Go Back   RC Groups > Aircraft - General > Simulators
Old Oct 10, 2009, 04:59 PM   #1
Help needed for Reflex XTR
Hey all. I'm new here and I need help for the Reflex XTR simulator. I installed it today on my Vista computer. Everything went well until I tried plugging in the Controller. When the program first started up, it said "No REFLEX-interface could be detected! Please check your hardware installation." Is this a problem with my controller? Or is it just that the program does not work on Vista?
P.S. I am using a controller with a P/S 2 connector which is then connected to a USB connector (No p/s 2 connector for this laptop =/)
Kubus908 is offline Find More Posts by Kubus908   Reply With Quote
Old Oct 10, 2009, 05:36 PM   #2
Ken Myers's Avatar
I just looked and my Reflex XTR dongle is USB, so I'm not sure what your problem is or why you'd need something different than the dongle provided with the program.
Ken Myers is offline Find More Posts by Ken Myers   Reply With Quote
Old Oct 10, 2009, 06:05 PM   #3
Mine only came with a P/S 2 dongle. I had to buy a converter USB cable to plug in because my laptop is very old and does not have the P/S 2 port. So the program definitely works on Vista?
Old Oct 10, 2009, 06:41 PM   #4
Did you purchase a retail copy of XTR or is this a copy of the CD which you are hoping to get to work with a 3rd party interface ?
As far as I know, all XTR interfaces are USB - there is no PS/2. They contain the PIC micro that encodes the signals from the transmitter in an encrypted mode that the software detects and understands. Thus if you use any other interface the software recognizes that a non genuine XTR interface is connected and displays the message you got. This is because the hardware protects the application against pirating.
Re-reading you post, do you mean your old laptop doesn't have a USB port and you are using a converter to plug the USB interface into an adapter which connects to the PS/2 port... if so then it's time to upgrade your laptop as I doubt that it would have the power and graphics to run XTR if it is indeed that old. USB ports have been around on laptops for over 10 years now, so for a machine not to have any USB ports it must be a bit of a dinosaur... But then you state your running Vista, and this confuses me, and Vista would need a fairly modern machine to run on, and certainly would struggle on a 10 year old computer that had no USB ports.....
Malc C is offline Find More Posts by Malc C   Reply With Quote
Old Oct 10, 2009, 09:07 PM   #5
No no. You understood me wrong. My computer has a USB port. It doesn't have a ps2 port. And the controller and the CD I got came with an RC helicopter I bought. The Cable that came with the controller has a PS2 connector so I had to buy a converter to plug it into my computer.
Anyway, I will try to use a Windows XP desktop controller. I wanted to make sure that it wasn't the program itself that wasn't allowing me to use the controller. Thanks for the help though.
Old Oct 11, 2009, 05:57 AM   #6
Right, the controller you have is not an XTR interface. The controller you have will not work with XTR for the reasons explained. I also doubt that the connector, whilst resembling a PS/2 connector isn't actually meant to connect to a keyboard connector.
Best advice, if you want XTR is to purchase a genuine copy from the classified section of most forums, or via e-bay. Alternatively, purchase a USB interface that emulates a standard windows joystick and try that with FMS, or Clearview.
Old Oct 11, 2009, 11:36 AM   #7
K. Thanks for clearing this up.
Old Oct 12, 2009, 05:21 PM   #8
Hey Guys (Gals?)
I bought my Reflex s/w last year and now just went to download some more aircraft only to find that they no longer support the product . I could not find any trace of the hundreds of model downloads, so I'm stuck with what I have.
They are planning to release a new product in the future.
This is a very nasty thing to do to existing customers. I, for one would never buy another product from them.
Nicholas
njacobs is offline Find More Posts by njacobs   Reply With Quote
Old Oct 12, 2009, 05:31 PM   #9
RC-Sim used to be the place for download for most sims - http://www.rc-sim.de/cms/index.php/en
Old Oct 30, 2009, 02:04 PM   #10
I too have a Reflex XTR, bought from a reputable model shop. Ran fine, then upgraded my comp to vista, now Reflex doesn't run. Contacted company and got the rudest reply imaginable! They want nothing to do with customers once they have your money. Avoid!
But if anyone knows how to get this to run on Vista...
snapperjon is offline Find More Posts by snapperjon   Reply With Quote
Old Oct 31, 2009, 05:31 AM   #11
Charlie06's Avatar
I too have a Reflex XTR, bought from a reputable model shop. Ran fine, then upgraded my comp to vista, now Reflex doesn't run. But if anyone knows how to get this to run on Vista...
Install it on a computer with XP then burn the Reflex folder off on a disc, then put the disc in the Vista computer and drag and drop the folder onto Vista.
Charlie06 is offline Find More Posts by Charlie06   Reply With Quote
Old Nov 01, 2009, 03:29 AM   #12
Thanks, Charlie06.
I'll see if I can find someone still running XP. If I can't, can anything be done?
Old Nov 01, 2009, 04:36 AM   #13
Charlie06's Avatar
Personally I don't know of any other way, that's the way I've been doing it ever sense I started using Vista.
Old Nov 01, 2009, 05:21 AM   #14
I'll see what I can do, Thanks again for the help.
Best advice is don't go near Reflex!!!!
Old Nov 01, 2009, 10:03 AM   #15
Reflex sim model builder
BurkhardE's Avatar
How's that? Are you asking for advice or are you giving advice?
Did you check the SimWerk website, especially the download center? Guess you have version 5.03, anyway they offer a Vista install especially for that.
Just for the record, would be interesting to know whom you asked, what the rude answer was, and what your question actually was.
BurkhardE is offline Find More Posts by BurkhardE   Reply With Quote
Help needed for large RC helicopter. Dennis Fetters rec.models.rc.helicopter 10 Sep 24, 2009 05:25 PM
Help! Sloping---PSS Warbirds for Reflex XTR? Help? DWA Simulators 5 Dec 08, 2008 01:37 AM
Help needed for rookie/ batteries? freddy Electric Plane Talk 5 Sep 12, 2002 05:18 PM
Help needed for replacement GWS IPS motor Willy Parkflyers 3 May 22, 2002 08:27 AM
help needed for picking a motor for f-16 gliderdude Electric Ducted Fan Jet Talk 3 Dec 01, 2001 06:47 PM
Bored? Want to fight?
Join the RCGroups clan!
