Espritmodel.com Heli Air
Old Oct 07, 2009, 03:18 PM
Joined Jul 2009
ST Models Fox EP ARTF
Think there just out... anyone got one yet?
After the sucess of the ASW28, its got to be a good one.
Details here
http://www.ripmax.com/item.asp?itemi...0&Category=010
Kn0bby is offline Find More Posts by Kn0bby
Old Feb 23, 2010, 06:55 AM
Greece
Joined Nov 2009
Is anybody who has experience with this model
asterixx25 is offline Find More Posts by asterixx25
Old May 08, 2010, 04:45 PM
Carl Petersen's Avatar
United States, AZ, Quartzsite
Joined Mar 2002
Tower H just started selling them so we just need a review.
Carl Petersen is offline Find More Posts by Carl Petersen
Old May 08, 2010, 11:09 PM
Crashasaurus Dumbthumus
road_rascal's Avatar
USA, MN, Apple Valley
Joined Dec 2008
Banana Hobbies is also selling the ST Fox glider. Looks nice.
road_rascal is offline Find More Posts by road_rascal
Old May 23, 2010, 07:02 AM
Joined Dec 2007
I have one of these (the version distributed by Hype), flown it a few times and love it! But is this the only thread about this plane? I'm a fixed wing noob, hence not qualified for a quality review but if you have any questions I'll answer it the best I can.
McMoron is offline Find More Posts by McMoron
Old May 23, 2010, 04:56 PM
Joined May 2007
I ordered one of these planes from tower Hobbies, still have not arrived. I have searched many discussion forms as well as this one and there are no reviews on this plane. the different on line hobby stores that sell this plane all use the same add but when you look under customers review there are none. You are the first to give any feed back on this plane positive or negative. I always try to read a review on a plane before I purchase it. I hope I made a good decision on this one. any info you can give will be helpful
wileyrc is offline Find More Posts by wileyrc
Old May 23, 2010, 06:24 PM
Joined Dec 2007
Well, my impressions/ experiences so far. I cannot tell how 'good' it is, since I cannot compare to anything else, hence I'll concentrate on the negative aspects, it's more like nitpicking, so don't jump to conclusions based on the negatives
- Extremely portable. This is actually very important for me, some planes in this class have glued tail surfaces, hence a pain in the b*** to transport them. This is why I ditched the Easy Glider and started looking for the Graupner Junior S, but decided to go for a plane with better acrobatic capabilities. The Fox comes in a 103x21x16cm (both RTF/ARTF) box which is perfectly portable, even in smallish European hatchbacks. The horizontal stabilizer is fixed with one screw/nut in less than 20 sec, and the piano wire has to be tightened at the servo (in the canopy). This should be a snap-on system of some kind, even though making some marks on the wire makes the trimming easy enough. Secondly, they could have added few extra, or better pieces of foam to transport the wings safely instead of loads of bubble wrap. This would have given this plane a truly Unique Selling Point in the market.
The hatch closes with a fairly weak snap-system, not reassuring at all, or at least if the puny rubber bands which are supposed to hold the battery snap, the battery will fall out in inverted flight and result in a crash - as demonstrated by a guy on YT This isn't a big issue, just add some velcro and the potential problem is sorted.
The plane can be flown with different sized batteries, but I mixed up some figures with the Windrider Fox, hence used a substantially larger battery (2.2Ah instead of 1.3Ah) which wouldn't necessarily be a problem, but since my battery was heavier I pulled it farther aft, which probably closed the ventilation channel. The result, On its second flight, 5-6min into the session, I had a semi hard crash, I wasn't sure why, I sort of lost control, after all I am a noob and it was slightly windy with some turbulence, but noticed the ESC was very hot (too hot to touch). I removed the heat shrink tubing and the plastic something between the board and the cooling plate, and applied a fair amount of silicone thermal paste. I'll salvage a ribbed aluminium cooling plate from a mother board og GPU in the future, but I definitely recommend everybody to watch out for the ESC. Secondly, I added a UBEC, actually it's a small 10A ESC with BEC, but now the power supply to the Spektrum AR7000 has redundancy. After its 3rd flight, I checked the temperature, and the ESC was still VERY hot (longer flight), so I believe the crash was due to power shortage (Spektrums are prone to fail (reboot) even due to minimal voltage drops).
The third issue is the fixture of the carbon rod in the wing, two screws are used to 'clamp' the rod at both ends in the wings. The screws are fairly small, hence afraid of stripping them, I might haven't tightened them enough, since after the 3rd flight I could see the wings were starting to separate... I've ordered some rare earth magnets and hope these will solve the (potential) problem, otherwise I'll probably drill a hole through the wing and carbon rod, and use a small nail and magnet to fix the rod.
There certainly is some flex in the wing, but it doesn't seem to be an issue AFAICT. If you are planning on 50mph slope soaring, then you'll have to add some carbon, but otherwise it looks adequate. The only carbon I'm going to add will be on the underside of the wing tips (for concrete/ asphalt landings).
Generally, it's a very nice plane, good looking, the foam is fairly smooth, not as many injection point as the Windrider, but if you are interested in looks, better sand the injection point down and give it a full coat of foam safe grounder. The folding prop is a bit flimsy, yet it survived the crash, which cracked the firewall plywood. I had to glue in a another one, but I'm very happy that the crash didn't cost me a penny. I cannot comment on the performance, the pilot (me ) is the bottleneck in my case. Btw. the best thing about it is the sound! I let it climb for a few minutes, and then let it go into a dive, over my head, that SOUND! YAY!
I tried to test the roll rate, but that manoeuvre didn't turn out very well I was saved by the altitude, so I'll wait a few packs before I try that again.
All in all, I'm VERY pleased with this plane, a plug n play plane for less than €100 delivered is a steal (in the EU at least).
Feel free to ask.
Old May 25, 2010, 05:36 AM
Joined May 2007
thanks for the info/review, my ST fox glider should arrive on wed, I should have time to test fly her on Friday or Saturday sounds like it should be a fun venture
Old May 25, 2010, 08:34 AM
Joined Dec 2007
You're welcome, I've started a new thread where I've tried to gather all relevant specs/ manuals/ reviews/ mods/ videos etc.:
http://www.rcgroups.com/forums/showthread.php?t=1250005
If you could post your impressions /review there as a more experienced flyer, it would be great.
Old Jun 29, 2011, 12:05 PM
Joined Jun 2011
ST model Fox review
Out of the box you just need a reciever and a battery unfortunatly my experience was a disapointing one. (Here is my story)
I was excited to get this model i finally got one from tower right around 130$ delivered. Got the receiver in the night before i was going to fly and tested everything was ready to go it seemed to have a boat load of power, this gave me high expectations. So the next nice afternoon I grabbed my batteries and headed to a friends open field about 30 acres with tall weeds. From here forward it all went down hill i launched it just like any hand launched glider got it about 200 feet up in the air and the motor just quit. glider it back down checked connections and tried with another battery just in case this was a problem, but the same thing happened again this time i almost lost the aircraft due to the low altitude i have come to the conclusion that the power system is a extremly cheap one that cant handle 40c burst battries and i was going to have to replace everything from front to back in the power managment sys.
which is too bad it had killer thrust initially. i tried to replace speed controller it did the same thing i think it needs a new motor going with a small rimfire they are bulletproof. and mabey a 30 amp speed controller .
I think it will be a good flyer once it gets a new power system.
but if i had to do it all over again I would have just saved the money and bought a more proven glider
Items i added
AR6100e
3s 1300mah 40c battery
wingit ill flyit is offline Find More Posts by wingit ill flyit
Old Jun 29, 2011, 10:42 PM
Joined Dec 2008
I wouldn't think a 40c battery would have anything to do with it. The 18A ESC does sound suspect. Did you putt a watt meter to it before the first flight?
The World Models Rambler EP Maiden Flight is Awesome! Best Value Available wannabe Parkflyers 3 Mar 09, 2012 05:43 AM
Discussion ST Models ASW28 EP Glider issues.... Kn0bby Electric Sailplanes 2 Apr 22, 2010 10:30 AM
Discussion ST Models Piper Cub EP ARTF Baz Ck Electric Plane Talk 0 Sep 02, 2009 10:37 AM
World Models Funworld EP kmashima Sport Planes 50 Apr 25, 2005 09:24 PM
world models funworld EP 25FX pipe RTF waytoofast Aircraft - Fuel - Airplanes (FS/W) 0 Aug 30, 2004 10:43 AM
