Old Aug 28, 2011, 12:21 PM
SBOTI74 is offline
Find More Posts by SBOTI74
I fly em', there for I am.
SBOTI74's Avatar
United States, CA, Tehachapi
Joined Feb 2009
That is a great explanation, thank you. I still don't really know what I have though. I have a Turnigy 80amp plush with UBEC.. is that switching, external, internal?
Thank you
SBOTI74 is offline Find More Posts by SBOTI74
Old Aug 28, 2011, 12:57 PM
vasek is offline
Find More Posts by vasek
Joined Nov 2003
Hey guys, i just ordered this controller for my habu (the original heats too much 4 my taste).
Did i make a wise choice? it has good reviews...
http://www.hobbyking.com/hobbyking/s...dproduct=10331
vasek is offline Find More Posts by vasek
Old Aug 28, 2011, 01:25 PM
onefastxp is offline
Find More Posts by onefastxp
crashing build's character.
United States, AL, Dora
Joined Mar 2008
yes you made a great choice.
onefastxp is offline Find More Posts by onefastxp
Old Aug 28, 2011, 02:13 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Thank you
You are welcome. Do you have the link the ESC you bought?
Prof100 is offline Find More Posts by Prof100
Old Aug 28, 2011, 03:58 PM
SBOTI74 is offline
SBOTI74's Avatar
Joined Feb 2009
Absolutly... Here's the link to the Turnigy 80A Plush with UBEC
http://www.hobbyking.com/hobbyking/s...idProduct=3727
Thank you again guys.
Old Aug 28, 2011, 04:19 PM
ZACATTACK is offline
Find More Posts by ZACATTACK
ZACATTACK's Avatar
Canada, ON, Hamilton
Joined May 2011
6 channel Spectrum
Still waiting for my foam Habu...I purchased a 6 channel RX Spectrum..with my X9303...should be nice..How do I hook up the controls on Ailerons... Left channel to AIL and where does the right channel go to?? Aux.1?? How about the steering for the front...I cannot run a seperate channel for RUDD ...not enough channels!! I have 10-15 retracts aswell.
1. Throttle.
2. Aileron
3. ELEV
4. RUDD
5. GEAR
6. AUX 1
So I guess I have to do a Rudd Mix with the steering??
ZACATTACK is offline Find More Posts by ZACATTACK
Old Aug 28, 2011, 04:53 PM
Jae14 is offline
Find More Posts by Jae14
Joined Jul 2011
1. Throttle.
2. Aileron
3. ELEV
4. RUDD
5. GEAR
6. AUX 1
The Habu comes with two Y-harnesses, one to join the ailerons onto one channel and the other to combine rudder and nose steering. I removed one y harness (rudder/steering) and plugged them separately into my Rx. But with the basic wiring as it comes you will only need 4 channels (Throttle, aileron, elevator, rudder/steering). I don't have retracts, but since you do then you'll need one more channel for that. So at minimum, you can have all functions including retracts on 5 channels.
Jae14 is offline Find More Posts by Jae14
Old Aug 28, 2011, 05:17 PM
evo101 is online now
Find More Posts by evo101
evo101's Avatar
Australia
Joined Jun 2009
Sure rimripper, prob won't be able to get out to the field again till the weekend
My battery does come down hot but I feel there is not enough cooling at the moment so I'll see what I can do there.
What esc are you using?
Originally Posted by rimripper View Post
Spyda,would you be able to do a 3 sec. Run into the camera and 3 sec. Out of it?I've also got a hot setup I need to run,it was going to be 6s but it's alot of amps and it was hard on my lipo's.The 5s still makes almost 1800 watts after a 7 second static,(slow startup)
I do like your new setup though!!!
evo101 is online now Find More Posts by evo101
Old Aug 28, 2011, 05:21 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
I know Hobbyking buys Hobbywing ESCs and rebadges them as Turnigy. It looks a lot like the Hobbywing 80 amp. Usually Hobbyking states it is switchmode BEC. Why not just buy the Hobbywing from Target Hobby for $18 less?
Old Aug 28, 2011, 05:50 PM
rimripper is offline
Find More Posts by rimripper
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
I was running a Ice lite,with the heat shrink opened on the ends for better airflow,on 6s I pulled 150 amps static,it's more my lipo's getting hurt than anything.I'll just run it on 5s for now.
rimripper is offline Find More Posts by rimripper
Old Aug 28, 2011, 06:07 PM
SBOTI74 is offline
SBOTI74's Avatar
Joined Feb 2009
Oh, I didn't buy it... I got it in a trade with a new Extreme Flight Extra... Just don't know what UBEC is exactly. Copy on the rebadging. I figured that's what it was.
Old Aug 28, 2011, 07:09 PM
evo101's Avatar
Australia
Joined Jun 2009
i might look at the CC ice light aswell as they seam to handle there Amp rating no issue.
im not sure how many amp's im pulling on 5s as my amp meter only reads up to 100amps. the 4s set up settles and holds around 90 - 95 amps full power on the ground.
Old Aug 28, 2011, 07:24 PM
ZACATTACK's Avatar
Joined May 2011
Servos
I have some HS-65-HB servos..Are these good for the Aileron? Are they good for the steering? What is a ggod recomendation for servos on this air frame? I have the Habu 32 on 5085's but that overkill on a foamy!The 65's come in metal gear aswell. Any input is super cool! Thanx!
Old Aug 28, 2011, 07:45 PM
tclaridge is offline
Find More Posts by tclaridge
United States, VA, Clifton
Joined Nov 2005
I have a five channel Rx. I used the Y for my steering and rudder, but I put the left aileron on the gear channel so I could do spoilerons. Works great.
tclaridge is offline Find More Posts by tclaridge
Old Aug 28, 2011, 07:49 PM
ZACATTACK's Avatar
Joined May 2011
This may sound stupid... Im a Heli guy with a Habu32/1409-2Y with a Foam Habu coming BUT What are soilerons? Should I set them up in my Foamy? I have a X9303...
Discussion Parkzone EDF jet HABU comox yqq Foamy EDFs 242 Dec 13, 2011 02:33 PM
Discussion Selecting an EDF/motor for 1st "JET" Texas Buzzard Electric Ducted Fan Jet Talk 22 Feb 01, 2008 01:52 PM
Looking for 1st EDF jet...Help? stegre Electric Ducted Fan Jet Talk 13 Jan 12, 2003 08:18 PM
Recommendation for 1st EDF Jet? HardAbz Electric Ducted Fan Jet Talk 14 Aug 08, 2001 12:06 AM
best edf jet to start with ? exowatt Electric Ducted Fan Jet Talk 19 May 04, 2001 12:39 AM
