Old Oct 10, 2009, 01:20 AM
marinaru_ro is offline
Find More Posts by marinaru_ro
Romania, HD, Sāntandrei
Joined Apr 2006
Build Log
Romanian high-power tug ZIMBRUL class
Hello guys!
I haven't write on the forum for awile, just watch your discussions, very interesting subjects, i just hope you will watch this thread too.
After a long period of documentation, (about 3 years) i have started the build of this tug about two months ago. It is one of the most powerfull tugs that operates in Black Sea, with twin diesels of 3300HP each.It was designed in 1986 at ICEPRONAV, the romanian ship design institute. There are four ships in this class, three in romanian navy and one in Greek service.
Some specs:
Lenght-35.80m
Beam-11.8 m
Twin props with a 3.8m in diameter in nozzels.
Can be used also as a icebreaker.
I am having almost the complet sets of shipyard drawings for every part of it, about 124 sheets of plans!
I hope you will like it
Best regards
George
marinaru_ro is offline Find More Posts by marinaru_ro
Old Oct 10, 2009, 01:58 AM
Joined Apr 2006
The model is in 1:45 scale, with a total lenght of 81.5cm.
i have used two Pro480 motors with two belt gears obtained from old Canon Ink-jet printers with small modifications.The gears ratio is 1:8, so at 6volts the props will have about 1200rpm/min at max. I will use two scratch built props, from brass with a 78mm in diam. The full size props are having variable pitch and my wish is to have this on the model also...
Some pictures...
Old Oct 10, 2009, 02:07 AM
Joined Apr 2006
I was on the real ship this summer at Constanta port and take about 300 pictures.
The nozzles are molded from fiberglass with styrene rudders.
Pictures...
Old Oct 10, 2009, 02:36 AM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Excellent work...
We will see some ice breaking tows soon?
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Oct 10, 2009, 02:44 AM
Cadmunkey is offline
Find More Posts by Cadmunkey
Guard-Engineer
Cadmunkey's Avatar
Canada, BC, Chilliwack
Joined Jul 2009
That's great work. I like the finish of the hull. I've always liked the flat look better than gloss.
Cheers,
Cadmunkey is offline Find More Posts by Cadmunkey
Old Oct 10, 2009, 08:28 AM
jjac is offline
Find More Posts by jjac
I'm tired.....
jjac's Avatar
Conway,Myrtle Beach SC
Joined Jul 2009
Skills!!
jjac is offline Find More Posts by jjac
Old Oct 10, 2009, 09:49 AM
fooman2008 is offline
Find More Posts by fooman2008
United States, ID, Rexburg
Joined Sep 2008
What a monster! if the scale is anything like the full size version you could use it to tow you in a dingy and go trolling!
Foo
fooman2008 is offline Find More Posts by fooman2008
Old Oct 10, 2009, 03:03 PM
Joined Apr 2006
Back with some pictures.
First thank you for watching this, and Umi i know you are a really specialist in modern ships so i will really need some help from you and other guys here during the build because this is my first "modern" tug. .
I have used email colours for airbrush, then covered with flat clear.
The model is having independent propulsion for each prop and also independent move for the nozzles. I can also mix them from the remote.
From my calculations it will have about 10.9Kg ; and lots of power i hope
Old Oct 10, 2009, 03:11 PM
Joined Apr 2006
As i have write before i was on the tug this summer and had the chance for a small run (about 4 Hours), during this time it towed a very large cargo(new build) out of port for first sea trials and belive me it it a very maneouvrable tug even without bowthruster. The bollard pull is 107tons wich is quite impressive.
Old Oct 11, 2009, 01:18 AM
Joined Apr 2006
Last week i have also begun the build of the superstructure, simple as form but very complex in details, alot of angles especially at the funnels.
I have used 0.8mm thick plywood for the walls and 2mm ply for superstructure's frames.
Old Oct 11, 2009, 01:23 AM
Joined Apr 2006
And this is where i am now...
Best regards
George
Old Oct 11, 2009, 08:18 AM
-kno3- is offline
Find More Posts by -kno3-
-kno3-'s Avatar
Austria, Vienna
Joined Mar 2008
Very nice hull! How long is it?
-kno3- is offline Find More Posts by -kno3-
Old Oct 11, 2009, 09:06 AM
PunyV is offline
Find More Posts by PunyV
Vestby, Akershus, Norway
Joined Mar 2005
If you read the first line in post nr 2
By the way! It's a very nice build!
PunyV is offline Find More Posts by PunyV
Old Oct 11, 2009, 09:08 AM
-kno3- is offline
-kno3-'s Avatar
Austria, Vienna
Joined Mar 2008
Missed that :-)
Old Oct 18, 2009, 02:45 AM
Joined Apr 2006
Hello guys!
I have made some progress, not much because of the time. I have used styrene to make the pieces like vents and some welding lines on the superstructure. Have also prepared the place where the towing hook will rotate; also used styrene for this and a rail from my collection of modeltrains.
New battery for high power applications? Jim McPherson Electric Plane Talk 3 Aug 01, 2002 07:24 AM
HIGH POWER ! Evo One 50 tested ! GREAT ! Vince Belgium Electric Ducted Fan Jet Talk 0 May 07, 2002 05:44 AM
Are there any Small High-Power motors for slow-flyers yet? e-sailpilot86 Parkflyers 40 May 04, 2002 10:38 PM
GWS IPS gears with EDF50's High power C motor GWS4CEO Parkflyers 16 Nov 18, 2001 07:15 PM
Large, high-power/performance electric gliders ShredAir Electric Sailplanes 5 Jul 08, 2001 02:39 PM
