Old Jan 15, 2010, 11:50 AM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
I have had the Skycharger for one week. I used it successfully for about 7 or 8 times. Once to charge a battery, the other times I used the Storage function to get batteries into the storage mode. Last night the LCD started to malfunction while in Storage mode. All the characters get lit up randomly. If I push the Increase button to go to another screen, it blanks out.
When I unplug and then re-plug it back in, it would start out okay and then if I pushed Increase button to look at the balance voltages the LCD characters would get all messed up and then the screen would go blank.
Now when I power it up, the LCD screen and characters are all messed up. The charger has become unusable.
I am going to contact Hobbypartz.com and hopefully they will do the right thing and replace this charger.
Kmot is offline Find More Posts by Kmot
Old Jan 15, 2010, 12:10 PM
skinnydoc is offline
Find More Posts by skinnydoc
United States, CA, Berkeley
Joined Feb 2007
sent in for credit
After having persistent issues with my replacement unit, I'm opting to send mine back for store credit, which I will promptlly use I'm sure, blue lipos probably.
I think this charger still needs work.
BTW, I'm parallel charging 4 6s 5000 packs with my iCharger 106b, it is incredible! I really dont need another charger at this point anymore. The iChargers (progressiverc.com) are a bit pricey (in comparison), but pretty amazing. Check out the threads on RCGroups, especially the one on parallel charging.
This is not to take away from the typically good products that hobbypartz sells.
Ben
skinnydoc is offline Find More Posts by skinnydoc
Old Jan 15, 2010, 01:08 PM
Kmot is offline
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Well, they have given me an RMA numbers to send it back for exchange. I certainly hope all the Skychargers are not FUBAR because it really seems like a nice charger. I would just like it to last more than a few uses, lol.
Something interesting about this charger I have found out and I am not sure about what the deal is:
If you download the software, it is software from IMAX. SO, it would seem the Skycharger is a Imax battery charger product. However, if you go to the SkyRC website, that makes the Imax chargers, they have instituted an "anti-fraud" method to help identify fakes. As is commonly known I think, China has a really bad reputation for copying things and pumping out look-a-like fake products. Anyway, at SkyRC thay show that a special hologram sticker is applied to the bottom of genuine SkyRC manufactured products and they claim if you have a so called SkyRC charger that does not have this hologram sticker, then it is a fake!
My charger does not have the hologram sticker.
http://www.skyrc.us/antifake/indexen.php
http://www.skyrc.us/indexhome.htm?#/.../Charger/b6ap/
Old Jan 15, 2010, 01:22 PM
Joined Feb 2007
new 200W charger on hobbypartz....
you may want to exchange for
http://www.hobbypartz.com/h610-hotpower-charger.html
its more like the iCharger. It has a much higher 200W rating. Its great running 10A.
I cant speak to the "fake" issue.
Ben
Old Mar 29, 2010, 11:59 AM
iceman96 is offline
Find More Posts by iceman96
Joined Mar 2010
B6ac problem
How do i get warranty on my b6ac.
It's brand new and doesn't work in lipo fast charge mode
iceman96 is offline Find More Posts by iceman96
Old Mar 29, 2010, 12:23 PM
Turner2 is offline
Find More Posts by Turner2
Tallahassee, FL
Joined Sep 2009
What does it do when you try it in that mode?
Turner2 is offline Find More Posts by Turner2
Old Apr 15, 2010, 07:52 PM
plaurence is offline
Find More Posts by plaurence
Plaurence
Joined Jul 2009
I was trying to decide between the B6AC or the FMX cellpro multi4.
Just made up my mind. I buy an FMA multi4
plaurence is offline Find More Posts by plaurence
Old Apr 21, 2010, 09:22 PM
iflybell is offline
Find More Posts by iflybell
Coon Rapids, MN
Joined Dec 2007
Sky Charger B6AC
I also had the same problems as before mentioned. The first unit I purchased failed to charge any battery. I would plug in a battery and hit charge only to have the unit restart. I don't know what angered me more, the fact that I had to pay return shipping on a defective product, the attitude and belittling treatment from the people at Hobbypartz or the wait for the replacement to arrive. The replacement seems to work fine however I cannot get the software to work in Windows 7. Has any one else run into this?
iflybell is offline Find More Posts by iflybell
Old May 21, 2010, 06:54 PM
RudderRider is offline
Find More Posts by RudderRider
Joined May 2010
I have the SkyCharger B6AC great product...but. After using the charger with an external
DC supply when I went back to AC the Charger will no longer turn on in that mode. I
measured the output from the switching power supply at 12 v. dc so I suspect the problem
is a firmware thing. At any rate I can not find out who manufactures the charger. If anyone
has an idea on this please let me know.
RudderRider is offline Find More Posts by RudderRider
Old Jun 27, 2010, 11:35 AM
MacPharlan is offline
Find More Posts by MacPharlan
Joined Jun 2010
Figuring the upper limit of the charge current
Hi, total newb here in charging. I have a SkyCharger B6AC and charging a 1100 mah NIMH battery.
It suggests in 'auto mode' to set the "current limit" to make sure it does not go over.
How do I figure out the current limit? Is that 1.1 amps with a 1100 mah batter?
MacPharlan is offline Find More Posts by MacPharlan
Old Jul 16, 2010, 04:36 AM
jrotor is offline
Find More Posts by jrotor
jrotor's Avatar
San Jose, CA
Joined Sep 2002
Hi all
I need help with the software.
During charge, the softeare says "Disconnected" and the graph is keep refreshing but no data is shown. However, charging is done fine to the battery.
Is there anything I should try in the software ?
jrotor is offline Find More Posts by jrotor
Old Dec 22, 2010, 11:59 PM
aajerezp is offline
Find More Posts by aajerezp
Guatemala
Joined Jul 2010
Hi all
I just bought a SkyCharger B6AC+ and when trying to charge, balance or discharge my battery a StarMAx 11.1v 2200mAh StarMax na, I get the message connection break. What will be the subject of this post, and check that the battery is properly connected.
Thanks for your reply.
aajerezp is offline Find More Posts by aajerezp
Old May 13, 2011, 05:45 AM
iamahuman is offline
Find More Posts by iamahuman
iamahuman's Avatar
India, KA, Bengaluru
Joined May 2010
I've ordered this charger recently.After reading about these problems,I'm slightly worried.Does anyone know if the problems have been solved?
PS:sorry for reviving this thread but thought that this would be the best place to ask my question.
iamahuman is offline Find More Posts by iamahuman
Old May 13, 2011, 08:05 AM
Turner2 is offline
Tallahassee, FL
Joined Sep 2009
I haven't had any problems with mine.
Old May 13, 2011, 11:36 AM
iamahuman's Avatar
Joined May 2010
well,that is a relief.Any more guys?
Discussion Smart 5-in-1 Balance Charger/Discharger for 1-6 Cell Lipo/Lilo/LiFe + 1-15 Cell Nimh hobbypartz HobbyPartz.com 34 Aug 13, 2009 07:54 PM
New Product Hot!!! 1 to 6-Cell Smart LiPo Charger w/ USB PC SOFTWARE!!! xheli XHeli 0 Jan 24, 2009 09:55 AM
GWS Tiger Moth 400 with Multipod 5 in 1 Buzzard21 Aerial Photography 0 Oct 25, 2005 09:19 AM
Century 5 in 1 simon109 Micro Helis 1 Feb 22, 2005 09:11 PM
WTD: A 4/5 in 1 board from micro heli matty_g Aircraft - Electric - Helis (FS/W) 0 Feb 22, 2005 11:44 AM
