Thanks...might have to look into some Tan Sport...for the time being, I might try chaining a couple bands together (tried that only once or twice before). I just want a good plane that will go up at least 50 feet or so before losing power.
Most of the time my building materials are EPS (foam plates) and a bamboo skewer. And a little hot glue to put it all together. So that might give you an idea of the weight of the aircraft...I would rather fly them outdoors than indoors. With the cheap rubber I have now, I might try and build a glider-type plane using 2 or 3 bands and see if I can get some decent climb and flight times. EDIT: One other question - is this the right place to buy the Tan Sport rubber? http://www.faimodelsupply.com/ |
United States, MA, Waltham
Joined Dec 2001
That's the place. And you'll be amazed how much better the good stuff is. Meanwhile, lube your motor and stretch it out when you start to wind, letting it shorten as you get more turns in. Silicone grease makes a good lube, or tincture of green soap with the alcohol boiled off mixed 50 percent with glycerin (the old fashioned formula). I use Formula 2001 rubber treatment. Not the other stuff, but the kind that's meant for rubber. (and maybe some other things, but rubber is one)
Latest blog entry: pics from Winthrop, MA indoor flying...
Illinois
Joined Feb 2004
Catman,
I just remembered something. Bill Kuhl emailed me a while back and he has designed a new, easy to build glider that’s built from foam plates. I think it’s right up your alley. Bill also has a video of the planes design process on his home page. If you give it a try let him know what you think, he loves feed back. Here is a link to the plan: http://www.hbci.com/~bkuhl/FoamJetII.htm Zach |
| Thread Tools | |
| Discussion problem with my optic 6 rubber duck | samymmk | Hitec/Multiplex USA | 1 | Jun 13, 2008 03:34 AM |
| Discussion balsa rubber powered plane rc conversion | lgliser | Indoor and Micro Models | 3 | Sep 08, 2007 11:13 PM |
| Alert A123 potential problem with building packs | bradpaul | Batteries and Chargers | 2 | Oct 24, 2006 02:18 PM |
| Help with a F/F rubber-powered duration flyer design | Cheesehead | Free Flight | 3 | Apr 08, 2005 07:09 PM |
| Successful stories of converted rubber powered plane? | Niggo | Parkflyers | 1 | Dec 01, 2004 02:08 PM |
