Old Dec 10, 2009, 05:42 PM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
^^^ Yep, just down the boom. I want to do a general comparison of the tail boom length. I'd subtract the rear wing tab from the equation (~3/4") and go from wing TE at the center to the LE point of the horizontal stab. Just eye-ball with a yard stick, don't need it to .001"
Troy is offline Find More Posts by Troy
Old Dec 10, 2009, 05:45 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
What would be the best (read cheapest) way for me too get a "show" into NZ?
jackosmeister is online now Find More Posts by jackosmeister
Old Dec 11, 2009, 11:58 AM
r/cmark is offline
Find More Posts by r/cmark
200 mph club
r/cmark's Avatar
United States, AZ, Fort Mohave
Joined Mar 2005
Just arrived today! It is a really NICE plane!!
r/cmark is offline Find More Posts by r/cmark
Old Dec 11, 2009, 12:06 PM
carpetbomb is offline
Find More Posts by carpetbomb
finger slicer
carpetbomb's Avatar
Southern CA.
Joined Mar 2009
Looks nice! and love the color scheme.
mike
carpetbomb is offline Find More Posts by carpetbomb
Old Dec 11, 2009, 12:19 PM
FASTBEN is offline
Find More Posts by FASTBEN
Cumulus Altimus
FASTBEN's Avatar
United States, TX, Keller
Joined Feb 2002
looks great
ben
FASTBEN is offline Find More Posts by FASTBEN
Old Dec 12, 2009, 08:55 AM
sbritton is offline
Find More Posts by sbritton
sbritton's Avatar
USA, CA, El Dorado Hills
Joined Apr 2008
Build Log Started
Well mine showed up last night and started my Viper build log:
http://www.rcgroups.com/forums/showthread.php?t=1156201
sbritton is offline Find More Posts by sbritton
Old Dec 12, 2009, 10:40 AM
r/cmark is offline
200 mph club
r/cmark's Avatar
Joined Mar 2005
I got the motor and esc in. Trial fitting the elevator servo. The first problem came up with the cable for the elevator. My idea is to put the peice of wood in side to give the cable support and keep it from bending. Anyone got a better idea?
Old Dec 12, 2009, 10:48 AM
epc2 is offline
Find More Posts by epc2
Miami Fl/Santo.Dgo.
Joined Jun 2004
Is that a 180 esc ?, Wow that's overkill!!!
epc2.
epc2 is offline Find More Posts by epc2
Old Dec 12, 2009, 11:08 AM
miche is offline
Find More Posts by miche
miche's Avatar
Joined Oct 2008
For hor. stab at the center is 59mm
Originally Posted by Troy View Post
la528it, can you measure the tail moment for me from wing trailing edge to leading edge of the stab? Por flavor...
miche is offline Find More Posts by miche
Old Dec 12, 2009, 11:14 AM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, UT, Salt Lake City
Joined Dec 2007
epc2.
And heavy too! I was hoping to get away with a cc80 and makeup the watts with volts rather than amps...
la528it is offline Find More Posts by la528it
Old Dec 12, 2009, 11:47 AM
r/cmark is offline
200 mph club
r/cmark's Avatar
Joined Mar 2005
No ideas on the cable?
Old Dec 12, 2009, 01:11 PM
FASTBEN is offline
Cumulus Altimus
FASTBEN's Avatar
Joined Feb 2002
did i miss this plane,,,is sousa out?
ben
Old Dec 12, 2009, 01:54 PM
jjmouris is offline
Find More Posts by jjmouris
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
Get some carbon sock, wet this out when over the cable. Install it in the plane and let cure.
I have not done this personally but seen it done.
jjmouris is offline Find More Posts by jjmouris
Old Dec 12, 2009, 02:19 PM
Dbox is online now
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
I would install tail servo in the tail.Will clear more space in the fuse,no mess with cables/linkages.
With all these goodies in the nose ,You will have to counter weight her anyhow to achieve right CG.
You still will need a balsa spacer to widen the tail a little for servo to fit.
Yuri,who hates tail servos in the fuse.
Dbox is online now Find More Posts by Dbox
Old Dec 12, 2009, 02:46 PM
MarkChinery is offline
Find More Posts by MarkChinery
Speed King
MarkChinery's Avatar
London Heathrow, Great Britain (UK)
Joined Feb 2003
its easier to install the servo & snake doing it this way. have a plate for the servo which also has an end anchor point for the snake. Slide it in, stick the plate/servo in correect location & just anchor the rest of the snake down the fuz. I normally just run cyno down the snake & it locks to the side of the fux where it contacts when in the correct place.
different model but same installs on my Jibe1 build log. Here
MarkChinery is offline Find More Posts by MarkChinery
New Product New Build thread for Viper F5D Model Rob AR High Performance 20 Sep 08, 2009 03:06 AM
Discussion new pylon model - Viper F5D 2009 MarkChinery High Performance 2 Mar 11, 2009 01:46 PM
