Are you sure about that? If he is shipping items to the US he might get into trouble: http://www.cannabisculture.com/noextradition Pat MacKenzie |
Latest blog entry: er9x heli 450 heli set up (flybar)
And (if it makes any difference) he was only shipping seeds. I only posted that link because it is a high profile example of the US extending its legal sytem across into Canada. There is little chance that a few non-compliant video sytems would attract quite the same amount of attention. Pat MacKenzie |
Joined Jan 2007
Well,
I am not pledging here for myself. I will do the best I can to cooperate with FCC - but within the boundaries of the Canadian Laws and Privacy regulations. I believe that cooerating with them will make things less harmful for everybody. My concern is about the consumers. Many of the consumers use these transmitters as they should - within the legal boundaries and they have the necessary licensing. Some don't but hey is their choice. Since many of the transmitters will probably be required to be locked down on one frequency from here on - the consumer who used it legally will be the one who will suffer - instead of having 3 available channels - it will have only one. |
Joined Jan 2007
Joined Mar 2008
. On a serious note , however , I do agree that what happened with the FCC sounds pretty sneaky to me . Your right that it sure sounds like some other company using dirty tactics to get the FCC to eliminate their competition . Sad .
Keep in mind doesn't have to be someone on the forum reporting you. It could be some cowboy Amateur Operator reporting everyone. I'm assuming this has to deal with the 2.4ghz radio equipment. If it is you're not the only one out there selling this stuff. There are more applications for it other than FPV.
Joined Jan 2007
I've visited a couple of canadian security stores and I fould that they without restriction sell 1W, 1.5W and even more powerful 1.2 and 2.4Ghz stationary transmitters for their customers all over urban environment. These can trasmit on the same frequencies as ours. So I am aware of other applications very well, but those could cause much more interference than we will ever do.... |
The ARRL has mentioned its concern about the illegal unlicensed use of these non type accepted devices for years. The FCC and the DOC cooperate together. Their rules and regulations are very similar. If someone has violated an FCC regulation it is likely the equivalent DOC reg has been broken too.
If you fly FPV in the US and your video range exceeds 30 feet and you do not have a valid Amateur Radio License you are most likely breaking FCC regulations. de WA8ZAH P.S. Any Ham op with with a sense of reality realizes the 2.4ghz band is worthless to us for communications with all the WiFi/ portable phones ect.. These "Long Range" 433mhz adapters are another story. Your likelyhood of getting busted without a license is excellent.. |
