Old Feb 02, 2010, 08:58 AM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, UT, Salt Lake City
Joined Dec 2007
Originally Posted by FASTBEN View Post
well little problem...after soldering the cc125 to the motor the length is about an inch to long and won't permit the battery to slip in,,,my battery came to wide to lay flat but can stand perfect....now the Question is how far can i cut the motor wire's back will it be solder-able.....the motor wire's are soldered to ESC directly i have removed the 3 motor wire's from esc and soldered direct to it..i need an 1" to make good.
ben
Ben, you may need to ditch the 125 and use ice 100... the 100lite is about the same size as the cc80... see if everything fits with the cc80. Remind me what motor you are using...?
la528it is offline Find More Posts by la528it
Old Feb 02, 2010, 09:04 AM
FASTBEN is offline
Find More Posts by FASTBEN
Cumulus Altimus
FASTBEN's Avatar
United States, TX, Keller
Joined Feb 2002
b40 fai carbon case.
ben
FASTBEN is offline Find More Posts by FASTBEN
Old Feb 02, 2010, 09:07 AM
la528it is offline
la528it's Avatar
Joined Dec 2007
ben
Which b40... is the the L (long can)? I.E> can you measure the length of the motor, and then the length of the motor and gb... you may be out of luck if she is too long
Old Feb 02, 2010, 09:13 AM
FASTBEN is offline
Cumulus Altimus
FASTBEN's Avatar
Joined Feb 2002
65mm 85.5mm w/GB
Old Feb 02, 2010, 09:16 AM
la528it is offline
la528it's Avatar
Joined Dec 2007
65mm 85.5mm w/GB
Ben you may be out of luck here, mine is a good 10mm shorter, and just fits with the ice 100 lite...
Old Feb 02, 2010, 09:27 AM
FASTBEN is offline
Cumulus Altimus
FASTBEN's Avatar
Joined Feb 2002
*&%(%*(&tttt.rich can i cut the motor wire's back?
Old Feb 02, 2010, 09:29 AM
la528it is offline
la528it's Avatar
Joined Dec 2007
I don't know about that sorry! I do know that if they are coated near the motor, you will have a very difficult time melting the coating off... I saw a thread here where they said you need to melt an asprin over the coating to get through it... ask in the motor section, they may be able to help
Old Feb 02, 2010, 09:38 AM
FASTBEN is offline
Cumulus Altimus
FASTBEN's Avatar
Joined Feb 2002
thanks rich
Old Feb 02, 2010, 10:41 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Would folding the wires back over the motor help?
GregG is offline Find More Posts by GregG
Old Feb 02, 2010, 12:32 PM
dearnheart is offline
Find More Posts by dearnheart
Joined Feb 2010
Originally Posted by la528it View Post
Howdy, I spoke with stratair about ordering a viper this morning, but given the shipping, it makes more sense to have SSUSA handle it all....
These are 1.4 meter planes, so before you tell me to buy an escape, these are larger and from what I can tell, you MAY be able to fly it like a hotliner:
http://www.youtube.com/watch?v=ja0ktbwyVIo
Interested? Let Bro know!
Edit: didn't know ssusa was going to carry these... much easier than me ordering for you all :P
http://403987l02du3mjxe10mlv7md3d.hop.clickbank.net/
dearnheart is offline Find More Posts by dearnheart
Old Feb 02, 2010, 01:26 PM
mattbrignoli is offline
Find More Posts by mattbrignoli
Joined Sep 2008
hello , what is the best motors : neu 1112/1y or mega 16/35/1 ???
where buy this motors at the best price ??
thnks a lot !
Matthieu
mattbrignoli is offline Find More Posts by mattbrignoli
ptxman is offline
Find More Posts by ptxman
Calgary, AB, Canada
Joined Oct 2002
ben
Are you considering 4s on this motor? If its the typical B40/6-turn/F5D motor Im thinking of, know that it was origially kv-d for 9C nimh (~10.8v nominal, probably <9v suppressed). It screams on 3S lipo (11.1v) & we blew a few Hacker 140A esc's pushing thos kind of amps. The CC125 was getting close to max'd, but a better controller IMO.
I think I smell charcoal something on 4S (14.8v) unless you have a toothpick prop, then again - why?. I dont think a 100A ice would cut it on 3S nevermind 4S. Size is a secondary issue.
edit ** If its the 12-cell ?-turn B40, thats ok. Sorry forgot they made 2 flavours **
check my pic, post #19.
http://www.rcgroups.com/forums/showthread.php?t=1180688
Replacing/re-orientating the CC-125 caps is not a big deal & will shave an inch off the esc length. The wire-over-motor rec is good too, thats how we usually do it. Direct soldering on the board is a bit iffy unless you are an experienced solderer & the assembly stays perfectly intact. Cutting the motor wires shorter is a non-no as per the coating comment.
ptxman is offline Find More Posts by ptxman
Old Feb 02, 2010, 04:01 PM
FASTBEN is offline
Cumulus Altimus
FASTBEN's Avatar
Joined Feb 2002
well mine is a f5f with 6.7.1 GB....
ben
Old Feb 16, 2010, 09:54 PM
plainguy is offline
Find More Posts by plainguy
Take off, eh
plainguy's Avatar
USA, CA, Long Beach
Joined Jan 2009
not putting out and overheating
My Viper has a Neu 1112 1Y w/ ESC PHX CC80 w/ 4.1 x 4.1 prop -wired like GregG on his Feb 7 pic. The motor doesn't have much pull. It does't feel nor sound right and overheats within a few throttle blasts. My escape with a similar set-up has no such problems.
To test I put on a Neu Battery 3S 2500 mAh. it drew about 65 amps.
didn't have much oomph and I detected a bit of a burnt smell.
I am baffled... Might anyone know what the problem may be?
thanks.
raul
plainguy is offline Find More Posts by plainguy
Old Feb 16, 2010, 10:05 PM
Thekid3418 is offline
Find More Posts by Thekid3418
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
That is way WAY too high. You should be around that many amps for a 4.75x4.75. A few possible causes come to mind
1) Is there any rubbing? IE of the spinner on the fuse? This could result in higher current draws
2) You may have burnt the motor. This would result in the kv increasing, which is counter-intuitive as you say it has less thrust (RPM) then usual...But it also could explain the smell. And if you burnt it bad enough the change in current draw...
Can you pull it out and see if the windings are a strange color at all? If so, it sounds like you should send it in to SNEU to get checked out/repaired. Maybe upgrade to something like a 1115-1.5D for 4s fun
Thekid3418 is offline Find More Posts by Thekid3418
New Product New Build thread for Viper F5D Model Rob AR High Performance 20 Sep 08, 2009 03:06 AM
Discussion new pylon model - Viper F5D 2009 MarkChinery High Performance 2 Mar 11, 2009 01:46 PM
