Old Oct 06, 2009, 07:17 PM
tdflyer16 is offline
Find More Posts by tdflyer16
Joined Apr 2009
Question
Ideas on removing tape/ sticker residue from a fuselage?
ok, two things.
First, I just got a used supra which had an experimental aircraft sticker on the bottom of the fuse. I pulled the sticker off, but now there is a big sticky spot on the bottom of my fuselage which is attracting all kinds of pet hair etc.
Second, I have a Topaz which i needed to ballast during a contest. Having no ballast tube i used sticky-back lead weights. After the contest I removed the weights and i got most of the backing off, but there are still a few spots where the adhesive backed foam is not coming off.
Any ideas on how to clean up my planes is greatly appreciated
tdflyer16 is offline Find More Posts by tdflyer16
Old Oct 06, 2009, 07:27 PM
Lance Prior is offline
Find More Posts by Lance Prior
Salt Lake City, Utah
Joined Nov 2004
I use GooGone
http://www.magicamerican.com/googone/products.aspx
Lance Prior is offline Find More Posts by Lance Prior
Old Oct 06, 2009, 07:30 PM
JoeR is offline
Find More Posts by JoeR
USA, NY, Jamestown
Joined Jun 2000
If you have any rubbing alcohol around you might try that. The higher the isopropyl alcohol content the better it will work.
JoeR is offline Find More Posts by JoeR
Old Oct 06, 2009, 07:48 PM
Dennis Everett is offline
Find More Posts by Dennis Everett
Dennis Everett's Avatar
United States, CA, Ontario
Joined Mar 2002
The above work pretty good , if that doesnt work acetone works , but might also remove paint.......
Dennis Everett is offline Find More Posts by Dennis Everett
Old Oct 06, 2009, 07:52 PM
Ronald Mong is offline
Find More Posts by Ronald Mong
Joined Mar 2005
WD 40 , once adhesive is removed then I clean off WD with some
windex or equal .
Ronald Mong is offline Find More Posts by Ronald Mong
Old Oct 06, 2009, 09:50 PM
BrianSmith is offline
Find More Posts by BrianSmith
<>< AKA W4BPS
USA, TN, Tullahoma
Joined Dec 2001
cigarette lighter fluid
I keep a can of this on hand.. Nope I don't smoke.. .. I get it at Wal-Mart pretty cheap.. Brian
BrianSmith is offline Find More Posts by BrianSmith
Old Oct 06, 2009, 10:12 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
There is (or was) a commercial product from 3M that's like Goo Gone only much stronger. I forget the name.
A bit of heat followed by light abrasion or at least a rag might help.
lincoln is offline Find More Posts by lincoln
Old Oct 06, 2009, 10:13 PM
FrogChief is offline
Find More Posts by FrogChief
Russian Federation, Sakha, Yakutsk
Joined May 2006
Originally Posted by tdflyer16
ok, two things.
91% isopropyl rubbing alcohol. Works wonders! WAY better than goo-gone and cheap (under $2.00 at Walmart.) Just watch for any paint coming off with it (enamel only, laquer and epoxy paints are fine.)
If you get a bit of color on the rag hit the area with a bit of turtle wax!
* 91% Rubbing alcohol works great at getting covering residue off of covering as well. I use it for general cleaning of my wings after finishing a covering job. Doesn't hurt the film one bit.
** It's also a great glass cleaner, the best in fact. Way cheaper than windex.
FrogChief is offline Find More Posts by FrogChief
Reply With Quote  (Disabled)
Old Oct 06, 2009, 10:14 PM
georgeg is offline
Find More Posts by georgeg
United States, CA, Bakersfield
Joined Jan 2001
This (http://www.dtep.com/icky.htm) is the stuff I use. I've given bottles of it to some of my clubmates and they agree that it is the best stuff they've ever used to remove tape residue. I've poured it full strength on foam and it had no effect on the foam. It will leave a bit of an oily file after use but it can easily be removed with rubbing alcohol or if you wait overnight, it seems to evaporate. I think if you try it, you'll never use anything else again.
georgeg is offline Find More Posts by georgeg
Old Oct 06, 2009, 10:21 PM
Rich Burnoski is offline
Find More Posts by Rich Burnoski
Bolingbrook, Illinois
Joined Nov 2007
the best stuff?
cyno glue" kicker". The kicker( accelerater) works the best for me. When 99% of the gooey stuff is lifted, than use alcohol. RB
Rich Burnoski is offline Find More Posts by Rich Burnoski
Old Oct 07, 2009, 03:44 AM
DACH is offline
Find More Posts by DACH
DACH's Avatar
United Kingdom, England, Derby
Joined May 2003
I second the cigarette lighter fluid. I used to work in a graphics studio and that's what we used all the time to remove residue adhesive from sticky tape or labels. Doesn't damage painted surfaces either.
Dave.
DACH is offline Find More Posts by DACH
Old Oct 07, 2009, 07:30 AM
Curtis Suter is online now
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
I believe SuperGlue "Accelerator" works too.
Curtis
www.TailwindGliders.com
Curtis Suter is online now Find More Posts by Curtis Suter
Old Oct 07, 2009, 07:43 AM
Mark Miller is offline
Find More Posts by Mark Miller
Mark Miller's Avatar
United States, WI, Waunakee
Joined Oct 2002
Lighter fluid is Naptha. You can get it in quart and gallon cans at the local hardware or home improvement store. It is a great all around cleaner. I too worked in the printing industry and every I smell it I'm transported back. Much cheaper than the lighter fluid cans.
BTW...CA Accelerator contains Heptane, Acetone, N,N-Dialkyltoluidine. The N,N-Dialkyltoluidine is the accelerator. I think the Heptane would be a great solvent too as it is used as rubber cement solvent. Brings back memories of grade school.
Mark
Mark Miller is offline Find More Posts by Mark Miller
Old Nov 02, 2009, 08:41 PM
bob_goes_gas is offline
Find More Posts by bob_goes_gas
Somerset, Ohio
Joined Aug 2009
peanut butter works good as well, especially on smooth glassed surfaces etc.
the oil makes it ball up and come right off, no harsh chemicals and it even polishes the surface
bob_goes_gas is offline Find More Posts by bob_goes_gas
Old Nov 02, 2009, 10:26 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Mark
Naptha is, by far, 'THE BOMB' for cleaning off residues. Best part is, it doesn't evaporate too fast.
Wipe on with a slightly wet paper towel, let it sit for a minute, and the wipe again.
It works great.
Target
target is offline Find More Posts by target
Discussion removing a sticker from covering flying evader The Builders Workshop 5 Sep 15, 2007 05:15 PM
Discussion Any Tips on Removing Epoxy from Covering Film. jnm2512 Electric Plane Talk 5 Aug 28, 2006 12:32 AM
Removing fuel residue from outside of the motor blk96gt Engines 8 Aug 11, 2005 09:16 AM
Question Removing tape from LiPos? candy7man Batteries and Chargers 2 Mar 23, 2004 12:34 AM
Any ideas on how to eliminate rear wing flutter from a zaggy 400x modified ducatista Foamies (Kits) 8 Apr 18, 2002 07:31 PM
