| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
CC ICE-100 weight gain
I don't know but the specs show a weight of 56.7gm or 2oz for the ICE-100. I bought 2 because of the power handling and low weight. Horrors, when I weighed mine, it was 110gms!! I know the weight is without wires but double the published weight?!! There must be a misprint somewhere Castle.Did you guys confuse the weight with the ICE-100 lite?
#2 |
A man with too many helicopter
The extra is the weight of the wires. Everyone cuts their wire to a custom length and installs connectors so the actual weight will be different for each instillation.
#3 |
I find it hard to believe that the weight of the wires without plugs is 55gms/ 2oz.
#4 | |
#5 |
That sickening crunch..
Wish we could solder the motor wires, or bullet connectors, directly to the ESC.. that would help immensely!
..a |
#6 | |
Problem solved.
#7 | |
Wrong side of the blue
#8 | |
Problem with that is if the motor has another type of connector already soldered on the motor leads (like the Scorpion does), you need to make an adapter, or remove the originals on the motor. I really see this cable issue as a non-problem--almost like people are whining for the sake of whining. I've shown a trivial solution--it solves the weight and allows you the freedom to choose whatever connector you want to use. |
#9 |
The other problem is that everyone likes a different connector. The wires are still the best. You can just cut the wires as short as you like.
#10 |
That is why I would prefer solder pads...
The Markus controllers have this for their F5B controllers: ![]() (pads on the other side) |
#11 | |
..a |
| Thread Tools | |
| Discussion Cc Ice | la528it | High Performance | 104 | Jan 25, 2010 09:28 AM |
| Help! Phoenix ICE 100 | Guntars | Castle Creations | 2 | Sep 18, 2009 12:31 PM |
| Discussion New price CC ICE lite | Tim B | Castle Creations | 0 | Jul 15, 2009 04:34 PM |
| For Sale New Duratrax ICE $100 | Salvador | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | Nov 30, 2007 12:39 PM |
| For Sale New Duratrax ICE $100 | Salvador | Aircraft - Electric - Batteries & Chargers (FS/W) | 2 | Nov 15, 2007 03:35 PM |
