Go Back   RC Groups > Vendors > HobbyPartz.com
Old Oct 10, 2009, 06:06 PM   #1
Sky Charger B6AC DUAL POWER 5-in-1 LiPo Charger w/ USB PC Charging & Monitoring
With an extremely low price, this is also one of the highest quality r/c battery charger you will ever find on the internet which also has USB PC monitor software to perfectly charge all your batteries. Dual power and multi-functional, the Sky Charger B6AC+ can charge 1-6 LiPo, A123 Li-Fe, NiMH and NiCD, Li-ion and PB batteries! The Sky Charger B6AC+ also features microprocessor controlled, high-power and high-performance circuit, maximum safety with delta-peak sensitivity, capacity limit, processing time limit, input power monitor, temperature limit and also monitoring the voltage of individual cell. Best of all, this charger also comes with everything such as power cord, charging clips/adaptors and everything you need to get started! Great for RC beginners!!!
Complete Charging Kit for under $60 at HobbyPartz.com
Special Features
Optimized operating software B6AC+ features the so-called AUTO function that set the feeding current during the process of charging or discharging. Especially for Lithium batteries, it can prevent the overcharging which may lead to an explosion due to the user's fault. It can disconnect the circuit automatically and alarm once detecting any malfunction. All the programs of this product were controlled through two way linkage and communication, to achieve the maximum safety and minimize the trouble. All the settings can be configured by users!
Internal independent lithium battery balancer
B6AC+ employs an individual-cell-voltage balancer. It isn t necessary to connect an external balancer for balance charging.
Balancing individual cells battery discharging
During the process of discharging, B6AC+ can monitor and balance each cell of the battery individually. Error message will be indicated and the process will be ended automatically if the voltage of any single one cell is abnormal.
Adaptable to various type of lithium battery
B6AC+ is adaptable to various types of Lithium batteries, such as Li-ion, LiPo and the new LiFe series of batteries.
Fast and storage mode of lithium battery
Purposes to charge Lithium battery varies, �fast� charge reduce the duration of charging whereas �store� state can control the final voltage of your battery, so as to store for a long time and protect useful time of the battery.
Maximum safety
Delta-peak sensitivity: The automatic charge termination program based on the principle of the Delta-peak voltage detection. When the battery's voltage exceeds the threshold, the process will be terminated automatically.
Automatic charging current limit
You can set up the upper limit of the charging current when charging your NiCd or NiMH battery; it is useful for the NiMH battery of low impedance and capacity in the 'AUTO' charging mode.
Capacity limit
The charging capacity is always calculated as the charging current multiplied by time. If the charging capacity exceeds the limit, the process will be terminated automatically when you set the maximum value.
Temperature threshold*
The battery�s internal chemical reaction will cause the temperature of the battery to rise. If the temperature limit is reached, the process will be terminated.
*This function is available by connecting optional temperature probe, which is not included in our package.
Processing time limit:
You can also limit the maximum process time to avoid any possible defect.
Input power monitoring
To protect the car battery used as DC input power from being damaged, its voltage keeps being monitored. If it drops below the lower limit, the process will be ended automatically.
Data store/load
The maximum five batteries�data can be stored for users�convenience. You can keep the data pertaining to program setting of the battery of continuous charging or discharging. Users can call out these data at any time without any special program setting.
Cyclic charging/discharging
1 to 5 cyclic and continuous process of charge>discharge or discharge>charge is operable for battery refreshing and Balancing to stimulate the battery�s activity.
Visit HobbyPartz.com for the latest hot deals on rc components!
hobbypartz is offline Find More Posts by hobbypartz   Reply With Quote
Old Oct 12, 2009, 09:32 PM   #2
Live to Fly, Fly to Live
KillerGX's Avatar
What is the difference between this Charger and the Thunder AC6, other than it being 5 dollars more expensive.... they look exactly identical.
KillerGX is offline Find More Posts by KillerGX   Reply With Quote
Old Oct 14, 2009, 06:03 PM   #3
The SkyCharger's software is more advance, basically having more features. The factory engineers behind this charger is very pro and it also comes with a temperature sensor device that the AC6 doesnt include.
Old Oct 14, 2009, 07:03 PM   #4
KillerGX's Avatar
I just noticed that the Balance plugs are embedded also..... thats a huge plus!
will Hobbyparts.com be offering the optional balance tabs aswell? I dont see them on the site?
If it has more safety features plus an added internal fan then this unit is well worth the extra 5 dollars..... Im sold!
Old Oct 16, 2009, 10:58 AM   #5
Does this charger have a built in fan. Jim
jimgrunt is offline Find More Posts by jimgrunt   Reply With Quote
Old Oct 20, 2009, 04:26 PM   #6
Yes, it comes with a built-in cooling fan
Old Oct 20, 2009, 07:09 PM   #7
Thank you for your reply. I have one on the way and will let everyone know what I think about its use and features. Jim
Old Oct 22, 2009, 08:38 PM   #8
My Sky Charger came today and I tried the storeage charge mode. How do I turn off the safty time out feature.I have 12 5000 5 cell that I would like to store but the timer times out just before they are at 19v. thanks for your help. Jim
Old Oct 24, 2009, 01:56 PM   #9
I now have both the thunder ac6 and the sky charger 6ac, they have the exact same alluminum case, different rubber feet, different buttons- thunder is easier to click, same display but the thunder is brighter, I like the built in balance ports on the sky charger. I didn't notice the sky charger having a internal fan though, I'm going to take it apart and do a youtube thing on the comparison of the two. All in all, these charger are great for what you are paying for them, not the highest charge rates, both are 5amp max, but it does the trick on every battery I have tried to charge yet.
bang22nd is offline Find More Posts by bang22nd   Reply With Quote
Old Oct 24, 2009, 07:23 PM   #10
Ok I made a short little video on the insides of the two chargers and sorry hobbypartz but there is no internal fan, I don't think it needs one anyway, it never gets hot for me, and I charge a 2 cell lipo at 5amps that has a 5000mah capacity. I can't speak for any lipo's over 2 cells. But I love these things for the money. Also I put a plug in for www.hobbypartz.com in at the end of my video they ship things out quick and I haven't had any issues with there products.
Inside the Thunder ac6 and the Skycharger (2 min 5 sec)
Old Oct 26, 2009, 01:28 PM   #11
USB interface
My charger does not allow me to enable the USB interface. How do I use the USB interface with a computer?
jackreb is offline Find More Posts by jackreb   Reply With Quote
Old Oct 26, 2009, 01:38 PM   #12
mode1's Avatar
join
mode1 is offline Find More Posts by mode1   Reply With Quote
Old Nov 03, 2009, 09:09 AM   #13
Bronze Member
mjbennett9's Avatar
Send a message via Yahoo to mjbennett9
Pictures at bottom of your site say temp probe is included, but above there's red text sayin "your" version does not include a temp probe?
mjbennett9 is offline Find More Posts by mjbennett9   Reply With Quote
Old Nov 03, 2009, 09:12 AM   #14
Bronze Member
mjbennett9's Avatar
Do you know what max watts are on the sky? I know you say 5A, but at 6S 4900mah, that's over 110Watts. Most cheap chargers max at 50Watts. If this is 100W or more like the turnigy accucel-8, I'd grab it in a heartbeat! :-)
Old Nov 03, 2009, 04:00 PM   #15
I know the sky doesn't say but I'll assume its the same as the thunder, and thats 50w. I have seen some of the cheep chargers as high as 200w at the hobby king but you have to deal with china shipping. I can't speak for 6s so maybe someone else can help here.
Discussion Smart 5-in-1 Balance Charger/Discharger for 1-6 Cell Lipo/Lilo/LiFe + 1-15 Cell Nimh hobbypartz HobbyPartz.com 34 Aug 13, 2009 08:54 PM
New Product Hot!!! 1 to 6-Cell Smart LiPo Charger w/ USB PC SOFTWARE!!! xheli XHeli 0 Jan 24, 2009 10:55 AM
GWS Tiger Moth 400 with Multipod 5 in 1 Buzzard21 Aerial Photography 0 Oct 25, 2005 10:19 AM
Century 5 in 1 simon109 Micro Helis 1 Feb 22, 2005 10:11 PM
WTD: A 4/5 in 1 board from micro heli matty_g Aircraft - Electric - Helis (FS/W) 0 Feb 22, 2005 12:44 PM
Bored? Want to fight?
Join the RCGroups clan!
