Old Oct 05, 2009, 04:21 PM
b-29er is offline
Find More Posts by b-29er
Buzz Run Extraordinare!
b-29er's Avatar
USA, MI, Sanford
Joined Jul 2006
Sea Dart project
I am starting on plans to make a fully-functional Convair Sea Dart as a winter project. I will be making more announcements on designs shortly.
here are the plans
material- sheet foam
power-edf's, up to twin 70mm's.
size- to scale for ducting
water takeoff/ landing capable- yes.
version- single ski for ease of constructuon
here are the plans it will be based off.
for those who don't know what a sea dart is... this is the twin ski version
Convair F2Y Sea Dart (1 min 54 sec)
b-29er is offline Find More Posts by b-29er
Old Oct 05, 2009, 06:35 PM
JGuilty13 is offline
Find More Posts by JGuilty13
JGuilty13's Avatar
United States, MI, Rochester Hills
Joined Nov 2005
this should be a very cool project!
JGuilty13 is offline Find More Posts by JGuilty13
Old Oct 05, 2009, 06:38 PM
Jack Brewer is offline
Find More Posts by Jack Brewer
United States, IN, Lafayette
Joined Dec 2003
Great, I have always like the Sea Dart. I also like non convential planes, just have to be different.
Jack Brewer is offline Find More Posts by Jack Brewer
Old Oct 05, 2009, 07:06 PM
b-29er is offline
b-29er's Avatar
USA, MI, Sanford
Joined Jul 2006
great! always lie support
anyways, I have made a list of parts (as of now
Foam: 6mm depron for framing of body, thin depron (maybe 1mm-2mm max) for skin. this should keep the plane light for flight.
edf: twin 66mm-70mm edf's. going by cost, because everyone likes a low cosst aircraft.
motor: hobby king 4900kv motor
esc: 50a esc
battery: 4s definite, size to be determined by weight.
Servos: 2 to 4 servos, narrow wing servos, 9mm thickness (external mount option
2 3kg+ servos (internal mount option, most likely
2 6kg standard servos for retractable ski
1 servo for rudder/ water rudder
size:scale. the size of the aircraft wll be determined by the ratio of the edf duct to the plan's ducting size.
radio: 6ch 2.4ghz radio from hobbyking
Retract system:
i hope to have 2 servos for the retractable ski, with homeade waterproofing. The plan is to use 2 pushrods mounted to hinges to push the rods out. the foreward servo will push less, to make the scale look. 4 tubes will slide in and out to hold the retracted panel in line. pics to come.
Old Oct 05, 2009, 07:51 PM
b-29er is offline
b-29er's Avatar
USA, MI, Sanford
Joined Jul 2006
Well, i looked at the airplane's specs on wikipedia, and found that the original plane had between a .96 and .54 t/w. meaning, weigtwise, there should be no thrust problem.
Old Oct 05, 2009, 07:53 PM
JackDaWack is offline
Find More Posts by JackDaWack
NJ
Joined Nov 2008
Subscribed!!! when your finished, i wouldnt be surprised if it never touched water! i would be so scared to land.
JackDaWack is offline Find More Posts by JackDaWack
Old Oct 05, 2009, 08:23 PM
b-29er is offline
b-29er's Avatar
USA, MI, Sanford
Joined Jul 2006
you'll be surprised. there are a lot of methods i'm tinking of for this ski, and i have a lot of places near water. guaranteed, it will fly on and land on water, just as the original did: getting up to ski speed (5kts), deploying skis and taking off, and landing the same. plus, the delta needs a high angle of attack for takeoff and landing, so having water around will help.
Old Oct 06, 2009, 02:39 PM
b-29er is offline
b-29er's Avatar
USA, MI, Sanford
Joined Jul 2006
figured out some dimensions. tip-to-tip, the wingspan will be 39", and length will be measured soon- i got 60, but with a 60 degree delta wing, doesn't seem right.
The fan will be a cheap 66mm 6-blade from hobby-lobby. The motor will be a 4900kv off-brand on a 4s with a 50a esc. 2 motor setups for the plane. judging by the power made by the thin-impellered storm with a 4150kv motor, the motor setup shouod produce around 2lbs+ thrust others using a similar setup.
Old Oct 07, 2009, 03:13 PM
b-29er is offline
b-29er's Avatar
USA, MI, Sanford
Joined Jul 2006
Quick question- i am looking at the feedback on the motors, and i'm hearing a lot of the same tune: The engine is FAST!!! but the speed controller needs to be set up with a good heat sink and ventillation. Anyone have a suggestion on how to get these more venting without putting them in the ducting or on top of the plane?
Borrowed some better plans (and a template for the paint job) from Pontious and W@cco's sea dart thread. Will be comparing these together, and more likely, i'll be using the plans from the old thread (clearer)
Does anyone have a drawing of the rear end? i need the size and placement of the rear ducts for the plans (and correct scaling).
Old Oct 07, 2009, 07:00 PM
b-29er is offline
b-29er's Avatar
USA, MI, Sanford
Joined Jul 2006
ok... i figured out the dimensions
width: 39"
length: jut over 60 with the tip.
Joined Dec 2003
Rear View
Display Sea Dart.
Old Oct 07, 2009, 07:07 PM
b-29er is offline
b-29er's Avatar
USA, MI, Sanford
Joined Jul 2006
works well enough. scale stays. I had set the plane up for 75mm for space for the edf's, and it works well for what i see. Any ideas on a water rudder?
Old Oct 07, 2009, 07:31 PM
b-29er is offline
b-29er's Avatar
USA, MI, Sanford
Joined Jul 2006
here are the autocad drawings of the plane. half-done, i have to do another drawing of the side.
Old Oct 07, 2009, 09:49 PM
b-29er is offline
b-29er's Avatar
USA, MI, Sanford
Joined Jul 2006
Well, finally got some dim analysis issues fixed. here are the dims
Length:60"
wingspan: 39"
height: 17"
I have completed the first stage- copying. next stage is bulkhead design. sould be done over te weekend.
Old Oct 07, 2009, 09:57 PM
EDDIEGIGOWATTS is offline
Find More Posts by EDDIEGIGOWATTS
1.21 gigawatts
EDDIEGIGOWATTS's Avatar
Fort.lauderdale Florida
Joined Jul 2006
you are so lucky I was just almost about to delete a bunch of pics out of my Pentax
I have more for tomorrow
Eddie
EDDIEGIGOWATTS is offline Find More Posts by EDDIEGIGOWATTS
Sea dart W@CC0 Electric Ducted Fan Jet Talk 25 Oct 24, 2009 10:06 AM
Build Log Sea Dart float jet. rifleman_btx Foamy EDFs 15 Oct 05, 2009 08:31 PM
Discussion Sea Dart! rifleman_btx GWS (Grand Wing Servo) 13 Sep 20, 2007 03:10 PM
