Old Jan 11, 2013, 10:26 PM
Diesel6401 is offline
Find More Posts by Diesel6401
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
Originally Posted by kalmon View Post
I used .5oz cloth and glassed the bottom of the plane using polycrylic. This added almost no weight and probably added a couple mph in drag reduction. Not to mention belly landings have virtually zero wear on the bottom anymore.
As for a 4S speed setup, I think Gary at Efflux RC has a 4200kv "hot wind" motor that paired with a bigger ESC would provide more speed.
-Brian
Thanks for the post. What fan unit it is it a combo? Never ordered from their before.
Diesel6401 is offline Find More Posts by Diesel6401
Old Jan 11, 2013, 10:41 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Hi Diesel,
I saw that you were hoping to use your existing battery.
Before you consider a high (4200kv) powered 4s setup, please note that your gonna need a 4s, 30C (min) 4000 mAh pack. The 3200-3300 mAh Habu pack will not support the amp draw of any brand motor in the 4200-4400kv range.
You will also need a 100A ESC as it's gonna be about 1450W @ 95-100A. The Castle ESCs run comfortably at 100A, as the Burst current is 170A. I hear (but have no experience with) the Hobbywing platinum 100 has a 150A burst rate, so that might be a good choice as well.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Old Jan 11, 2013, 10:46 PM
jgalexander is offline
Find More Posts by jgalexander
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
Brian is right on with that kv for hot 4s action ( <-- sounds like LiPo po.rn!). The motor that efflux sells is one option, an ARC 28-47-1 with either a WemoMini or a HET 6904 fan is another, and the Hoffman Storm Hot Wind (HW) is another. Pete (hole digger on RCG) was selling them a few months ago for a discounted price, and the 28-47-1's show up from time to time on here. One thing to note, any ~4200kv motor on 4s is going to draw a TON of amps, usually somewhere around 100-125A. Your batteries will need to be up to snuff.
Best of luck,
Josh
EDIT: I see Gary beat me to it!
jgalexander is offline Find More Posts by jgalexander
Old Jan 11, 2013, 11:00 PM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
Thanks for the info fellas. I'm a bigger hobbywing fan than cc fan when it comes to escs. Ill make sure the batteries are up to par even if I need to drop the kv down a Tad on the motor. You guys rock. Hopefully this weekend ill strip the habu and build my eflite hurricane.
Gonna rob the hitec 65mg & 85mg servos and replace with some cheap but trusty TP90MGs on the tail and maybe hxt900s/tp90s on the ailerons and snag a larger hobbywing or plush esc. Going cheap. To much goodies I need and 2 helis I need to fix. Funds are stretched!
Old Jan 14, 2013, 01:40 AM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Which 4200 KV motor by Gary are you guys referring to?
I know of 1 but there may be others.
As far as I know, his best 4200 KV is MEGA 16/30/1
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Jan 14, 2013, 08:36 AM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Gryphon
I was referring to the Velocity 4200. But all the others would be options as well. honestly I'd just e-mail or PM Gary and tell him your budget, speed goal, and cell count and he'll get you a combo. On second thought take that budget and double it.... speed costs at this scale!!
-Brian
kalmon is offline Find More Posts by kalmon
Old Jan 14, 2013, 03:41 PM
GryphonRCU's Avatar
Joined Mar 2008
Thanks for the reply Brian.
I believe i should have commented on E option.
Without the E, the above motor will turn bunch more RPM and draw more AMPs.
Since the internal resistance of the Mega is so much lower (better), if people don't want to run at higher power settings etc, they should consider this motor instead of the one I mentioned above:
16/30/1E with about 5% lower KV (due to E rotor $10) should easily run more efficient than other motors mentioned.
This Mega 6 pole and its very low internal resistance will not drop as many RPM under load compared to other motors. Read higher % KV under load.
At same Watts going into motor, it will put out more RPM than other mentioned brands.....more efficient and cooler.
At same RPM out, it will have fewer watts draw from battery than other brands mentioned.....more efficient and cooler.
***When trying to match a Mega to most other motors (power wise), slightly lower KV should be picked.
Just compare resistance numbers.
9 combinations of shaft and bearing options.
Gryphon
Old Jan 14, 2013, 09:53 PM
efflux RC's Avatar
Joined Aug 2009
We carry 4 motors in the 4200KV range.
These are all "hot" wind motors. Approx 1450-1500 watts ( @95-100A)
on 4s in most 70mm EDFs with a heat sink and throtlle management.
  • ARC 28-48-1 (4250kv...preorder)
  • HET 1W-30 (4400kv) currently on sale.
  • MEGA 16/30/1 (4200kv..Preorder)
  • Velocity RC 2860-4200 (4200kv) in stock
Thanks for the in depth info Gryphon.
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Feb 09, 2013, 06:11 PM
supercollider is offline
Find More Posts by supercollider
C.E.R.N. field tester
supercollider's Avatar
United States, NE
Joined Sep 2012
supercollider is offline Find More Posts by supercollider
Old May 03, 2013, 07:50 AM
ultimatetwo is offline
Find More Posts by ultimatetwo
Fly to live- Live to fly
ultimatetwo's Avatar
ROTA-CADIZ-SPAIN
Just for sharing buddies. A scramble sortie... between my buddie Bernardo´s Vector and my trusty and 3 years old Habu...
Turnigy Trusth 70 amp. from HK seems to do well the job..
Best regards mates.
Manolo.
habu y vector carreritas (4 min 8 sec)
ultimatetwo is offline Find More Posts by ultimatetwo
Old May 03, 2013, 08:09 AM
DamonH is online now
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
What happened to your buddy's plane?
DamonH is online now Find More Posts by DamonH
Old May 06, 2013, 09:22 AM
ROTA-CADIZ-SPAIN
Hi buddies. Las saturday my old and trusty Habu 1 have a midair collision against my buddy Bernardo´s Vector.... so I crashed and fuse lost again his long and slick nose..., a hobby King Hd wing camera was onboard and video ....
And here is my question, it is possible to swap all the components of the old Habu to a new Habu 2 bare airframe kit or at least just using all old parts, wing, tail, motor, etc, with just a new Habu 2 fuse....?.
Tx for granted.
Manolo.
Ps. DamonH, my buddy Vector was undamaged on both videos...., the first one the battery were gone and the second the Vector fell in the wheat field with no damage at all...
HABU BAIL OUT... (5 min 19 sec)
Old May 06, 2013, 10:56 AM
Joined Apr 2010
Hi Manolo,
You can directly swap all the electronics from the Habu 1 to the Habu 2. Good luck with the new plane, and thanks for sharing the videos.
Josh
Old May 08, 2013, 09:29 AM
ROTA-CADIZ-SPAIN
Tx a lot for the tip Josh, I just ordered this morning the bare airframe no painted kit to Germany. Just let me another question... What is the best Hobby King retract system that can fit in the V2 with less mods and reliable ...
Tx for granted.
Manolo.
Old May 08, 2013, 12:02 PM
Joined Apr 2010
I believe this one is it, although I haven't tried it for myself yet.
http://www.hobbyking.com/hobbyking/s...abu_type_.html
Here are the Habu 2 threads. Check em out:
http://www.rcgroups.com/forums/showthread.php?t=1631887
http://www.rcgroups.com/forums/showthread.php?t=1698345
-J
Discussion Parkzone EDF jet HABU comox yqq Foamy EDFs 242 Dec 13, 2011 03:33 PM
Discussion Selecting an EDF/motor for 1st "JET" Texas Buzzard Electric Ducted Fan Jet Talk 22 Feb 01, 2008 02:52 PM
Looking for 1st EDF jet...Help? stegre Electric Ducted Fan Jet Talk 13 Jan 12, 2003 09:18 PM
Recommendation for 1st EDF Jet? HardAbz Electric Ducted Fan Jet Talk 14 Aug 08, 2001 01:06 AM
best edf jet to start with ? exowatt Electric Ducted Fan Jet Talk 19 May 04, 2001 01:39 AM
