Old Oct 05, 2009, 09:03 AM
rcgroupie is offline
Find More Posts by rcgroupie
pushing the envelope
rcgroupie's Avatar
USA, CA, Los Angeles
Joined Jun 2005
9 dB collinear omni antenna build for 900 MHz video
Decided to build a collinear 900 MHz antenna from coax. The antenna is built from 50 Ohm RG 58 coax cable with a theoretical gain of 9 dB over 360 deg. Since each 3 dB doubles the effective power of the transmitter, this will give about 8 times the power.
This would eliminate the need for antenna switching since it is omnidirectional. I'm not worried about directly overhead, because there should be enough leakage to cover any reasonable altitude.
Another benefit of a good antenna is that by reducing SWR, transmitter heating can be minimized. Thus it would be beneficial to use the antenna on the vehicle as well.
First order of business was to cut the cable into 1/2 wavelength pieces. Then the ends were trimmed to have a short length of center conductor and a short length of shield exposed. The tricky part was to do this without cutting the shield.
EDIT: Quickstart
Dimensions:
Coax segment overall length is 4.6" per segment, overlap to get 4.28" sections
Tube is 3.08 long
Tip is 3.25 long
Ferrites centered 4.28 back from feed.
Anyway, some important notes:
Don't use a CB style PL-259 connectors, they are very lossy above 300 MHz, use N, SMA or BNC
RG 58 cable is lossy so don't run long feeds - use RG 8 to extend the cable with a connector as above.
You will not want a directional antenna on an aerobatic plane, just use it for your ground station.
Don't let anything conductive near the active part of the antenna, and get it up in the air.
rcgroupie is offline Find More Posts by rcgroupie
Old Oct 06, 2009, 10:51 AM
rcgroupie's Avatar
Joined Jun 2005
Here is an image of one segment of the coax portion of the antenna. 4 segments = about 6 dB gain and 8 segments = about 9 dB gain. This was a scrap segment since the ends were not perfect.
The 9 dB 8 segment version is about 3' long so it is intended to be connected to the receiver end.
On the vehicle, the standard 3" long whip that comes with the transmitter is normally used (must be mounted vertically). However, since a 4 segment collinear antenna is < 2 feet long, it is feasible to mount it on some vehicles such as blimps.
Combining 6 dB on the vehicle and 9 dB on the ground gives 15 dB gain, equivalent to 32 times the transmitter power!
Old Oct 06, 2009, 04:41 PM
jimmyjet007 is offline
Find More Posts by jimmyjet007
Joined Jun 2009
Hi,
This is very interesting. I don't understand the theory but this is very interesting. Please continue to share the development. Any other photos of a finished collinear antenna?
Jimmy
jimmyjet007 is offline Find More Posts by jimmyjet007
Old Oct 07, 2009, 09:01 AM
morane is offline
Find More Posts by morane
Joined Nov 2008
I am also interested in this antenna. Thanks, alessandro
morane is offline Find More Posts by morane
Old Oct 08, 2009, 04:22 PM
GallopingGhost is offline
Find More Posts by GallopingGhost
Joined Sep 2005
This sounds like a very good idea. Please continue and keep us informed on your progress.
GallopingGhost is offline Find More Posts by GallopingGhost
Old Oct 08, 2009, 05:34 PM
frogman1206 is offline
Find More Posts by frogman1206
Frogman
Stoughton, WI
Joined Jun 2009
This is all intriguing but can someone explain to an electronic idiot like me how you would implement this and make it work. All I see is a length of coax with the ends removed. I can handle that part but wouldn't know what to do next. I just got a 900mhz dowlink setup so this interests me.
frogman1206 is offline Find More Posts by frogman1206
Old Oct 08, 2009, 08:37 PM
Joined Sep 2005
Ditto.....
Bump bump....
I found this on a 2.4
http://martybugs.net/wireless/collinear.cgi
Old Oct 08, 2009, 09:21 PM
rcgroupie's Avatar
Joined Jun 2005
OK I'm still trying to get some pics. In essence, you just solder the 8 bits of coax, add a whip at the top and a brass tube and a couple ferrites at the base and you're done. You can also scale it for 2.4
Old Oct 08, 2009, 09:56 PM
Frogman
Stoughton, WI
Joined Jun 2009
Cool....I could maybe handle that if it is explained properly. I'm not a total electronics idiot but dang close.
Old Oct 09, 2009, 11:19 AM
rcgroupie's Avatar
Joined Jun 2005
The center conductor of each section is soldered to the shield of the adjacent one, both sides. Care must be taken not to melt the core insulation. When done, there should be two separate circuits, insulated from each other.
The end gets a bit of copper wire radiator, and the feed point has ferrites and a tube to stop the RF from returning. Tip length and ferrite position are adjusted to minimize SWR.
Old Oct 09, 2009, 04:16 PM
Joined Sep 2005
Are there any commercial made ones on the market for us lazy guys?
Old Oct 09, 2009, 04:30 PM
rcgroupie's Avatar
Joined Jun 2005
This lazy guy would have bought one...
Dimensions:
Tube is 3.08 long
Tip is 3.25 long
Old Oct 09, 2009, 08:53 PM
Joined Sep 2005
I must admit I like the concept of more gain than a patch in a Omni design. Only downside I see is getting the stuff and doing it. Waaa waaa waa goes the lazy boy...
For what its worth I built several DIY HD TV antennas out of almost nothing and they outperformed almost any commercial antenna I tried.
Old Apr 01, 2010, 03:25 AM
EyeFlyPlanes is offline
Find More Posts by EyeFlyPlanes
So Cal FPV Aviator
EyeFlyPlanes's Avatar
United States, CA, Santa Clarita
Joined Feb 2008
What ever happened to this antenna? do u have any test videos?
EyeFlyPlanes is offline Find More Posts by EyeFlyPlanes
Old Apr 04, 2010, 09:26 PM
Martin V is offline
Find More Posts by Martin V
Joined Mar 2007
Seems like this would be well suited for close in 360 degree flying or long range low-medium altitude 360 degree flying without needing to move the antenna. The weak areas would be High alt above, and far away with med to high alt.
Sound correct?
Martin V is offline Find More Posts by Martin V
Help! Correct antenna lenth for 900 MHz transmitter? Pepelatz FPV Talk 10 Jun 17, 2009 01:28 AM
Discussion Using antenna splitter for a 900 MHZ rx Avenger GBU-1H FPV Talk 3 Apr 14, 2009 07:47 AM
Discussion HIGH GAIN AMPLIFIER FOR 900 MHz RECEIVERS CATPart FPV Talk 2 May 20, 2008 06:02 PM
Discussion Antenna for 900 video albertocvr FPV Talk 0 Feb 12, 2008 04:06 AM
28" mini zagi you can build for $1.00 mattk17 Parkflyers 6 Feb 15, 2002 09:50 PM
