Old Oct 10, 2009, 08:28 AM
vernon7026 is offline
Find More Posts by vernon7026
Return of the Warlord
vernon7026's Avatar
United Kingdom, England, Wallington
Joined Aug 2009
Mini-HowTo
wot trainer
I am busy with a Wot trainer , my first plane ?
I have heard that the Ailerons should be pinned ? What is this exactly and how do you do it ? Please give me some advise on this
regards
vernon7026 is offline Find More Posts by vernon7026
Old Oct 10, 2009, 08:45 AM
MCarlton is offline
Find More Posts by MCarlton
Cromer,Norfolk, UK
Joined Nov 2006
Pinning refers to a method of securing the hinges. When the hinges are glued into position in the control surface and the wing, drill two small holes vertically through the wing (and thus through each hinge) and then glue a length of cocktail stick or similar through the holes and cut off flush with the wing surface.
Do the same on the aileron.
This then stops (or helps to stop) the hinges from pulling out.
MCarlton is offline Find More Posts by MCarlton
Old Oct 12, 2009, 04:46 PM
Thermalin is online now
Find More Posts by Thermalin
I'm a pilot, 100 yrs too late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
WOT = Wide Open Throttle?
I have found the CA hinges need no pinning.. I have seen ailerons in pieces with the ca hinge still firmly attached to the wood on all sides.. (don't ask how i know ) You can larger sheets of the stuff and cut your own so you make them longer, etc.
Thermalin is online now Find More Posts by Thermalin
Old Oct 15, 2009, 02:50 AM
MCarlton is offline
Cromer,Norfolk, UK
Joined Nov 2006
Wot = range of models from Chris Foss, "Wot Trainer" is the latest incarnation.
http://www.9m2bx.net/chris_foss_wot_trainer_review.htm
Old Oct 15, 2009, 07:16 AM
Thermalin's Avatar
Joined Jan 2005
Now that is a tail skid.
Looking at the photos.. you definately want to stay away from those funky bends in the exposed pushrods for the rudder and elevator connections. If you go with this ARF... the elevator is single piece and the rudder is angled up at the bottom.. A good mod would be to run the rod straight out the back of the fuselage and center the horn on the elevator. This way it's a straight shot out the back, and concealed. This is done on some of the more basic sailplanes to reduce drag getting all that linkage out of the airflow. The rudder pushrod could also be straightened out by lowering the horn.
Old Oct 15, 2009, 03:05 PM
MCarlton is offline
Cromer,Norfolk, UK
Joined Nov 2006
I thought that, those pushrod bends look horrendous, and I'm rather surprised at them, they look awfully sloppy.
Old Jul 20, 2010, 09:45 AM
ma_zeman is offline
Find More Posts by ma_zeman
Joined Jul 2010
Pushrods
Sorry...I had to interject after seeing what some of the posts here said...
Those pushrods are the wrong way round, the one connected to the rudder should be connected to the elevator and vice versa. You'll notice that then they both line-up without the need to drill extra holes in the fuse. Apologies to the builder as I've seen the instructions and they do tell you to do this, but a little common sense would tell you they're the wrong way round...
Rob
ma_zeman is offline Find More Posts by ma_zeman
Old Jul 25, 2010, 04:43 PM
cmulder is offline
Find More Posts by cmulder
Ireland
Joined Apr 2001
pushrods
I agree that the pushrods are the wong way and am amased a reviewer who does improve the model does overlook this basic fact.
but like the reviewer writes once the plane is made more durable why choose this model since and advantages are gone
cmulder is offline Find More Posts by cmulder
Help! Chris Foss WOT Trainer Throttle Servo Rod Problem! iRiddim Fuel Plane Talk 5 Apr 23, 2014 07:59 AM
