Old Oct 05, 2009, 06:11 PM
AEMontoya is offline
Find More Posts by AEMontoya
AEM
AEMontoya's Avatar
Bay Area, CA
Joined Sep 2009
Question
Placing Motor/Radio system from a Radian into an Easy Glider?
I have a Radian and would like an economical way to practice flying a similar plane that has ailerons. Would it be possible for me to simply buy the extra servos and then switch the motor and radio components from a Radian into an Easy Glider?
AEMontoya is offline Find More Posts by AEMontoya
Old Oct 06, 2009, 04:56 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Sure!
..a
Old Oct 06, 2009, 01:58 PM
AEM
AEMontoya's Avatar
Bay Area, CA
Joined Sep 2009
Originally Posted by Andy W
Sure!
..a
Thanks for the reply, Andy (we're namesakes). One of the reasons I would like to switch over from the Radian to the Easy Glider Pro is because the latter has ailerons, and I would like to slowly train myself to be able to someday handle F5F models (the Radian is only R & E). Toward that end, I was just reading a really good post from May 20, 2003 (http://www.rcgroups.com/forums/showthread.php?p=990930) where you helped explain the difference between flaperons and spoilerons. Well, I would love to figure out how to be able to program the Spektrum Dx5e radio that came with my Radian so that when I use it with an Easy Glider Pro I can have both ailerons raise at the same time, thereby acting as spoilerons. Again, my goal would be to train for someday being able to fly F5F planes that truly utilize spoilerons and flaps. Do you know if such programing is possible? The stock receiver that the Radian uses and that I plan to use in the EG Pro is an AR500, which has ports for two ailerons. Any help would be greatly appreciated. Also, since the EG Pro requires 2 extra servos, would I have to upgrade my Radian battery from the stock 3S 1300 mah Lipo to something bigger? Thanks.
Old Oct 06, 2009, 02:40 PM
Windknot is offline
Find More Posts by Windknot
Canada, PE, Stratford
Joined Aug 2006
Not with a Dx5e tx, but you can have spoilerons with the AR500 Rx and some mixing.
See this thread:
http://www.rcmf.co.uk/4um/index.php/topic,56876.0.html
Windknot is offline Find More Posts by Windknot
Old Oct 06, 2009, 04:03 PM
AEM
AEMontoya's Avatar
Bay Area, CA
Joined Sep 2009
See this thread:
Thanks for the link, Windknot. Unfortunately, both time that I tried to follow it, I received an error message and was automatically signed off of the internet. I will try it again later.
Old Oct 07, 2009, 12:29 AM
Windknot is offline
Joined Aug 2006
From the thread in the link above:
Servo settings, if your's are different then some of the '-' may become '+' and visa versa
THR & GEAR = NORM
AILE, ELEV, RUDD, FLAP = REV
My left (looking from the front) wing aileron servo is plugged in to the GEAR channel.
My right (looking from the front) wing aileron servo is plugged in to the AILE channel.
Set your GEAR travel adjust to +0% -0%
Use FLAP and AILE travel adjust as required to adjust your wing servo limits.
You need to do the mixes on PROG.MIX5 and PROG.MIX6 you can use others but the trims for the AILE etc will not work if they are not in 5 or 6 according to the manual.
Here is my PROG.MIX5 This links the FLAPERONS to the GEAR
FLAP -> GEAR
RATE: -100%
-100%
SW: ON
OFFSET: 0
Here is my PROG.MIX6 This links the AILERONS to the GEAR
AILE -> GEAR
RATE: -100%
-100%
SW: ON
OFFSET: 0
Thatís it! If youíre not using FLAPERONS then you wonít need the 5th mix. It can be a bit fiddly to get the lower rate value, I had to set the SW to 'MIX' then use the D/R throttle hold switch to toggle on/off and the aileron control to get to the lower value
I also have a throttle hold switch set up (habit from my Heli's)
PROG.MIX1
THRO -> THRO
RATE: -120%
0%
SW: ON
OFFSET: -125
Old Oct 09, 2009, 10:36 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
DX5i is not a computer radio. It has no channel mixing so it can't do flapperons or spoilerons. However if you put a Y cable on the ailerons you can fly the Easy Glider with the DX5i.
The stock battery would be fine.
aeajr is offline Find More Posts by aeajr
Help! Which one...Radian or Easy Glider Pro? jodini Electric Sailplanes 34 Oct 09, 2014 09:58 PM
Sold Radio System from Stryker F27C Dynomike Aircraft - General - Radio Equipment (FS/W) 2 Jun 03, 2008 07:54 PM
F/S Graupner Terry/w motor,folding prop,and radio system gflier Aircraft - Electric - Airplanes (FS/W) 1 Feb 04, 2005 09:09 PM
Radio Glitching from Brushless system? RCDad Electric Plane Talk 18 May 29, 2004 01:21 PM
How easy is it to remove radio gear from a Firebird XL ? Al P Foamies (Kits) 5 Jan 21, 2002 01:23 PM
