This is Huge!!!!!
Battery came in today. Not only does it fit in the Viper, It fits with ease, no squeezing!!! The actual dimensions are 100x33x38mm. Unbelievable.
This pack is 5S 2250mah 50C Let's hope it performs!! Here is the scoop.... Maxamps.com. You pick the cells and mah pack and they build it for you. The cool thing is, you can tell them where you want your battery leads exiting from. If you look at the pics, you can see that I had the leads coming out of the top of the pack. This allows me to shorten the wires, plug in the pack and place the battery in the fuse without any wires on the side. Note: When you have the pack built you can make these modifications as well as select what kind of plugs and balance taps. As seen in the pics, I chose no plugs, because I know I am going to cut them short. The weather here is crap, but I will report how the packs handles |
Running 5.25 x 6.25 (posted a few times in thread my complete setup). I've only run the prop mentioned. I have read somewhere earlier in this thread that, for reduced speeds you could prop down, but I forgt the size. Maybe 5.0 x 5.0? Tim |
| Thread Tools | |
| New Product New Build thread for Viper F5D Model | Rob AR | High Performance | 20 | Sep 08, 2009 03:06 AM |
| Discussion new pylon model - Viper F5D 2009 | MarkChinery | High Performance | 2 | Mar 11, 2009 01:46 PM |
