Old Apr 23, 2003, 09:22 AM
Nowell York is offline
Find More Posts by Nowell York
Nowell York's Avatar
Columbus, Ohio
Joined Nov 2001
Multiplex Cockpit -- Rudder throttle mixing for twin?
I know this is possible with other radios, however, has anyone been able to do this with the limited mixing capability of the Cockpit? The goal would be mild yaw control with two motors.
I've done elevator-throttle mixing, but this is a different beast.
Nowell York is offline Find More Posts by Nowell York
Old Apr 27, 2003, 10:45 AM
Columbus, Ohio
Joined Nov 2001
btt
Old Apr 28, 2003, 01:35 AM
rorywquin is offline
Find More Posts by rorywquin
Turbines suck ;-)
United Kingdom, Hillam
Joined Mar 2000
I am reasonably sure you cannot do it through the standard mixers - maybe you can some how replace the control to the rudder (or 2 servo ailerons) with control to the left and right motors ?
rorywquin is offline Find More Posts by rorywquin
Old Apr 30, 2003, 10:48 PM
Columbus, Ohio
Joined Nov 2001
THanks for the reply. I'm sure it could be done, but I'd propbably have to move several of the channels on the mother board around making it a radio dedicated to that aircraft.
Old May 01, 2003, 01:43 AM
Turbines suck ;-)
Joined Mar 2000
If you use a 2 aileron set up to control two speed controllers and then have rudder / elevator control only it may work.
Old May 01, 2003, 05:20 AM
max z is offline
Find More Posts by max z
max z's Avatar
The Netherlands, ZH, Boskoop
Joined Mar 2001
This will give you differential motor control only, and deprive you of a common throttle function. I don't know the Cockpit's capabilities, but if you can mix in flap and use that for throttle control I think you're there.
Max.
max z is offline Find More Posts by max z
Old May 06, 2003, 01:17 AM
Turbines suck ;-)
Joined Mar 2000
MAx Z
I think that would work.
Old May 06, 2003, 07:33 AM
Columbus, Ohio
Joined Nov 2001
Brilliant. Let me have a go at this and I'll report back.
Right stick will be rudder/elevator (which I have to use anyway for my 4 channel rx flying wings).
Left stick will be setup for dual ailerons with flaps mixed in.
Help! Rudder throttle mixing Michael in Toronto Radios 0 Jul 05, 2007 11:15 AM
Help! Multiplex Cockpit SX throttle programming? GliderGuideMan Radios 7 Jan 14, 2007 10:09 AM
Question Rudder to throttle mix for HB King? Pepper99 Mini Helis 5 Jan 03, 2007 05:17 PM
Question Rudder to Aileron mixing for Knife Edge??? dst 3D Flying 3 May 31, 2006 11:15 PM
Discussion Futaba TZ7CAP throttle mixing (for flaps) uswaldronz Radios 1 Apr 13, 2006 05:41 PM
