Old Feb 11, 2012, 07:55 PM
southernmd_man is offline
Find More Posts by southernmd_man
Gravity's a harsh Mistress....
southernmd_man's Avatar
United States, MD, Lusby
Joined Jan 2007
Too nasty to fly, so it was a nice day for new decals to be applied and change her a bit.
southernmd_man is offline Find More Posts by southernmd_man
Old Feb 11, 2012, 09:27 PM
the_walrus is offline
Find More Posts by the_walrus
United States, UT, Saratoga Springs
Joined Mar 2010
Originally Posted by ufale View Post
Walrus...any pictures?
I did flaps just like the guy in post 5393, pics here:
http://www.rcgroups.com/forums/showt...s#post16609776
This guy did the same:
Habu flap and retract mods (0 min 22 sec)
It was $4 for servos, already had some linkages laying around, works like a champ!!
the_walrus is offline Find More Posts by the_walrus
Old Feb 12, 2012, 12:28 AM
Heirmeistr is online now
Find More Posts by Heirmeistr
If it flys, I like it
Heirmeistr's Avatar
USA, CA, Fullerton
Joined Jun 2007
I have a habu that has just been sitting around for a while. Now I want to paint it and fly it, but before I paint it I should do my mods first. Is there a post or list of recommended mods? I am especially interested in what some have done to keep the ESC running cooler. Adding ventilation holes and relocating the ESC?
Heirmeistr is online now Find More Posts by Heirmeistr
Old Feb 12, 2012, 12:43 AM
Dan767 is offline
Find More Posts by Dan767
Dan767's Avatar
United States, WA, Federal Way
Joined Apr 2006
Dan767 is offline Find More Posts by Dan767
Old Feb 12, 2012, 07:17 AM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
The ones I've seen most often are:
1) open cooling holes just behinds the stock receiver location into the ducting to help suck air out of there.
2)relocate ESC, stock location standing on end for more exposed surface area, recessed into the intake ducting about an inch to 1 1/2" back of the intake, or in the belly under the wing or just behind the wing.
3)retracts
4)flaps/spoilers
5)5cell on stock motor and just up the ESC to a 100a everything else handles 5S just fine.
The nice thing about moving the ESC back is it helps fix the stock nose-heavy CG. And if you move it to the intake ducting you can get rid of the motor wire extensions, which add weight.
-Brian
kalmon is offline Find More Posts by kalmon
Old Feb 12, 2012, 08:23 AM
ufale is offline
Find More Posts by ufale
ufale's Avatar
Joined Nov 2010
This guy did the same: http://www.youtube.com/watch?v=h38Y7Hw2Rn0
Thanks!! I am going to do this. I had one very bad experience when I throttled down while turning into my final approach (lawn dart). Since then, I eat up a lot of runway when I land my Habu. (I have even had it so far away from me that I could not see when it touched ground.) I think flaps will really help me cut down the space needed for landing.
ufale is offline Find More Posts by ufale
Old Feb 12, 2012, 08:42 AM
Airbusboy is offline
Find More Posts by Airbusboy
Airbusboy's Avatar
Bishops Stortford, UK
Joined Dec 2005
I agree with most recent comments on this thread, the Habu thread needs to keep going, as it is such a great all round EDF plane, so here is my 2 cents worth.
I dont know whether it has been tried before on this thread, so I apologise in advance if it has, but I am currently experimenting with micro cooling fans on the stock 60A ESC.
I did a brushless motor conversion on a buggy a while back, and the buggy ESC came with a cooling fan which gave me the idea. I didn't want to move things or cut things about in the fuselage just yet.
I have come across the ESC temp cut out like most people who have tried upgrading the motor. I currently have the Eflite 3600kv motor in it, and the ESC is not very reliable, even though it is only pulling about 45-47 Amps at WOT.
I did put a Mega 16 15 2 in a Wemo Fan on 4S in the Habu a while back and the Stock ESC didn't want to know at all. I am running 60A ESC's in other models with this combination with no problems, so I am sure the stock Eflite 60A ESC is up to the job.
First indication are really good. I only have a 17 x 17mm micro fan on the ESC at the moment, as it was all the Electronics shop had in stock. This is a little too small I feel, so I have ordered a couple of larger cooling fans to try out. They are 5v fans, weigh nothing, and I am running them from a spare socket on the receiver. They only draw about 0.2A so battery consumption isn't really an issue. All I have had to do is add a male servo connector to the cooling fan with no other modifications.
I will keep those who are interested updated.
Airbusboy is offline Find More Posts by Airbusboy
Old Feb 12, 2012, 10:13 AM
Heirmeistr's Avatar
USA, CA, Fullerton
Joined Jun 2007
Thanks Kalmon!
I really like what Depron Dave has done with the retracts. Looks like he has his ESC moved behind the wing as you mentioned. I spent a lot of time last night looking for a picture of where and how people have moved their ESC. I couldn't find a single picture. Does anyone have one? As they say, a picture is worth a thousand words!! Thanks
Old Feb 12, 2012, 03:16 PM
tacoturbo is offline
Find More Posts by tacoturbo
tacoturbo's Avatar
Kauai, Hawaii
Joined Oct 2009
Originally Posted by gewiens View Post
Why not just buy another airframe? Not sure how pricey they are though.
I would but HH says its no longer available and out of stock. Geez, what a bummer. I wasn't wild about the paint scheme but the Habu flew so good I'll miss it. I need the complete airframe kit, dang it sucks they don't produce it anymore. I fly off a rough grass runway so the newer Habu is out of the question as it doesn't look like a good belly lander.
tacoturbo is offline Find More Posts by tacoturbo
Old Feb 12, 2012, 03:36 PM
gewiens is offline
Find More Posts by gewiens
Look Up!
gewiens's Avatar
Canada, MB, Niverville
Joined Apr 2008
You can't get parts anymore? Weird. The new habu would definately not be a belly lander.
gewiens is offline Find More Posts by gewiens
Old Feb 12, 2012, 03:39 PM
gewiens is offline
Look Up!
gewiens's Avatar
Joined Apr 2008
Complete air frame still showing on parkzones site.
Old Feb 12, 2012, 06:48 PM
divemasterphil is offline
Find More Posts by divemasterphil
Soon to be CrashMasterPhil
Rochester MN
Joined Dec 2007
You can still get all the parts individually.
divemasterphil is offline Find More Posts by divemasterphil
Old Feb 12, 2012, 11:41 PM
Depron Dave is offline
Find More Posts by Depron Dave
Lots foam, so little time
Depron Dave's Avatar
northridge California
ESC relocation
Thanks Kalmon!
Here is from post 8290
http://www.rcgroups.com/forums/showt...c#post20268073
Depron Dave is offline Find More Posts by Depron Dave
Old Feb 12, 2012, 11:44 PM
Parts.....
Yeah I just got all the parts individually from HH .for a back up
Old Feb 13, 2012, 08:13 AM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
Originally Posted by Depron Dave View Post
The only reason I didn't mount my ESC there was the extra long battery extension i'd need to get power back there.
-Brian
Discussion Parkzone EDF jet HABU comox yqq Foamy EDFs 242 Dec 13, 2011 02:33 PM
Discussion Selecting an EDF/motor for 1st "JET" Texas Buzzard Electric Ducted Fan Jet Talk 22 Feb 01, 2008 01:52 PM
Looking for 1st EDF jet...Help? stegre Electric Ducted Fan Jet Talk 13 Jan 12, 2003 08:18 PM
Recommendation for 1st EDF Jet? HardAbz Electric Ducted Fan Jet Talk 14 Aug 08, 2001 12:06 AM
best edf jet to start with ? exowatt Electric Ducted Fan Jet Talk 19 May 04, 2001 12:39 AM
