Old Oct 06, 2009, 05:26 PM
RC REDHOTS is offline
Find More Posts by RC REDHOTS
NC
Joined Oct 2009
1/8" Lite Ply
Hello All
I an located in NC, Can anyone tell me of any possible places to get 4 x 8 sheets of 1/8 Lite Ply.
Thanks! RC Redhots
RC REDHOTS is offline Find More Posts by RC REDHOTS
Old Oct 06, 2009, 06:04 PM
coosbaylumber is offline
Find More Posts by coosbaylumber
Joined Jul 2005
Luan Plywood?
Not in that big of sizes for you locally. We have a few plywood only places near here. They go through 1/8 inch plywood like water. Hard to keep in stock due to it being used for concrete forms.
A 1/2 sheet maybe. but not a full sheet.
Wm.
coosbaylumber is offline Find More Posts by coosbaylumber
Old Oct 06, 2009, 07:37 PM
cwesh is offline
Find More Posts by cwesh
I post, thread dies!
Georgetown, Texas, United States
Joined Feb 2003
If you are somewhat close to Peachtree City in Georgia (Atlanta), Aircraft Spruce carries it in 4x8 sheets, 3mm and 6mm. That is their east coast store.
Link: http://www.aircraftspruce.com/catalo...es/liteply.php
Later!
cwesh is offline Find More Posts by cwesh
Old Oct 06, 2009, 07:59 PM
Chad Veich is offline
Find More Posts by Chad Veich
Scale Builder
United States, AZ, Litchfield Park
Joined Jul 2002
Almost any supplyer of hardwoods will have it. Look for 3-ply Italian Poplar, sometimes called "bender ply" as well.
Chad Veich
Chad Veich is offline Find More Posts by Chad Veich
Old Oct 07, 2009, 03:50 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Be aware that at least in Europe, for some reason liteply is nearly always 3mm, not 1/8".
Its made of poplar, and its main use is in mobile homes and caravans apparently. Because its just stiff enough, and light (and cheaper than birch IIRC).
I've pretty much given up using it. the quality we could get was poor. thinner birch plus balsa is as stiff light and strong, usually.
Old Oct 07, 2009, 10:12 AM
Scale Builder
Joined Jul 2002
It is also actually 3mm over here as well vintage1. I use it extensively because it is cheaper than balsa, laser cuts about ten times better, and the quality is generally very good. The laser makes it very easy to cut lightening holes in the stuff so that the end result is not much heavier, if any, than balsa. It does have a propensity for warping so I have to keep it stacked and weighted until I'm ready to cut.
Old Oct 07, 2009, 03:35 PM
NC
Joined Oct 2009
Thanks Guys
I did run across the popular ply , but I wasn't sure if I wanted to use it or not.
Most of of the places that I found the lite ply need to ship it by way of truck (4 x 8) , and I didn't want to pay truck freight.
Has any of you used the popular ply?
I have scaled up a HOTS and the wing span is 10' 1 I hope a G 62 will pull it.
All my cad drawings are done for 1/8 and I may have to make some changes.
Any feed back welcome!
Thanks RC REDHOTS
Old Oct 07, 2009, 08:46 PM
Scale Builder
Joined Jul 2002
RC REDHOTS,
The light plywood normally associated with the hobby is Poplar, they are the same stuff. Regarding your CAD drawings, I have found that I need to allow for .1125" rather than .125" when designing with the light ply if you want a relatively snug fit on laser cut parts.
Old Oct 07, 2009, 09:22 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Go to Lowes or Home Depot and in the building supply department where they have plywood and materials like bathroom wall sheeting etc. They have door panels made from thin plywood. Might be useful to you. I use it in my planes all the time.
hoppy is offline Find More Posts by hoppy
Old Oct 07, 2009, 09:24 PM
Curare is offline
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
It may be ply, but it ain't lite!
Curare is offline Find More Posts by Curare
Old Oct 08, 2009, 07:25 PM
Meyer56013 is offline
Find More Posts by Meyer56013
Meyer56013's Avatar
Blue Earth, MN
Joined Nov 2005
I've bought it at both Hobby Lobby craft stores and Michael's
GARY
Meyer56013 is offline Find More Posts by Meyer56013
Old Oct 09, 2009, 12:53 AM
T_om is online now
Find More Posts by T_om
The Junk Man
Jacksonville, Florida
Joined Jul 2006
Actually, it is. The product he is referring to is commonly called "door skins", very light ply.
Tom
T_om is online now Find More Posts by T_om
Old Oct 09, 2009, 10:09 AM
Scale Builder
Joined Jul 2002
Door skins and/or Luan plywood are suitable for some modeling applications but are not near the same quality as Italian Poplar plywood in my opinion. Also, the light ply found at the hobby shop or craft store is Poplar. The difference is, at the hobby shop you will pay nearly as much for a 12"x48" piece as you will pay for an entire 4' x 8' sheet at the lumber supply houses. Of course if all you need is a little 6"x12" piece then the hobby/craft stores may be the better option!
Old Oct 09, 2009, 11:33 AM
T_om is online now
The Junk Man
Joined Jul 2006
Quite right. Which is why it costs 1/10th as much. It is, however, suitable for a lot of applications where aircraft-grade liteply is used. Especially for formers and doublers that are not seen.
Tom
Old Oct 14, 2009, 09:47 AM
zx32tt is offline
Find More Posts by zx32tt
United States, NC, Locust
Joined Jul 2001
There is a plywood importer in Mooresville NC that has Italian poplar lite ply and other plywood. It was about $17 for a 4x8 sheet some yrs ago. Door skins of birch or luan are much heavier.
zx32tt
zx32tt is offline Find More Posts by zx32tt
Question Where can I get 1/8" ply Control Horns in Bulk? RCSuperPowers Vendor Talk 4 Feb 22, 2007 07:00 PM
Pictures of my new Omega 1.8 !!! jshelton Electric Sailplanes 17 Aug 20, 2002 11:29 PM
Omega 1.8 for sale Speedfreak Aircraft - Electric - Airplanes (FS/W) 2 Nov 16, 2001 08:24 AM
Omega 1.8 E First Flights!!! jshelton Electric Sailplanes 6 Oct 29, 2001 05:39 PM
I need two 1/8"x3/8" bearings for my MM Reverse... Sean Electric Heli Talk 1 Jun 17, 2001 04:22 PM
