Old Oct 14, 2012, 08:11 AM
smoothflying is offline
Find More Posts by smoothflying
Joined Apr 2012
Originally Posted by johnnyrocco123 View Post
I like about 40 seconds on the jazz with 20 second breaks. So we will see......
Voodoo and I were talkina about it yesterday. The 1115/1Y is your ticket. You say you can not tell a huge difference between the 2.5 going from 4 to 5 cells. I can tell you honestly I can tell a massive difference going from 4 to 5 cells on the 1y. The 1y is the perfect combo I think.
smoothflying is offline Find More Posts by smoothflying
Old Oct 14, 2012, 09:38 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Originally Posted by smoothflying View Post
All these numbers are in the air flying. I did push it a little hard on the 5S. It is definitely a lot faster on 5S then 4S. Real hazy day and had an extremely hard time seeing it when it entered level flight to the field about 600ft away. I pulled out of throttle but still got a glide speed passing the radar gun at 211mph.
Which prop are you using?
GregG is offline Find More Posts by GregG
Old Oct 14, 2012, 03:18 PM
Joined Apr 2012
4.75x4.75
Old Oct 14, 2012, 04:26 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
1115/2.5D
I was getting 150 degrees on 5S with the 5.25x6.25
This was with 40 second runs with 20 seconds in between.
I would think that at 2800kv, it would be very limited like Voodoo suggested.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Oct 28, 2012, 07:34 PM
Joined Apr 2012
We had a very big flyin over here in Georgia and managed to get a high speed pass with the radar gun at 235mph on 5S. Got a real cool picture. We tried to get one of the passes with the numbers showing but the button wasn't pushed on this pass.
Old Oct 29, 2012, 10:27 AM
decones is offline
Find More Posts by decones
making my own planes...
decones's Avatar
Curitiba - Brazil
Joined Oct 2007
1115/2.5D
I have here the 1115/2D - 2600kv to run it on 5S,
will start with 4.7x4.7
let's see
decones is offline Find More Posts by decones
Old Oct 29, 2012, 12:22 PM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
235 mph on 5s, the Viper must be really fast
was that with a dive and tailwind?
sebbe is offline Find More Posts by sebbe
Old Oct 29, 2012, 01:23 PM
Joined Apr 2012
Yes. Not sure of how much tailwind but probably 5-10. not sure. The same pattern I drew up on the other thread was the same way I flew. I go full power, 45, half roll, pull a big half circle to bleed as little airspeed as possible and then go flat and level. Probably flat and level for about 200 yards out before it passes by the radar gun. This is a max speed run. I dont think I have anymore speed to get than that on 5S. Other passes were clocked at 225 and 226. The 235mph was right off a fresh battery.
Old Dec 10, 2012, 06:28 PM
decones is offline
decones's Avatar
Curitiba - Brazil
Joined Oct 2007
Does anybody face hard work when balancing those sets of prop+spinner?
It's so hard to get all these things running smoth, I spent some money buying a bunch of sets and still couldn't find anything that deserve my wow :-(
B plan- anyone flying small carbon foldings? GM ones?
André
Old Dec 10, 2012, 08:01 PM
KRProton is offline
Find More Posts by KRProton
Tim Lampe; Hobbico R&D
KRProton's Avatar
Champaign, IL
Joined Dec 2009
I'm flying my Viper F5D style. 5S, Neu 1115/2.5D, APC 5.25 x 6.25.
Probably nobody will tell you NOT to balance props, but I don't balance mine and never have. I do notice some props run smoother than others - sometimes I get a really "sweet" one and you can tell, but even ones that aren't that great are just fine and don't raise my eyebrow.
Got 110 I think logged fligts on the plane and motor now. Still going strong.
Tim
KRProton is offline Find More Posts by KRProton
Old Dec 11, 2012, 04:10 AM
GregG is offline
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Originally Posted by KRProton View Post
I'm flying my Viper F5D style. 5S, Neu 1115/2.5D, APC 5.25 x 6.25.......
What speeds are you getting with this prop Tim?
Old Dec 11, 2012, 04:18 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Greg, I think this was metioned before, like a bit over over 200mph..
Old Dec 20, 2012, 11:50 AM
SniperWj is offline
Find More Posts by SniperWj
The Sarawak KoloMee
SniperWj's Avatar
Singapore
merry xmas guys!
amazine to see familair nick still flooting around this thread! after i gone for so long time!
wish you guys fly fast, land safe and slow!
yiming
SniperWj is offline Find More Posts by SniperWj
Old Dec 29, 2012, 09:34 PM
LVSloper is offline
Find More Posts by LVSloper
LVSloper's Avatar
Las Vegas
Joined Mar 2009
neu motor numbers?
I just dropped in my replacement motor from Neu, 1115/1y/3.2. The amps are down 13-15 and the watts are down 350 from the old motor. What could be the reason behind the drop and how is this going to affect the Vipers performance?
LVSloper is offline Find More Posts by LVSloper
Old Dec 30, 2012, 01:17 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Was it a 1115/1Y you had in it before also? If so, I can tell you I have a 1115/1Y which is too "hot" because of a loose shaft. It will be sent back for repair soon. I expect a drop in amps like yours, but can compensate with a bigger prop if the performance is not satisfactory.
Arcteryxxx is offline Find More Posts by Arcteryxxx
New Product New Build thread for Viper F5D Model Rob AR High Performance 20 Sep 08, 2009 03:06 AM
Discussion new pylon model - Viper F5D 2009 MarkChinery High Performance 2 Mar 11, 2009 01:46 PM
