This thread is privately moderated by Howard Matos, who may elect to delete unwanted replies.
Old Oct 06, 2009, 01:01 PM
Howard Matos is offline
Find More Posts by Howard Matos
AR-15 BRD!
Howard Matos's Avatar
Frederick, MD
Joined May 2002
Careful!
Charging series-wired packs - be careful ! ! !
Charging two batteries wired in series using two separate chargers has the potential to cause irrepairable damage to either one or both chargers as well as damage to one or more batteries connected to the chargers. Of course it is physically possible (and easy) to connect the balance leads and/or discharge leads of two series-wired batteries to two separate chargers, but a common ground can occur at the power supply inputs to the chargers. The only safe way to do proceed is to use individual "isolated" power supplies; two separate 12v batteries for example to power each of the chargers independently. If you were to use two AC power supplies, you MUST confirm using a continuity meter, that the power supplies do not share common ground while connected to the house's AC supply. The problem is, MANY power supplies do share common DC ground as the power supply manufacturers connect DC ground to AC "earth" ground internally. Common DC ground flows through your home's AC lines. Now with common ground, when you connect the first wire of the second series pack to the charger, you have the potential for a direct short across the first series-wired pack (pack 1 ground to pack 1 +). The short will not occur until the charge FETs actually energize. Then "poof", the damage is done in microseconds. This is probably the number one way that people damage chargers in this industry, and not only FMA Direct chargers. Most of the time, customers have no idea what went wrong. The original Cellpro 4s charger has no protection or warning against this scenario because it has AUTO start. Charge FET closes as soon as valid voltages are present on the charger output. The manual clearly warns customers against this situation. Please check the CAUTION box on page 2 of the following link:
http://www.fmadirect.com/support_docs/item_1230.pdf
For a detailed pictorial diagram of the proper and improper ways to charge series-wired batteries, check the following link:
http://www.fmadirect.com/support_docs/item_1324.pdf
Incidentally, our newer Cellpro Multi4 is capable of determining this common ground scenario and will not energize the charger when the condition exists.
But the simplest solution is to never charger two packs wired in series using two separate chargers. Disconnect series-wired packs before connecting to the charger(s). If you only have one charger and you are determined not to wait to charge each pack individually, consider the potentially safer approach of charging packs in parallel using a single charger. If you are careful and you assure that both batteries are discharged to equal levels before connecting them together or to the charger, you can make up a simple "y" adapter using Cellpro battery pigtails for example, to parallel charge 2 packs using the Cellpro chargers. Each node of a pack must be connected to corresponding nodes of the other pack. The packs must be equal cell count and equal capacity. The charger will see the two parallel connected packs as a single pack. If one battery is charged and the other is discharged, you can run into problems because when you connect the two packs up to your wiring harness, the full pack will charge the dead pack at high current with no current limiting between the two. After a short time, the cell voltages will equalize, but in the mean time you will be putting high charge rate into the dead pack which is generally not good for the battery's life.
Howard Matos is offline Find More Posts by Howard Matos
Old Oct 06, 2009, 03:57 PM
uzzlimbird is offline
Find More Posts by uzzlimbird
Joined Jul 2009
Keeping a log
Outstanding information Howard. Every battery user should keep a log of useful information available and perhaps even a check list of dos and don'ts. Howard---Your post should be # 1. One should keep a log of every battery and remember to check their condition periodically. You would be amazed to see how rapidly time flies when you are having fun and you suddenly realize you have been flying a pack for three years! Add this one to your log too: Check your transmmitter battery or meter reading BEFORE each flight. Do you know when most flyers check it? You got it! Right after the crash to see if it went down!
uzzlimbird is offline Find More Posts by uzzlimbird
Old Jan 12, 2012, 10:05 AM
Dennis 9412 is offline
Find More Posts by Dennis 9412
Team Airtronics
Dennis 9412's Avatar
Washago, ON, Canada
Joined Oct 2002
Hi Howard:
I tried the links you posted above and neither of them point to the documents. Is there another link I can use, or is this sticky no longer valid?
I'm trying to charge 2 2 cell A123 packs wired in series through the Cellpro node plugs off of one Multi 4 charger. Can you provide me with a diagram to check that I am doing this properly?
Thank you
Regards,
Dennis
Dennis 9412 is offline Find More Posts by Dennis 9412
Old Jan 13, 2012, 01:06 AM
Tim Marks is offline
Find More Posts by Tim Marks
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
Originally Posted by Dennis 9412 View Post
Hi Howard:
Thank you
Regards,
Dennis
Hi:
The FMA Direct site was merged into www.revolectrix.com. Here are the correct links on the new website:
Cellpro 4s manual - http://revolectrix.com/support_docs/item_1230.pdf
Series Wiring Caution Sheet - http://revolectrix.com/support_docs/item_1295.pdf
But for your situation, you can refer to the following document to see the Cellpro batteries wiring conventions. You'll want to wire the 2 x 2s to make it look like a single 4s battery pack.
http://revolectrix.com/support_docs/item_1315.pdf
Tim Marks
Tim Marks is offline Find More Posts by Tim Marks
Old Jan 19, 2012, 03:45 AM
a1pcfixer is offline
Find More Posts by a1pcfixer
Counter agent of B.S.
United States, IN
Joined Aug 2003
Originally Posted by Tim Marks View Post
Hi:
Tim Marks
Does such series wiring info also apply to the CellPro 4S Gold?
a1pcfixer is offline Find More Posts by a1pcfixer
Old Jan 19, 2012, 11:13 AM
Tim Marks's Avatar
Joined Mar 2008
To my knowledge, it applies to all chargers.
Tim Marks
Question Simultaneously charging series packs with two chargers kkant Batteries and Chargers 4 Feb 25, 2009 12:01 PM
Discussion Charging series packs... tommyeflight89 Batteries and Chargers 4 Jun 03, 2007 07:47 PM
Charging large NIMH packs in series? R Hudson Batteries and Chargers 5 Oct 05, 2005 03:06 PM
Charging Large LiPoly Packs in Series? Brill 1 Batteries and Chargers 12 Apr 23, 2005 06:31 PM
Be careful with LiPo packs Joe Bennett Aerial Photography 15 Mar 12, 2004 07:07 AM
