Old Oct 24, 2012, 03:22 AM
ChuckTseeker is offline
Find More Posts by ChuckTseeker
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
have bought a Habu 2 airframe and am looking at getting a better sounding EDF than the stock one and wondered if this one would fit the bill?
http://www.hobbyking.com/hobbyking/s..._1200watt.html
it says it makes 1.7kg of thrust, is this more or less than the stock unit? i have searched but couldn't find anything on this 10 blade fan.
This model is the 4s version they also do a 6S version for 2.4kg of thrust but i was thinking the 6s might be a bit of a squeeze and heavy to get into the Habu?
so anyone fitted this 4s or 6s fan? anyone give me any info about weather the 4s will be at least as powerful as the stock system?
cheers chuck
ChuckTseeker is offline Find More Posts by ChuckTseeker
Old Oct 24, 2012, 04:09 AM
crispypilot is online now
Find More Posts by crispypilot
United States, GA, Athens
Joined Jan 2012
I have a change sun ten blade fan with a velocity 2900kv. It sounds great and I get between 6-8 lbs of thrust on a 6s setup with 100 amp esc.
crispypilot is online now Find More Posts by crispypilot
Old Oct 24, 2012, 08:10 AM
kalmon is online now
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
cheers chuck
Chuck I'm not sure how shipping down under would be but Gary at EffluxRC has probably the ultimate all alloy 6S setup for the Habu. Personally I'd be nervous with a metal setup from HK. Metal requires extreme precision in manufacturing.
-Brian
kalmon is online now Find More Posts by kalmon
Old Oct 24, 2012, 01:06 PM
jgalexander is offline
Find More Posts by jgalexander
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
Not to worry, it isn't a metal fan, just the shroud and tailcone. The fan is still plastic. Pretty sweet sounding setup. http://www.rcgroups.com/forums/showthread.php?t=1712422
jgalexander is offline Find More Posts by jgalexander
Old Dec 27, 2012, 08:03 AM
MJB9 is offline
Find More Posts by MJB9
ARMY ATC (93C)
MJB9's Avatar
United States, TX, Keller
Joined Jan 2005
Originally Posted by Diesel6401 View Post
Dang No PNP that's a bummer.........
Looks sick though! I hope like mentioned the servos are swapped. I changed my V1 over to HS65s in the airlerons and HS85mg in the tail.
Did you use HS85MG for both the elevator and the rudder? or just the rudder? Also, did you consider the HS82MG? I only ask that because the 82MG is about half the cost of the 85MG. the 85MG has a bit more torque, but also a little heavier. Amazon has the 82MG's for $15 each :-)
If two 82s/85s fit in the tail, I'm going to order two 82's. I have HS65MGs for everything else including the flaps. Having these larger servers in the tail will help a lot wiht CG on a 5S/6S setup.
MJB9 is offline Find More Posts by MJB9
Old Dec 27, 2012, 09:42 AM
nickelbn1 is online now
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
I dont see why the hs82mg wouldn't work. Definitely strong enough
nickelbn1 is online now Find More Posts by nickelbn1
Old Dec 27, 2012, 11:56 AM
Mugen4Lfe is offline
Find More Posts by Mugen4Lfe
Mugen4Lfe's Avatar
Joined Sep 2011
I've heard the hs82 is faster than the hs85, but the 82 doesn't center as well. But I don't speak from experience.
Mugen4Lfe is offline Find More Posts by Mugen4Lfe
Old Dec 28, 2012, 01:39 PM
AV8TRX is offline
Find More Posts by AV8TRX
AV8TRX's Avatar
Joined Feb 2012
OK this may be a silly question as this thread is epic and I haven't seen the whole thing. I Have been flying the Habu in Phoenix FS but I can't seem to find them on the net for sale. Has it just been replaced by the Habu2? I am looking toward a UMX MIG 15 for a starter EDF but I like this one ALOT!
AV8TRX is offline Find More Posts by AV8TRX
Old Dec 28, 2012, 01:55 PM
Joined Apr 2010
You are correct! Habu2 is the replacement for the Grey/Blue/Yellow v1 Habu. If you'd prefer the v1 Habu, they pop up for sale in the classifieds from time to time (I actually have one that I'll be listing one of these days).
Josh
Old Dec 28, 2012, 07:27 PM
AV8TRX is offline
AV8TRX's Avatar
Joined Feb 2012
Cool Thank you!
Old Dec 29, 2012, 07:48 PM
AV8TRX is offline
AV8TRX's Avatar
Joined Feb 2012
Never mind. I think I found it.
Old Jan 03, 2013, 05:24 PM
BlackBeast is offline
Find More Posts by BlackBeast
BlackBeast's Avatar
Canada, QC, Témiscouata-sur-le-Lac
Joined Dec 2008
Just finished my new tiger paint scheme...
BlackBeast is offline Find More Posts by BlackBeast
Old Jan 11, 2013, 06:26 PM
Diesel6401 is offline
Find More Posts by Diesel6401
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
Yup I used the 85MG on the rudder and the elevator. Took just a little foam carving to fit, nothing major. No issues.
Diesel6401 is offline Find More Posts by Diesel6401
Old Jan 11, 2013, 06:32 PM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
Question for all, my Habu is a starting to show her age and repeated belly landings are starting to take it's toll. I'm thinking of yanking the guts out of her and maybe buying a E-Flite F86 and using all the Habu gear in that. I'm not retiring the Habu airframe just yet, so what is the most ballistic 4s setup for a Habu? Not looking to break the bank so what's cheap speed?!? I don't want to buy more batteries so that's why I'm sticking with 4s and when (down the road) if I ever get the F86 I won't need anything other then the airframe kit.
Old Jan 11, 2013, 07:45 PM
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
I used .5oz cloth and glassed the bottom of the plane using polycrylic. This added almost no weight and probably added a couple mph in drag reduction. Not to mention belly landings have virtually zero wear on the bottom anymore.
As for a 4S speed setup, I think Gary at Efflux RC has a 4200kv "hot wind" motor that paired with a bigger ESC would provide more speed.
-Brian
Discussion Parkzone EDF jet HABU comox yqq Foamy EDFs 242 Dec 13, 2011 02:33 PM
Discussion Selecting an EDF/motor for 1st "JET" Texas Buzzard Electric Ducted Fan Jet Talk 22 Feb 01, 2008 01:52 PM
Looking for 1st EDF jet...Help? stegre Electric Ducted Fan Jet Talk 13 Jan 12, 2003 08:18 PM
Recommendation for 1st EDF Jet? HardAbz Electric Ducted Fan Jet Talk 14 Aug 08, 2001 12:06 AM
best edf jet to start with ? exowatt Electric Ducted Fan Jet Talk 19 May 04, 2001 12:39 AM
