Old Sep 06, 2010, 09:34 PM
pitviper51 is offline
Find More Posts by pitviper51
Foamy Season is here! MX2#1
pitviper51's Avatar
Elizabethtown, Kentucky
Joined Nov 2005
thanks, oh I will be getting video from ground and onboard of the first drop. we might test the rig with equal load that cant break. the thing I am trying to get working is a way for the droge to pull from the pallet to get out of the plane smooth, then releasing the load to float down level. So far my tests withthe chutes at this weight load it falls fast enough to pull all three chutes open, and then floats nice. stay tuned.
mike
pitviper51 is offline Find More Posts by pitviper51
Old Sep 07, 2010, 10:50 AM
mastrsn is offline
Find More Posts by mastrsn
Procrashtinating Builder
mastrsn's Avatar
about 12" from my computer in Jacksonville Fl.
Joined May 2004
Originally Posted by foam and tape View Post
I havent yet tried covering the bottom of the undercambered airfoil but i'd imagine it would perform just as vrpilot stated. It should help with flutter as i've done this on my fpv plane.
Not only am I going to cover the bottomwing, but I'm Lengthening the wing span and going with 4 motors!
I've got to get with wmcneal and see if we can lengthen the fuselage too....
( I have too much time on my hands......)
mastrsn is offline Find More Posts by mastrsn
Old Sep 13, 2010, 06:22 PM
Gbee is online now
Find More Posts by Gbee
Gbee's Avatar
United States, CT, Suffield
I need some advice with my Twins' ramp/door. I had 50 ping-pong balls loaded during our club Fun Fly with members names on them. I was going to drop them from altitude over the target (random, closest wins), but many came out during the climb to altitude. I did a do-over with same partial loss of balls during the climb...(embarrassing for me and my Twins, but I dropped the majority right on.) The balls are shifting rearward and opening the door. I've had this issue at times with other cargo as well.
I was thinking I need some kind of servo actuated latch on a Y harness with the door servo. I mounted my door servo high in the fuselage, near the receiver (with a 6 in. .032 pushrod that pulls the door closed). I though of running a push/pull cable off the other side of the door servo, but it's a long way to the rear of the door. Any thoughts of securing the door?? What do you all do?
Gbee is online now Find More Posts by Gbee
Old Sep 14, 2010, 08:36 AM
wmcneal is offline
Find More Posts by wmcneal
AMA 125691
wmcneal's Avatar
Jacksonville Florida
Joined Jul 2002
Gbee,
I have the same problem with my big cargo plane. Not so much with the lightweight paratroopers, but more with the larger RC skydivers. The weight slides back when climbing and pushes the door open. I have learned to climb at a more shallow angle. That is the only solution I have worked out so far. I will post something if I come up with a better solution.
wmcneal is offline Find More Posts by wmcneal
Old Sep 14, 2010, 09:11 AM
F-111 John is offline
Find More Posts by F-111 John
R.I.P, Aardvark.
F-111 John's Avatar
Holt, MI
Joined Jan 2009
Is the door flexing? If so, how about a bit of carbon fiber?
F-111 John is offline Find More Posts by F-111 John
Old Sep 14, 2010, 10:02 AM
jiberk is offline
Find More Posts by jiberk
Vacuum Tubes Forever BCT2/BCR3
MN AZ
Joined Oct 2006
75% version
The twin is about a month old. Similar issues as the 100% version, wing tip flutter on over speed and flexing cargo door. Built with $Tree foam board. Flies GREAT and I do love dropping things!!! Vtail mixer work great, will have to change ESC on 100%. Larry, GREAT tiled plans!
Setup
2204-14T 19grm motors
10 Amp turnigy esc's
3S 1300 20C
GWS vtail mixer.
5grm HXT servos
JohnB
jiberk is offline Find More Posts by jiberk
Old Sep 14, 2010, 02:30 PM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
You could use another servo on a long lead - put the servo arm on the outside, so it latches the door closed and swings out the way when you want to open it.
Or, change it from a cargo door to a bomb-bay hatch - hinge it at the back and run the pushrod wire through a couple of short pieces of tube at the front, so it works like a door bolt and the servo pulls the wire to unlatch the hatch. Then it'll flap backwards in the breeze, which might look untidy but it won't get in the way during landing.
Or, if you want to get fancy, modify the servo for continous rotation, glue/screw a drum to the output, and use some string to winch the door closed. If you attach the string at the back of the ramp, the servo will have loads of leverage and the ramp won't open accidentally. Opening and closing the door will take longer (probably a few seconds) but you could call that a 'scale feature' ;-)
RobinBennett is offline Find More Posts by RobinBennett
Old Sep 14, 2010, 06:11 PM
Rockin G is offline
Find More Posts by Rockin G
If It Aint Broke,I'll Break It
Rockin G's Avatar
United States, TX, Lockhart
Joined Dec 2008
Please excuse this ignorant question. I have never built anything from just plans. I notice there are a bunch of plans on post#1. If I was to take them to any of my office stores for full size plans, which ones do I take them and is there anything special I need to tell them?
I would plan on building the full size. I was thinking about having flashsolutions cut it for me with his phlat, but I think I at least want to TRY to do it myself. Also, what size sheets will I need to order, and how many....Thanks in advance.
Rockin G is offline Find More Posts by Rockin G
Old Sep 14, 2010, 07:09 PM
Dave Barrow is online now
Find More Posts by Dave Barrow
Dave Barrow's Avatar
United States, KY, Covington
Joined Feb 2003
RobinBennett, I like your idea of using another servo to latch the door. This might be a good servo for that purpose. http://www.hobbyking.com/hobbycity/s....2kg_/_0.08sec It's small, light, good rating, inexpensive and best of all, in stock. I'm getting ready to order some things, think I'll add one to the order.
Dave Barrow is online now Find More Posts by Dave Barrow
Old Sep 14, 2010, 11:01 PM
FutureVRPilot is offline
Find More Posts by FutureVRPilot
FutureVRPilot's Avatar
Sonoma
Joined Jul 2009
I have just received my Twin-Star wing set and it looks like it will work nice. I may increase the trailing edge to fit the width of the fuse with a slight taper to the wing tip. A must is to sand the little mode release finish on the wing, looks better. For the prop clearance i will need to insert some wood about 1.5" min. thickness where the wing joints, for fuse clearance using a 9.6 3 blade prop. I measured the wing and it comes to 57" after the insert. I believe the plans call out for 57" too The tail will be cut to a round early aircraft version and the outer tail fins will look like the B-25 tail. Also ordered the round cowlings that are used for the T.S. sea plane version from park flyer plastics. Super Tiger .10 elect. motors that produce about 300 Watts ea. This will be an FPV plane. with Eagle Tree HUD... airspeed / altimeter and then and upgrade next spring to a UHF long range / antenna tracking system.
FutureVRPilot is offline Find More Posts by FutureVRPilot
Old Sep 15, 2010, 05:43 AM
MikeRobey42 is offline
Find More Posts by MikeRobey42
Perth, Western Australia
Joined Jan 2010
I had that problem and I thought the door was flexing but then I realised it was the pushrod between the servo and the door that was bending. I added a bracket/guide for the pushrod about halfway along and that improved things a lot.
MikeRobey42 is offline Find More Posts by MikeRobey42
Old Sep 15, 2010, 10:05 PM
pitviper51's Avatar
Joined Nov 2005
today my friends cargo plane made its maiden flight, first one was way tail heavy and took some work. after trimming the wing and adding wieght its flying better. we decided that it needs wing stuts, so stay tuned for updates.
Old Sep 15, 2010, 10:49 PM
pitviper51's Avatar
Joined Nov 2005
wing core
has anyone used this company to make wings for the cargoplane?
http://flyingfoam.com/launch.html
seems the lodgical thing to do..
I would when I build one.
mike
Old Sep 15, 2010, 10:59 PM
Joined Feb 2003
Take the full sheet plans, they have a scale on them.
Old Sep 16, 2010, 04:16 AM
beemer-san is offline
Find More Posts by beemer-san
belgium-europa
Joined Nov 2009
this is mine...from belgium
hi guys.....
may i proudly present to you my twincargo plane.....
first, i like to thanks "foam an tape", also larry ross who were very helpfull.
the whole plane is changed a little bit, so a made a kind of canopy up on the cockpit...later my flycam2 will be attached there.
also a little different landing gear, who can be replaced by skids for landing in the snow.
some leds are built in the wing and the nose, so i can fly when it is almost dark.
the main wing itselfs is a closed type: much more rigid and lots of space to integrate other things like brake flaps.....
in meanwhile, i'm building a second wing now with ailerons and brake flaps separately, but integrated in the wing, not extended as in the movie.
the roof of the cockpit is also removable, better acces for connecting servo's, lipo and other stuff while the wing is already attached.
i love this plane, Francine too!
this should be the link to my movie on youtube ( i don't know how to show him in this message)
twin cargo plane.wmv (5 min 39 sec)
this little movie was made near by bastogne in belgium, a nice place to fly around.
greetings to you all!
ps: sorry for my "english"-i did the best i can
beemer-san is offline Find More Posts by beemer-san
Multiplex Cargo Plane Riko Electric Plane Talk 7 Aug 19, 2009 09:21 AM
List your Cargo Plane mods.+pics. speedo Foamies (Kits) 24 Oct 19, 2005 03:04 PM
Newbie multi purpose plane Jay Spence Slope 19 Sep 15, 2004 10:36 PM
Multi-purpose Charger hyperbot Foamies (Kits) 5 Apr 18, 2002 04:47 PM
Multiplex Cargo Plane, How is it? info. needed. speedo Foamies (Kits) 8 Oct 09, 2001 10:37 PM
