Old Dec 30, 2012, 11:02 AM
LVSloper is online now
Find More Posts by LVSloper
LVSloper's Avatar
Las Vegas
Joined Mar 2009
Originally Posted by Arcteryxxx View Post
Was it a 1115/1Y you had in it before also? If so, I can tell you I have a 1115/1Y which is too "hot" because of a loose shaft. It will be sent back for repair soon. I expect a drop in amps like yours, but can compensate with a bigger prop if the performance is not satisfactory.
Yes, same motor as before; the last one burned up due to a bad batch of magnets according to Neu Motors. The current motor is turning out 74 amps and 960 watts on 4S and 107 amps and 1860 watts on 5S. The old motor turned out 93 amps and 1126amps on 4S and 121 amps and 2110 watts on 5S. (4.75X4.75 prop).
LVSloper is online now Find More Posts by LVSloper
Old Dec 30, 2012, 03:39 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Do you have rpm data from the two motors and same prop/battery? Your new motor might turn the prop at the same or similar rpm but with higher efficiency than the old one.
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Dec 30, 2012, 05:13 PM
LVSloper's Avatar
Las Vegas
Joined Mar 2009
The data logging failed to download; I will have to check my saved files and see if I have any data to compare. The batterys(TP) are a year old; this might contribute to some loss of power.
Old Dec 30, 2012, 05:46 PM
biskit is offline
Find More Posts by biskit
United States, AL
Joined Apr 2007
Bad magnets presumably means weak magnets. Weak magnets will raise the kv of a motor if everything else is the same. So it may be your old motor was defective drawing that much power and now it seems like you've lost power with a motor that is working as designed.
Change props to get the power back up if that is what you are looking for.
biskit is offline Find More Posts by biskit
Old Dec 30, 2012, 06:03 PM
Arcteryxxx's Avatar
Joined Feb 2010
Agree! I expect an increase in performance, all other things being equal.
Old Jan 01, 2013, 04:02 PM
LVSloper's Avatar
Las Vegas
Joined Mar 2009
Biskit,
Thank you for the clarification, I'm looking to keep the plane flying in the 200 mph speed range on four cells. I will have to double check the operating range for the motor according to Neu motors. The motor is producing slightly more watts per amps over the old motor; maybe a little higher efficiency.
Old Jan 01, 2013, 04:11 PM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Your watt meter is measuring watts consumed, not produced.
Watts = volts x amps
More watts from less amps means more volts. Thats your battery not your motor...
jackosmeister is offline Find More Posts by jackosmeister
Old Jan 06, 2013, 06:57 PM
LVSloper's Avatar
Las Vegas
Joined Mar 2009
Test flight - Neu motor
Well, I finally had some good weather here in Vegas; tested out the replacement motor from Neu Motors. The plane is probably down 20mph; trims were way out of adjustment. I only ran it on the 4S today since I have not flown it since April and being a new motor i did not want to stress it too much(5 flights). I'll have to download the flight data log and check out the numbers. The flight times were up about a minute and half along with motor run times up about the same. I averaged five and half minutes on flight time and three and a half minutes of motor run time; comsuming about 1.7 - 2.0 volts on the batterys. I have not recharged the batterys to get a mah reading.
5S Saturday.
Old Jan 15, 2013, 02:32 PM
smoothflying is offline
Find More Posts by smoothflying
Joined Apr 2012
I got a question. I am wanting to make a little air hole on top of the fuse in front of the wing saddle. Is this a good place to make an air hole. I have one on each side of the fuse up front for air to the motor but want to make a hole up where the esc gets pushed to the top of the fuse when I put my 2 cell pack under it. Would this make any compromise to the fuse?
smoothflying is offline Find More Posts by smoothflying
Old Jan 15, 2013, 02:43 PM
Mreyello is offline
Find More Posts by Mreyello
Mreyello's Avatar
Deutschland, RP, Niederzissen
Joined Dec 2011
The front-end beside the motor is a low preasure area, good spot to get air out,not in.
A hole right at the wingsattle may give a higher preasure area(depends how close to the wing) so it may happen that airflow is reverted and rear hole is inlet and the front holes are outlet.
Yello
Mreyello is offline Find More Posts by Mreyello
Old Jan 15, 2013, 02:56 PM
Joined Apr 2012
Yello
It wont be right on the wing saddle maybe about in the middle of the nose and leading edge of wing.
Old Jan 15, 2013, 03:08 PM
Mreyello is offline
Mreyello's Avatar
Joined Dec 2011
Just check out bernoullis law:
http://en.wikipedia.org/wiki/Bernoulli%27s_principle
At the front side of the fuse airflow is accellerated ( as the diameter gets bigger) so surface preasure is low.right behind the spinner preasure is lower than more behind where the fuse starts to get cylindric, but anyway both spots are low preasure.
The airflow followes the preasure difference, if frontholes got lower presure than the rear one airflow will be reverted.
Best results i got with inlet in Spinner nose and outlet at the end of the fuse.
Yello
Old Jan 19, 2013, 03:18 PM
Quadmad is offline
Find More Posts by Quadmad
Joined Jul 2012
Originally Posted by Coil View Post
Sorry to but speedcup outrunners are way bigger You will never fit one in a viper, you need 40mm or more, they also use 7inch or bigger prop. The folding props are custom made to sustain that kind of power.
My advice is to go with 28mm motor + gearbox and BIG prop or 28mm motor and small pylon prop.
If you seek speed go with pylon setup.
http://www.youtube.com/watch?v=FXXJe19Z0rI
Just watched this vid and I'm very impressed with the performance
he's running Mega 16-25-2 on 6s 2100mAh 30c the motor is rated @ 35 short time max amps I would be surprised if he's pulling 35 Amps it would be easily double that or more
I'm looking at a similar setup
can anyone give me more info?
Quadmad is offline Find More Posts by Quadmad
Reply With Quote  (Disabled)
Old Jan 19, 2013, 03:51 PM
Auckland NZ
Joined Aug 2007
16/25/2 is very overloaded on 6S, your better off going for a larger motor (16/30+), youll get more performance from less power, and have a motor thats not on the edge of melting. That setup would be over 100A
5S on the 16/25/2 is nice though.
Old Jan 19, 2013, 04:21 PM
Quadmad is offline
Joined Jul 2012
Thanks. where's the best place to buy a Mega motor ? any idea what prop he was using ?
New Product New Build thread for Viper F5D Model Rob AR High Performance 20 Sep 08, 2009 03:06 AM
Discussion new pylon model - Viper F5D 2009 MarkChinery High Performance 2 Mar 11, 2009 01:46 PM
