Old Dec 12, 2009, 02:57 PM
r/cmark is offline
Find More Posts by r/cmark
200 mph club
r/cmark's Avatar
United States, AZ, Fort Mohave
Joined Mar 2005
Originally Posted by Dbox View Post
I would install tail servo in the tail.Will clear more space in the fuse,no mess with cables/linkages.
With all these goodies in the nose ,You will have to counter weight her anyhow to achieve right CG.
You still will need a balsa spacer to widen the tail a little for servo to fit.
Yuri,who hates tail servos in the fuse.
The tail at its widest point is 3mm.
r/cmark is offline Find More Posts by r/cmark
Old Dec 12, 2009, 08:06 PM
Dbox is online now
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
I am washing my hands then
Yuri.
Dbox is online now Find More Posts by Dbox
Old Dec 13, 2009, 12:00 PM
Bro is offline
Bro
Find More Posts by Bro
Bro
Bro's Avatar
Southern California
Joined Feb 2003
Viper
Originally Posted by FASTBEN View Post
did i miss this plane,,,is sousa out?
ben
Ben,
one left, it could be for you!
send me email if you are serious..
B
Bro is offline Find More Posts by Bro
Site Sponsor
Latest blog entry: 2015
Old Dec 13, 2009, 05:24 PM
FASTBEN is offline
Find More Posts by FASTBEN
Cumulus Altimus
FASTBEN's Avatar
United States, TX, Keller
Joined Feb 2002
Originally Posted by Bro View Post
Ben,
B
i'll take it do not sell it...sent pm
ben
FASTBEN is offline Find More Posts by FASTBEN
Old Dec 13, 2009, 05:38 PM
sbritton is offline
Find More Posts by sbritton
sbritton's Avatar
USA, CA, El Dorado Hills
Joined Apr 2008
Viper Aileron
Okay, making more progress on the build:
http://www.rcgroups.com/forums/member.php?u=206818
Took about two hours to get one aileron perfect. The next one should go faster now that I have a good approach.
I also have the power system in. Initially I will be going with the NEU1110-1Y, CC125 and 4S-2600-35C. With the firewall set back (into) the fuse a bit more than normal, I'm hoping my spinner has enough bite on the prop shaft.
sbritton is offline Find More Posts by sbritton
Old Dec 14, 2009, 09:12 AM
FASTBEN is offline
Cumulus Altimus
FASTBEN's Avatar
Joined Feb 2002
will a 4s 4200 hyperion fit this baby?also can i go with Arc 28-47-1 kv-4250 and 110g it is similar than mega 16-25-1.with 5.2.1 neu on 4s.?
ben
Old Dec 14, 2009, 09:40 AM
MarkChinery is offline
Find More Posts by MarkChinery
Speed King
MarkChinery's Avatar
London Heathrow, Great Britain (UK)
Joined Feb 2003
sbritton,
you should of not cut so much of the servo recess away & left an edge round it. you then cut down the cover so it fits in the recess not just stick the uncut cover over the outer skin.
MarkChinery is offline Find More Posts by MarkChinery
Old Dec 14, 2009, 10:01 AM
sbritton is offline
sbritton's Avatar
Joined Apr 2008
Mark: Thanks for the pics...I can't believe I didn't think about that. Well, it's not too late, I can build up the lip a little on each edge to get it to fit better later.
I like how you did the aileron linkage on yours better that what Stratair suggested...seems like a cleaner install with less cutting involved. In fact I was considering doing the same with an adjustable clevis. Given that I'm not doing competition flying, what I ended up with should be sufficient.
Old Dec 14, 2009, 10:54 AM
r/cmark is offline
200 mph club
r/cmark's Avatar
Joined Mar 2005
I am going to have to mount the servo covers 'backwords' so the arms won't hit the cover.
Old Dec 14, 2009, 03:26 PM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
Originally Posted by miche View Post
For hor. stab at the center is 59mm
Not quite. How about this:
Troy is offline Find More Posts by Troy
Old Dec 14, 2009, 04:28 PM
miche is offline
Find More Posts by miche
miche's Avatar
Joined Oct 2008
All right, that is like 470mm
miche is offline Find More Posts by miche
Old Dec 14, 2009, 04:40 PM
FASTBEN is offline
Cumulus Altimus
FASTBEN's Avatar
Joined Feb 2002
well talked to bob,,mine is green with black tips,still dangeling over the motor....
ben
Old Dec 14, 2009, 06:13 PM
Troy is offline
Troy's Avatar
Joined Feb 1999
Thanks Miche, perfect.
Old Dec 14, 2009, 07:15 PM
sbritton is offline
sbritton's Avatar
Joined Apr 2008
Viper Elevator
Well, made some good progress and have the elevator done. Took a bit trial and error, but have a nice solid slop-free elevator.
Old Dec 14, 2009, 07:33 PM
FASTBEN is offline
Cumulus Altimus
FASTBEN's Avatar
Joined Feb 2002
looking at GB in 5.2.1 but all i see is 6.7.1 or 5.3.1
http://www.neumotors.com/Site/Gear_Drives.html
New Product New Build thread for Viper F5D Model Rob AR High Performance 20 Sep 08, 2009 03:06 AM
Discussion new pylon model - Viper F5D 2009 MarkChinery High Performance 2 Mar 11, 2009 01:46 PM
