,,, as we speak..
He's a fighter for sure..
We'll be so glad to see him back on here..
Later,
Lenny
lennyboy is offline Find More Posts by lennyboy
Old Dec 20, 2011, 10:16 AM
urpu36 is offline
Find More Posts by urpu36
Joined Aug 2010
Not Larrys style..
Later,
Lenny
Thank You Lenny
urpu36 is offline Find More Posts by urpu36
Multiplex Cargo Plane Riko Electric Plane Talk 7 Aug 19, 2009 09:21 AM
List your Cargo Plane mods.+pics. speedo Foamies (Kits) 24 Oct 19, 2005 03:04 PM
Newbie multi purpose plane Jay Spence Slope 19 Sep 15, 2004 10:36 PM
Multi-purpose Charger hyperbot Foamies (Kits) 5 Apr 18, 2002 04:47 PM
Multiplex Cargo Plane, How is it? info. needed. speedo Foamies (Kits) 8 Oct 09, 2001 10:37 PM
