Old Oct 13, 2012, 11:29 AM
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, FL, Daytona Beach
Joined Aug 2010
Originally Posted by smoothflying View Post
Need some advice fellas. Here is some of my data from 4S and 5S. These are maxes on 4.75*4.75 prop. Is this bad or good. Looks like 5S is not good.
4S
1400 Watts
81 amps
5S
2200 Watts
122 amps
270 degrees
Those 5S numbers have to be static for sure,when the plane is in the air unloaded,the numbers come way down.All my numbers with the same setup were safe,but i did want to try a few other props,but did not get the chance....
VooDoo Child is offline Find More Posts by VooDoo Child
Old Oct 13, 2012, 11:57 AM
Joined Aug 2010
What does have me scratching my head is that 270 deg temp,did you hold the plane in your hand and run it for a long time ?
Old Oct 13, 2012, 01:00 PM
sebbe's Avatar
Sweden
Joined Feb 2006
275???? MAN, poor motor.... I hope you did not run it for long that way.....
sebbe is online now Find More Posts by sebbe
Old Oct 13, 2012, 01:12 PM
Joined Apr 2012
All these numbers are in the air flying. I did push it a little hard on the 5S. It is definitely a lot faster on 5S then 4S. Real hazy day and had an extremely hard time seeing it when it entered level flight to the field about 600ft away. I pulled out of throttle but still got a glide speed passing the radar gun at 211mph.
smoothflying is offline Find More Posts by smoothflying
Old Oct 13, 2012, 01:24 PM
sebbe's Avatar
Sweden
Joined Feb 2006
that Viper must be fast, 211mph with the throttle released before..
Old Oct 13, 2012, 01:41 PM
Joined Aug 2010
I am thinking he is talking about the ESC temp,the Neu 1115/1Y runs very cool due to the openings in the front of the motor case,at least mine did (much cooler then the Mega,but the Mega had much cooler temps on the esc and lipo,as my Neu had more temps on the esc and lipo).But those numbers are silly,i am thinking there could be a wrong pole count or Kv entered in the logging.
Old Oct 13, 2012, 01:44 PM
Joined Aug 2010
Where did you get "THE WAVE SMILIES" ? They are cool
Old Oct 13, 2012, 02:32 PM
sebbe's Avatar
Sweden
Joined Feb 2006
klick on them, then rightklick and save target as.....
and you have them,,, dont know where I got them, hehe..
Old Oct 13, 2012, 03:01 PM
Joined Aug 2010
DONE ! Now i have to find a post to use them
Old Oct 13, 2012, 03:52 PM
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Which is the winner for F5D???
Door number 1 or door number 2?
5S
1115/1Y with a 4.75x4.75
1115/2.5D with a 5.25x6.25
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Oct 13, 2012, 04:55 PM
Joined Aug 2010
5S
Depends on how long you want to run your plane WOT.Now i can not comment on the 2.5D,but i sure can on the 1Y.I had the 1Y w/4.75X4.75 apc w/TP 2700mah 5S,and it was fast,but it could not do a 60 second WOT run,the packs were blistering hot,even killed one of them.....so smaller prop,or shorter runs on the 1Y.....On a side note,if i did 5 15sec pulls on the 1Y,the ESC took the brunt of the hit....a bit of a catch 22.But like i said,IT WAS FAST
Old Oct 13, 2012, 04:58 PM
Joined Aug 2010
For inrunners,i for one will stick with Mega,they have such an insane amount of choices to tailor to ANY need for sport F5D.....and for some cool reason,they like to take the heat,and take the pressure of the ESC and lipo in high speed setups.
Old Oct 13, 2012, 05:09 PM
You down with EPP?
Houston, Tx
Joined May 2009
I am debating on trying my Mega 16/40/1.5rc 2370kv on 6S when I get my Swist.
For now I am going to put it in a buddy of mines Viper. Now that the cooler weather is rolling in, we are going to give that Mega a go on 5S with the APC 5.25x6.25. Should be plenty fast.
Old Oct 13, 2012, 05:24 PM
Joined Aug 2010
Now that is a KILLER setup.I say 2500Kv is perfect for using an APC 4.74X4.75 on 5S,and 2370 would work the same on 6S with a bit more ummmmmmf if you do not want to mess with props (but 2500KV on 6S with cut 4.75X5.5 is the shizzy) ....Now i am taliking 60sec full on runs....I have givin up on pushing stuff to it's bear limits,and if i can not fly it for 60sec WOT,it's not an F5D wanna-b plane But that is just me.
Old Oct 13, 2012, 07:43 PM
You down with EPP?
Houston, Tx
Joined May 2009
I like about 40 seconds on the jazz with 20 second breaks. So we will see......
New Product New Build thread for Viper F5D Model Rob AR High Performance 20 Sep 08, 2009 03:06 AM
Discussion new pylon model - Viper F5D 2009 MarkChinery High Performance 2 Mar 11, 2009 01:46 PM
