Old Oct 06, 2009, 10:12 PM
guitaramp68 is offline
Find More Posts by guitaramp68
guitarflyer
Joined Feb 2009
im gonna try ask the edf guys
is 4.8v enought to run my rx and servos.i want to run a batt instead of bec.
or should i go 6v.im run typical 64 to 70 mm edfs.
thanx anthony
guitaramp68 is offline Find More Posts by guitaramp68
Old Oct 06, 2009, 10:36 PM
AceMigKiller is offline
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
6v is almost always better, but I do run some 4.8v packs on low-draw setups (6 servos or less).
You'll be A-Okay with 4.8v, gas guys running higher servo loads did it for years! lol
Vic
AceMigKiller is offline Find More Posts by AceMigKiller
Old Oct 06, 2009, 10:41 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
4.8v is plenty, for standard servos. If you're running digis or high torques, then 6v is better
Xpress.. is offline Find More Posts by Xpress..
Old Oct 06, 2009, 10:46 PM
The Don is online now
Find More Posts by The Don
MA Indoor FreeFlight Columnist
Willoughby, Ohio
Joined Jan 2002
If you run 6V just make sure the servos you have will run on 6 volts.
The Don is online now Find More Posts by The Don
Old Oct 06, 2009, 10:53 PM
guitarflyer
Joined Feb 2009
thanx alot guys im planning on running 4 triple a or u you go 4 double a's
Old Oct 06, 2009, 11:32 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
^No, run rechargables. MUCH better. For 4 AA's, a 5 cell NiMH will replace them.
Old Oct 07, 2009, 12:30 AM
guitarflyer
Joined Feb 2009
of cource rechargeable but could i get away with triple a nimh.i think they are 650 mah
Gonna try 9 cells in my Bandit with Hacker B40 8S ferradas Electric Sailplanes 5 May 15, 2003 09:47 PM
Gonna try this.With a question dirtdiver Foamies (Kits) 0 Oct 20, 2002 05:16 PM
Plane designed to try out GWS EDF 50 iamDerrick Parkflyers 1 May 05, 2002 12:20 PM
OK - gonna try the Cox Viper one more time.... Steve McBride Foamies (Kits) 74 Jul 13, 2001 06:21 PM
Gonna try Lil Hornet (battery question) kenny_dilger Parkflyers 9 Jun 01, 2001 11:33 PM
