Old Jan 06, 2010, 01:44 AM
jsnaphook is offline
Find More Posts by jsnaphook
Why you swing so hard?
jsnaphook's Avatar
Lake Tahoe
Joined Jun 2006
Originally Posted by la528it View Post
epc2: the gearbox and motor fit... PERFECTLY! The cc80 is longer than the ice 100 lite, so I went with the former. The caps go to about 5mm in front of the wing saddle, the lipo can sneak a tiny bit ahead of the saddle. Because the ice 100 is so thin, I stuff both a 450mah 2s pack and cc bec up there for rx supply, but I worry that rx lipo and bec are in potentially the hottest part of the plane.... what do y'all think?
If your ICE melts, can or will it take out your rx power supply being in close proximity?
Juan
jsnaphook is offline Find More Posts by jsnaphook
Old Jan 06, 2010, 03:25 PM
epwierman is offline
Find More Posts by epwierman
epwierman's Avatar
Joined Aug 2004
Richard,
I had a motor mount let go once, and the motor / esc / receiver pack where all up front. :-( The receiver batt twisted around and connection was lost.
So, if this is your only option for fit, prefilght that nose regularly and check the temps real good initially to ensure nothing is going to cook. And maybe consider wrapping the crap out of the esc with kapton to minimize fire damage in the unlikely event of that scenario.
See ya tomorrow!
Eric
epwierman is offline Find More Posts by epwierman
Old Jan 06, 2010, 03:57 PM
carpetbomb is offline
Find More Posts by carpetbomb
finger slicer
carpetbomb's Avatar
Southern CA.
Joined Mar 2009
Originally Posted by epwierman View Post
Richard,
See ya tomorrow!
Eric
Remember to get lots of video for us drones that have to work for a living.
mike
carpetbomb is offline Find More Posts by carpetbomb
Old Jan 08, 2010, 10:30 AM
jjmouris is online now
Find More Posts by jjmouris
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
I'd say don't do it but if, then don't wrap the ESC to much as this will only give it less cooling and send it up in smoke guaranteed.
Better put a lot of layers of Kapton around that RX pack, use way overkill wires and tape those as well.
jjmouris is online now Find More Posts by jjmouris
Old Jan 14, 2010, 06:21 PM
r/cmark is offline
Find More Posts by r/cmark
200 mph club
r/cmark's Avatar
United States, AZ, Fort Mohave
Joined Mar 2005
Viper for sale in 'Aircraft - Sailplanes (FS/W)'
Sold!
r/cmark is offline Find More Posts by r/cmark
Old Jan 15, 2010, 03:03 AM
MarkChinery is offline
Find More Posts by MarkChinery
Speed King
MarkChinery's Avatar
London Heathrow, Great Britain (UK)
Joined Feb 2003
for sale already, thats a bit quick.
MarkChinery is offline Find More Posts by MarkChinery
Old Jan 15, 2010, 08:32 AM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, UT, Salt Lake City
Joined Dec 2007
so's the plane :P
la528it is offline Find More Posts by la528it
Old Jan 15, 2010, 08:51 AM
FASTBEN is offline
Find More Posts by FASTBEN
Cumulus Altimus
FASTBEN's Avatar
United States, TX, Keller
Joined Feb 2002
so's the plane :P
lol.....
FASTBEN is offline Find More Posts by FASTBEN
Old Jan 28, 2010, 10:33 PM
plainguy is offline
Find More Posts by plainguy
Take off, eh
plainguy's Avatar
USA, CA, Long Beach
Joined Jan 2009
viper burnt power train
Flew my Viper for all of 30 seconds sounded great, cut some beautiful lines -until it shut down.
motor and or esc smell burnt.
Set up
Neu 1112 1Y motor
CC 80 phoenix ESC
430 mAh 2S lipo receiver pack with BEC
Hyperion 4S 45C Battery
4.1 x 4.1 prop.
fuse -no cooling / vent holes
can't be certain what happened until i take it all apart but in the meantime wanted to know if anyone has had a similar situation.
thanks,
plainguy is offline Find More Posts by plainguy
Old Jan 28, 2010, 11:48 PM
la528it is offline
la528it's Avatar
Joined Dec 2007
Set up
Neu 1112 1Y motor
CC 80 phoenix ESC
4.1 x 4.1 prop.
thanks,
Raul did you program the esc? Was the battery hot when you landed? Was the esc hot? The motor?
Old Jan 29, 2010, 12:24 AM
plainguy is offline
Take off, eh
plainguy's Avatar
USA, CA, Long Beach
Joined Jan 2009
yup. all programed and pretty. flew to trim yesterday on 3S everything hunky dori.
will remove motor & esc tomorrow for inspection and (hopeful) resolution.
thanks for caring...
Old Jan 29, 2010, 12:25 AM
Thekid3418 is offline
Find More Posts by Thekid3418
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
900-1000 watts is borderline for an 1112 motor with no cooling. For instance, my motor (1112-2D) under testing conditions with no cooling air, got uncomfortably warm to the touch after 50sec at ~65amps. In the air, with lots of cooling, it never gets above ambient, but without cooling is another story.
I would suggest testing the kv of your motor to see if you over-heated it, and testing the ESC to make sure it still functions. If they both work, cut some small cooling holes and try again! That motor should handle your power level easily, but it needs a little help
Kid
Thekid3418 is offline Find More Posts by Thekid3418
Old Jan 29, 2010, 08:13 PM
plainguy is offline
Take off, eh
plainguy's Avatar
USA, CA, Long Beach
Joined Jan 2009
thanks for the info kid.
took apart & found Neu motor yellow wire charred all the way into the motor. maybe problem caused by improper yellow wrap insulation causing arch (?)
Old Jan 29, 2010, 10:36 PM
sbritton is offline
Find More Posts by sbritton
sbritton's Avatar
USA, CA, El Dorado Hills
Joined Apr 2008
I had the same issue with a 1110-1Y. I was really surprised...but the motor was a complete loss. I got a lot of flights out of it, so figured I got my money's worth.
sbritton is offline Find More Posts by sbritton
Old Feb 02, 2010, 08:45 AM
FASTBEN is offline
Cumulus Altimus
FASTBEN's Avatar
Joined Feb 2002
well little problem...after soldering the cc125 to the motor the length is about an inch to long and won't permit the battery to slip in,,,my battery came to wide to lay flat but can stand perfect....now the Question is how far can i cut the motor wire's back will it be solder-able.....the motor wire's are soldered to ESC directly i have removed the 3 motor wire's from esc and soldered direct to it..i need an 1" to make good.
ben
New Product New Build thread for Viper F5D Model Rob AR High Performance 20 Sep 08, 2009 03:06 AM
Discussion new pylon model - Viper F5D 2009 MarkChinery High Performance 2 Mar 11, 2009 01:46 PM
