Old Oct 10, 2009, 03:10 PM
trappy is offline
Find More Posts by trappy
trappy's Avatar
Austria
Joined Feb 2007
Great FPV plane - Ritewing Zephyr (flying wing)
This thread is to introduce the Ritewing Zephyr - my new favorite FPV plane. It's perfect for FPV from beginner to advanced. It has a wide speed range, is pretty simple to build (DVD with instructions included!) and will survive any crash. If built without the glass weave (just pure foam, similar to Maxi Swift) it flies very slowly and handles great. When you add the glass (called "Riteweave" - very light but strong material) and cover it with Monokote it turns into a high-speed beast. Some may think a Funjet is fast ... but the Ritewing will outpace it while being more stable and safe to fly.
Using the supplied building instructions, it's very simple to install your FPV gear properly and achieve maximum range without any of the equipment interfering with each other. It's a pusher plane, so there is no prop visible.
Here's the build-thread from Chris Klick (designer of the plane):
http://www.rcgroups.com/forums/showthread.php?t=1087976
Here's the FPV build thread of webdr:
http://www.rcgroups.com/forums/showthread.php?t=1098938
Here's my build thread:
http://www.rcgroups.com/forums/showthread.php?t=1100046
And here are a 2 movies I made ... as you can see, I built mine for speed
First 4 flights:
http://www.vimeo.com/6917628
5th flight .. a little more daring:
http://www.vimeo.com/6998976
The wing is available via RCGroups member "klique". You can buy it directly off him and he will help you order any additional components you may need (Riteweave, for example).
trappy is offline Find More Posts by trappy
Old Oct 10, 2009, 03:48 PM
logicwins is offline
Find More Posts by logicwins
FPV FTW
Austin, TX
Joined Dec 2004
Great videos Trappy. I will eventually be getting one of those once I have great video equipment tested with lots of flights on my Stryker.. a great test platform. The size is a little intimidating, id much prefer something a little smaller.
logicwins is offline Find More Posts by logicwins
Old Oct 10, 2009, 04:10 PM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
logicwins: There are smaller Ritewings available but if you want to get something reliable, stable and strong the size is perfect. Bigger size also gives you better options to space out your equipment properly. I needed only 5 test flights to get all issues sorted out, now I'm expecting crystal-clear reception. It weighs 1.6kg exactly with the glass covering, you can build it to about 1kg if you go light. You could even start out light, then once you're comfortable glass it and add a bigger motor.
Old Oct 10, 2009, 11:43 PM
kason is offline
Find More Posts by kason
kason's Avatar
Taiwan
Joined Aug 2009
nice vids, very entertaining.
one thing tho, i noticed that it flew 4km away in a hilly environment. my city is hilly too. what's your setup? I mean Tx Rx VTx VRx. got any booster or antenna modding?
kason is offline Find More Posts by kason
Old Oct 11, 2009, 03:47 PM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
kason: I'm on stock 500mW 2.4ghz gear from lawmate. R/C is a 35mhz setup using a 404cm antenna on the receiver. 4km is far from the range limit
Here's another video to show off the high wind flying and slow flight capabilities of the aircraft. The first part of the movie was shot at high altitude with winds of more than 50kmh
http://www.vimeo.com/7011889
Old Oct 11, 2009, 03:53 PM
Kmart is offline
Find More Posts by Kmart
Kmart's Avatar
United States, CO, Boulder
Joined Sep 2008
trappy- I'm impressed with how many trees you hit, and it kept flying! That was awesome. 5 and 4 .
The only reason you didn't get 5 green dudes, is I can't post that many.
Kmart is offline Find More Posts by Kmart
Old Oct 11, 2009, 03:56 PM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
lol. thanks Yeah the Zephyr really tracks nicely, it's very hard to knock it out of the sky
Old Oct 11, 2009, 04:06 PM
Kmart is offline
Kmart's Avatar
Joined Sep 2008
Trappy- are you in Somalia? Your GPS # at the end come up with Somalia. Beautiful place where you were!
Old Oct 11, 2009, 04:21 PM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
There is bad GPS at the bottom of the valley I flew (too steep), but more importantly, I think you mixed up long and lat:
http://maps.google.at/maps?q=47.1007,+10.2175
Old Oct 11, 2009, 04:28 PM
Kmart is offline
Kmart's Avatar
Joined Sep 2008
doh, I just tried to google 10.2 and 47.1, it was backwards.
Lol, that explains the snow.
Old Oct 11, 2009, 04:55 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
Nice Vid Trappy,you can defintely see the wind up on the ridge,but the Zeph took it with no prob.An easy star or maxi would have ben all over the place.
ck
klique is offline Find More Posts by klique
Old Oct 11, 2009, 04:59 PM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
ck
... and I've got video to prove it
Here I tried to make a climb in similar conditions with the Maxi Swift ... it didn't make any headway at all at full throttle so I had to turn around:
http://www.vimeo.com/5542577
If you have a plane that can fly against strong winds (I reached up to 80km/h into the wind, and almost 180km/h with the wind) you can fly on top of the mountain where there are nice waves/upwinds that carry you forever ... the wind is strongest just as you reach that sweet spot, though ... so you need a plane with little drag and good maneuverability to reach it
On another note ... that maxi swift tree action looks like wobbly slow-motion now that I've got the Zephyr the KX-131 is better than the CX161 though
Old Oct 12, 2009, 01:53 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
...R/C is a 35mhz setup using a 404cm antenna on the receiver. ...
How are the 4 meters spread on the wing ?
renatoa is offline Find More Posts by renatoa
Old Oct 12, 2009, 05:33 AM
trappy is offline
trappy's Avatar
Austria
Joined Feb 2007
It is directed to the opposite side of the VTX and left hanging out the side. About 3m hang out the back.
Old Oct 12, 2009, 06:08 AM
renatoa is offline
Joined Sep 2007
No issues with wire coming in prop, or wing leaning on that side ?
Discussion Ritewing Zephyr FPV build thread Matt Gunn FPV Talk 436 Feb 01, 2011 11:01 AM
Discussion Ritewing Zephyr FPV AP UAV wing klique FPV Talk 75 Oct 28, 2009 02:46 PM
Discussion Ritewing Zephyr 1st FPV flight Matt Gunn FPV Talk 13 Sep 18, 2009 09:25 PM
Scorpio ME 109, Great little plane! steve neill Parkflyers 20 Nov 21, 2001 09:40 AM
Terry is a great little plane jshelton Electric Sailplanes 3 Oct 22, 2001 11:57 AM
