Old Sep 03, 2012, 09:27 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Originally Posted by KRProton View Post
I bet your Viper was going faster than it looked - that's how it is for me at least even on 5S (until you get a pass right down on the deck aligned with the centerline of the runway right in front of your self!).
If it can take a 5.25 x 6.25 on 5S don't see why it couldn't take a larger prop on 4S. On 5S I get about 95A - 100A static, so I guess that should be a safe number to shoot for on 4S.
Don't know what the max temp should be. 150?
Tim
I was thinking around 150 degrees. I will shoot for 95a.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Sep 09, 2012, 01:36 AM
You down with EPP?
Houston, Tx
Joined May 2009
Anyone using this in a Viper?
http://www.maxamps.com/Lipo-2250-185-Flight-Pack.htm
I am on the hunt for a single 5s battery that will fit and deliver some good amps. This looks like it might be the one....
Old Sep 24, 2012, 08:23 PM
You down with EPP?
Houston, Tx
Joined May 2009
Will this fit?
I have made up a mock pack, but it's hard to tell...
I am having a custom 5s pack made at 99x40x34mm.
The pic show how it will go in the Viper, with the battery leads exiting the top running towards the ESC. Does look like it will work?
2200mah pack
Old Sep 26, 2012, 10:28 AM
smoothflying is offline
Find More Posts by smoothflying
Joined Apr 2012
2200mah pack
Are u making it ursrelf or someone else. I'm interested if it fits perfect.
smoothflying is offline Find More Posts by smoothflying
Old Sep 26, 2012, 10:47 AM
You down with EPP?
Houston, Tx
Joined May 2009
I'll let you know in about 5 days. I ordered it yesterday. It is the same dimensions of a Hyperion 5S 2200mah 35C. Actually this one is about 1/2mm smaller on width and height, and shorter by about 6mm in length. The C-Rating is supposed to be a true 60C.
question is, how do I secure it??? if it does fit it will be do it by fractions of a mm. (no room for velcro)
Old Sep 26, 2012, 10:53 AM
Joined Apr 2012
I would think the Velcro would squish a little. Might be something to try when u get it. How much was it??
Old Sep 26, 2012, 11:26 AM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
This might sound strange,but trust me on this one....If I use Velcro on the bottom of the fuselage and lipo,my wing does not fit so good,but when I tried putting a piece on the bottom of the wing,and top of lipo the wing fits on no problem.I use a 1"x1" piece in line with the wing bolts .
VooDoo Child is offline Find More Posts by VooDoo Child
Old Sep 26, 2012, 12:38 PM
You down with EPP?
Houston, Tx
Joined May 2009
Cool, I will try that. I know it is going to be really close. All I need to do is get it in once. I plan on leaving it in the fuse.
I am still bitter at SUSA for selling me this with cinfidence that the TP 5S 2250mah 65C pack would fit. I would have bought a Jolt if I had known it was going t obe such a pain.
Old Sep 26, 2012, 08:42 PM
plainguy is offline
Find More Posts by plainguy
Take off, eh
plainguy's Avatar
USA, CA, Long Beach
Joined Jan 2009
F5B guys would tape across the battery grabbing on to edge of plane fuse and cross over battery. It won't budge. they use thin Kapton tape.
good luck!
plainguy is offline Find More Posts by plainguy
Old Sep 26, 2012, 10:42 PM
AEMontoya is online now
Find More Posts by AEMontoya
AEM
AEMontoya's Avatar
Bay Area, CA
Joined Sep 2009
Securing with the velcro under the wing should work, but be sure the pack is held real well. When you grip the fuse for launch, it tends to cause the bottom of the fuse, below the battery, to pull down, leaving the battery more or less hanging from its velcro attachment under the wing. This could be asking for trouble if the securing isn't really good. I had one instance where I had this type of setup with my Viper and the battery slipped back during the throw. It not only caused the COG to be way off, but the sliding battery ripped one of the aileron wires out completely from the wing wire harness. I happened to throw it off a sloped cliff, and luckily had enough time to circle it around and land it without incident.
If the pack is pretty wide, and barely fits through the saddle, then there's the chance that when the battery is pushed all the way down onto the bottom of the fuse, there's a gap between the bottom of the battery and the bottom of the fuse due to the curvature of the fuse. In this case, some thinner style velcro may be able to be used within this gap, and you wouldn't have to worry about the above scenario so much.
AEMontoya is online now Find More Posts by AEMontoya
Old Sep 27, 2012, 07:01 AM
You down with EPP?
Houston, Tx
Joined May 2009
Im liking the kapton tape idea. Hopefully that will work.
Old Sep 27, 2012, 07:13 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
I usually do mine with no velcro. Make a blocking system to keep the battery from moving fore/aft. One block in front the other in back. I use triangular chuncks of foam in front and back to cushion the pack and gently squeeze it in between the blocks.
GregG is offline Find More Posts by GregG
Old Sep 27, 2012, 10:42 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
How secure the blocks against fuse?
sebbe is offline Find More Posts by sebbe
Old Sep 28, 2012, 07:51 AM
GregG is offline
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
I run a couple of screws into the block from the underside of the fuse then use small pieces of foam block as a cushion front and back. The battery is slightly wedged in holding it securely.
The CG can be changed by changing the sizes of the foam blocks front and rear.
Old Sep 28, 2012, 10:48 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
ok, always nice to get new ideas..
New Product New Build thread for Viper F5D Model Rob AR High Performance 20 Sep 08, 2009 03:06 AM
Discussion new pylon model - Viper F5D 2009 MarkChinery High Performance 2 Mar 11, 2009 01:46 PM
