Pittsburgh, PA
Joined May 2008
I prefer the LG arrangement on your bigger one personally. Wire gear always ends up turning into a pain for me(I don't fly from the friendliest grass) and would rather just use a good sturdy aluminum setup and be done with it. All of my birds are that way except my Corsair and I hate it's wire gear setup
Milton, WI USA
Joined Dec 2007
Landing Gear
You know I am with you on the wire gear. The Dural style gear is so much better and virtually no problems. Our field is grass also, in all my years of flying I have only been in one club that had a paved runway, I really prefer the grass. As I mentioned to Chris, it seems the music/piano wire we get today is so soft it is little more than stiff wire. Have you had a chance to get started on your big Cub Bee yet ? Would really like to see that one, the little guy flys so sweet in your video I can only imagine the bigger one would be great also. Seems like your design is dialed in just right. Tom |
Pittsburgh, PA
Joined May 2008
I got to get more balsa sheeting this weekend and will be back on the build. Thanks for the compliment, I really got lucky because I basically made it up as I went along. There is one flaw to the little guy that has surfaced: the LG mounting block is too weak and gave out I'm sorting out this issue so the bigger brother doesn't have the same problem
United States, FL, Palmetto
Joined Sep 2009
Tom,
Speaking of CG, where should it be located on this plane? I took your advice and I am going to put an OS .25 on her. Started to recover the fuse last night. Coverrite is working well. Goes on with a lot less heat than superkote. Thanks, Chris |
Milton, WI USA
Joined Dec 2007
Little 'Poke CG
I think you will be very pleased with the OS .25. As I said earlier, the OS engines are a little more expensive but they are excellent. The CG on the Little 'Poke is set at 3.625" from the leading edge at the fuselage. It should be suspended on your balancer inverted. If you go to Towerhobbies.com and search "Slowpoke" you can bring the .10/.15 up and review the manual online. If you have need of a manual I have one I would be happy to send you, let me know. Tom |
Milton, WI USA
Joined Dec 2007
Little 'Poke Pictures
I just sent you a message on the CG but I remembered you were thinking about adding ailerons to your wing. Attached are a few pictures of my Little 'Poke that may be useful. TOM |
Milton, WI USA
Joined Dec 2007
Bundle Of Sticks
Thanks very much ! I truly love the Stearman also, mine was big and yellow. People like your husband and myself that build airplanes from "a bundle of sticks" get a great deal of satisfaction from our creations and when our loved ones share that pleasure it is truly special. My wife shares me with my hobby and loves to see my creations as well. Thank you, Tom |
Milton, WI USA
Joined Dec 2007
Cub Bee
Great shots of you C-B. The landing gear looks great. I really like the lines of your C-B and from your video I know it flys great. Will Bigger C-B have the same lines ? On my Bigger 'Poke, all the trim is done all electronics installed and will be ready for flight in the next day or two. I have to mask it off and spray a coat of clear flat LustreKote. I used Ultracoat for the trim and I want to kill some of the shine as well as seal down all the edges. I have to re-check the CG and weigh it. I am sure I went past my 9.0 lb target. Mainly because I used the dual batteries/switches and the MG servos, but that is ok. When I build a kit or a scratch I add a lot to the airframe. I hate to have to strip covering and re-do because some point in the airframe has rattled loose or let go, and stripped servos will ruin your day. The HS5645-MG's are digital of course and while holding zero resolution they do consume more power. Thus the added need for the dual battery/switch setup, not to mention the comfort for the guy on the box. Tom |
| Thread Tools | |
| Wanted! 3D 33% or little larger | Kev71H | Aircraft - Fuel - Airplanes (FS/W) | 4 | Aug 19, 2004 11:31 AM |
