Go Back   RC Groups > Aircraft - Exotic and Special Interest > Ornithopters
Old Oct 12, 2009, 09:40 AM   #16
K Kakuta
Kazu-kaku's Avatar
Tupuxuara 7-9 Fight & Gliding With New Programed GLDAB
GLDAB worked well, so, Tupuxuara 7-9 was gliding.
Tupuxuara 7-9 Fight & Gliding With New Programmed GLDAB (5 min 10 sec)
Kazu-kaku is offline Find More Posts by Kazu-kaku   Reply With Quote
Old Oct 18, 2009, 08:59 AM   #17
K Kakuta
Kazu-kaku's Avatar
Flight with New programmed GLDAB
New programmed GLDAB was set in Kestrael F6, Chaoyangopterus8-8, Tupuxuara7-9.
New programmed GLDAB worked well.
New Programmed GLDAB for Gliding of Ornithopter. (2 min 31 sec)
Old Oct 18, 2009, 05:07 PM   #18
G-LO's Avatar
Kazu that was truly inspirering.The new glidelock is quick! Will you apply it on your slow hawk and Falcon-F5? If so, I will like to see their performance. G-lo
G-LO is offline Find More Posts by G-LO   Reply With Quote
Old Oct 18, 2009, 06:30 PM   #19
K Kakuta
Kazu-kaku's Avatar
New GLDAB acted in FalconF5 well equally.
SlowHawk2 needs adjustment in order to fly. Now I am preparing it.
Old Oct 21, 2009, 08:12 AM   #20
K Kakuta
Kazu-kaku's Avatar
New programmed GLDAB was set on Cybird P2.
GLDAB works well.
I will flight this Cybird soon.
New GLDAB for Gliding of Ornithopter on Cybird P2 (3 min 24 sec)
  • Name: 091021-NewGLDAB-on-Cybird-2.jpg
Old Oct 25, 2009, 08:20 AM   #21
K Kakuta
Kazu-kaku's Avatar
New GLDAB for Gliding of Ornithopter on SlowHawk2
New GLDAB for Gliding of Ornithopter on SlowHawk2.
New GLDAB works well.
New GLDAB for Gliding of Ornithopter on SlowHawk2 (2 min 31 sec)
Old Oct 25, 2009, 02:12 PM   #22
G-LO's Avatar
Mr.Kazu the glide rate is good on the slow hawk as well!
I like the the effortlesness and the naturalness of the glide.
Will you apply the the glide madual to your new slow hawk? What color is your new slow hawk Mr.Kazu?
G-lo
Old Oct 25, 2009, 04:07 PM   #23
Kazu, that green fabric really looks good. You can actually get a better glide if you lower the dihedral. If you drill and tap a new hole on the main gear for the ratchet pin just to the side of the current one I think you will see.
Kinkade is offline Find More Posts by Kinkade   Reply With Quote
Old Oct 25, 2009, 04:09 PM   #24
Bring your wing lock dihedral down to just a few degrees above the horizontal.
Old Oct 26, 2009, 01:49 AM   #25
K Kakuta
Kazu-kaku's Avatar
Dear Kinkade
Thank you. I lowered a fixed position of wings.
A postscript: Red SlowHawk3 arrived. Thank you. But, 2 years and six month were long.
I looked at your new gear system and Glide Lock system.
Your idea is splendid. But,the operation of your Glide Lock system is complicated.
I point out problems of this SlowHawk3 package.
1) There is not an operating manual of SlowHawk3.
2) A carbon plate for installation of the main wing does not fit a carbon plate of the body. It is hard that a beginner corrects this.
3) The right and the left gear were installed incorrectly. A right gear was installed to the left. A left gear was installed to the right. Therefore Glide Lock system did not act.
4) Specifications of ESC and Motor are not explained.
In a state of this package, beginner cannot assemble Slowhawk3.
Please improve it.
Old Nov 02, 2009, 08:32 PM   #26
G-LO's Avatar
Mr.Kazu I was wondering,will you ever apply the the stainless steel gear on one of your slow hawks? Of so what is the weight for the steel gear for the slow hawk?
G-Lo thanks
Old Nov 03, 2009, 09:24 AM   #27
K Kakuta
Kazu-kaku's Avatar
G-Lo thanks
I use stainless steel gear in Bueo F4, Falcon F5 and Kestrel F6.
I do not use stainless steel gear in SlowHawk.
20-30g increase weight when stainless steel gear was used.
Old Nov 08, 2009, 06:03 AM   #28
K Kakuta
Kazu-kaku's Avatar
Flight of Cybird P2 with New GLDAB for Gliding of Ornithopter
I set New GLDAB on Cybird P2.
New GLDAB act well.
Flight of Cybird P2 with New GLDAB for Gliding of Ornithopter (3 min 0 sec)
Old Nov 20, 2009, 11:11 AM   #29
FrancisG's Avatar
Originally Posted by FrancisG View Post
Thanks, Kazu! I will try your new program (but in a month, I'm very buzy now )
Kazu,
Your program works well on my brushed motors . Precedently, I used the 1.3 version from Alain Bizot himself (tempo=0s), but it was necessary to add a 10 Kohms from +5v to pin 6, your version is more simple for the same result.
FrancisG is offline Find More Posts by FrancisG   Reply With Quote
Old Yesterday, 02:09 AM   #30
K Kakuta
Kazu-kaku's Avatar
Kazu,
Hi, FrancisG
Thank you for a report of a good result.
GLDAB is a best device for gliding at present.
I wish for a good flight of your ornithopter.
New blood for soaring ..."via a structured program" GordySoar@aol.com RCSE 0 Sep 26, 2007 06:14 PM
You can download my new program for FREE. Majosoft uk.rec.models.engineering 0 Apr 06, 2005 01:11 AM
New Forum for Parkflyers? Allan Wright Electric Plane Talk 7 Aug 06, 2001 01:28 AM
New modells for fms Looooeeee! Electric Plane Talk 1 Aug 05, 2001 01:31 AM
New shaft for Aveox 1114/4Y? byoung Electric Plane Talk 8 Jun 08, 2001 07:59 PM
Bored? Want to fight?
Join the RCGroups clan!
