| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 |
Guest
Posts: n/a
[RCSE] How to determine the right fin size
Much have been said here about the
correct relation between fin size and dihedral, as most of us know they are interrelated, for too small fins and we have an aircraft prone to Dutch Roll, and too big a fin and we have an airplane that easily enters a spin. I have wondered about how test pilots find out the exact correct size and if the method can be applied to models, and the answer is an emphatic yes, and no, often our models are too crowded. For power models it's probably easier, as their fuselages usually are roomier! What they do, is to trim the aircraft for glide and then apply a tiny bit of, say left aileron, to produce a little bank. To counter the turn pilot pushes a little right rudder so that the aircraft continues forward in a straight line, if a bit crabbed (yawed). Now comes the tricky bit for us modellers - they let go of the stick and see what happens. This is by no means equal to us letting go of our tx's sticks, as that means the servos neutralizes the ailerons. Our valiant test pilot then repeats the procedure with the rudder flowing free (feets off the pedals). If the plane lowers the low wing with the hands off the stick the fin is too big, or with the ailerons fixed and the try to turn into the lower wing - entering a spiral dive the fin is too big, if the wings try to reduce the bank all is well :-)! If the ailerons are locked and the rudder let free it should not try to enter a spiral dive either! (all these facts gleaned from Darrol Stinton's Flying Qualities and Flight testing of the Aeroplane, publ. Blackwell Science) Well, how can we apply this to our one-off designs, modifications, et cetera? Or if I am a producer of commecial kits, what then? What we need is a possibilty to "unlock" the ailerons and rudder, and there is a possibility, and a rather neat one I think :-)! Copyright, me, of course :-)! : What you do is reinvent the centre aileron servo system (one servo for both ailerons, by the means of Bowdens, push-pull lines, push-pull rods, whatever), but this time it is just a servo without innards, but the output arm in place , so there is little or no resistance. This servo is then connected to the aileron servo by pull-pull lines. and the aileron servo sit on an old classic servo tray, or you use two aileron servos and an electronic mixer, onboard or in your tx, one servo pulling the dummy servo one way and one the other. For the rudder things are much simpler, as a common system is pull-pull. Here you simply mount the rudder servo on a mixer slider (as used on many early flying wing), or if the pull-pull system includes a slider already (to tension the lines correctly a slider a spring is often incorporated), you just replace the spring with a servo. As you see, some sort of pull-pull system is needed (could be mainly pushrods except for the last bit, if you like), as pull-pull is the only way to make the rudders trail free, that I see workable. Anyone wanting to use this test system has to send me a picture of the plane before, and after, modification! Muchos gracias! Thank you! Tackar, tackar! Danke, Merci! Tord, Now taking off his thinking cap to repair his ElectriCub (don't ask why I need to repair it)! RCSE-List facilities provided by Model Airplane News. Send "subscribe" and "unsubscribe" requests to soaring-request@airage.com. Please note that subscribe and unsubscribe messages must be sent in text only format with MIME turned off. |
#2 |
Guest
Posts: n/a
Re: [RCSE] How to determine the right fin size
>as most of us know they are interrelated, >for too small fins and we have an aircraft prone >to Dutch Roll, and too big a fin and we have >an airplane that easily enters a spin. Don't over-generalize here. The effect of the vertical tail on spiral stability critically depends on the sign of spiral stability already present (i.e. is it already stable or unstable). The latter can be estimated by Blaine Rawdon's parameter, which I call "B": B = EDA * (tail_arm/span) / CL Case 1: B<5, spiral stability is negative (unstable). Enlarging the vertical tail will make the spiral grow faster. Case 2: B>5, spiral stability is positive (stable). Enlarging the vertical tail will make the spiral die off faster. The crucial point is that B itself does not depend on the size of the vertical tail. In practical terms, enlarging the vertical tail on a spirally-stable poly glider (Case 2) will actually IMPROVE its spiral stability, contrary to popular lore. This is observed in poly DLGs, which have huge vertical tails but still have good spiral stability. Ditto for aileron gliders with lots of dihedral. Enlarging the vertical tail on a flat-wing aileron glider (Case 1) will indeed make the spiral stability worse, but I don't see this as a major consideration. Dutch roll damping is much more important, especially during a spot landing. Has anyone ever seen a glider with a vertical tail which was too big from the viewpoint of controllability? I doubt it. RCSE-List facilities provided by Model Airplane News. Send "subscribe" and "unsubscribe" requests to soaring-request@airage.com. Please note that subscribe and unsubscribe messages must be sent in text only format with MIME turned off. |
| Thread Tools | |
| Discussion Anyone know how to choose the right prop size? | Generalfred | Electric Plane Talk | 1 | Jan 23, 2007 10:34 PM |
| Discussion how to determine the right CG for this model | Florin777 | Fuel Jet Talk | 3 | Feb 10, 2006 03:09 PM |
| How to determine a good engine size? | rca420 | Engines | 3 | Jun 08, 2004 11:00 PM |
| Re: How to determine the right fin size | Tord Eriksson | RCSE | 0 | Apr 24, 2003 04:02 AM |
| How do I determine model/engine size? | tolladay | Scale Electric Planes | 9 | Sep 19, 2002 06:44 AM |
