Espritmodel.com Heli Air
Old Feb 09, 2013, 12:20 AM
Martin - AKA mr.sneezy
PLMS's Avatar
Adelaide, Australia
Joined May 2004
Originally Posted by Rishelman View Post
Just searched some old posts here, think I got a handle on it. Going to put the horns in dry, see how much sticks out. If I need to trim for the correct servo horn/control horn ratio, I will.
Rishelman
http://www.rcgroups.com/forums/showt...6#post23450940
See the image of my rudder. Fitted them fully flush to the other sides skin, which had the gusset just proud of the surface on the right side.
I had to fill the hole in the horn they provided with epoxy and re-drill, as the push rod was loose in the size drilled as it came...
PLMS is offline Find More Posts by PLMS
Old Feb 13, 2013, 10:40 PM
F3K all day
Joined Dec 2011
I re recorded a tutorial about glassing the top sky wing, it turned out much nicer here
Carbon Fiber patch tutorial for model airplane (0 min 0 sec)
What do you think?
jasonafriedman is offline Find More Posts by jasonafriedman
Old Feb 22, 2013, 12:42 AM
Knobbs
Friday Harbor, WA -San Juan Island
Joined Aug 2008
well, I was excited to have my first DLG ready to maiden this Saturday. Doesn't look like that's gonna happen. Went out to the shop to install throwing peg and set CG, last two things I needed to do before test flight and trimming. However, I had yet to bolt the wings on since I epoxied the boom to fuse. Bad news. My tails are crooked in comparison to the wing. Seriously bummed out. I have built a few planes, some from kits, some ARFs, nothing like this has ever happened. I measured and lined that stuff up as many different ways as I could think of before glueing, still managed to screw it up. I was so jazzed too, so happy it had turned out so well (until this, obviously). Everyone kept saying what an easy, straight-forward build this was. I agonized over detail after detail. Sanding the pedastal for the stab just right, fitting the rudder true, setting up the linkage, etc, etc. There are a LOT of variables in the building of this kit. And, although I thought I had gone to enough length to insure those variables were spot on, I am still left with a 9.7oz paperweight, about $350 poorer, and no DLG to fly. Well, not one that will fly straight anyway.
Sorry, had to vent. Maybe next year.
Rishelman
Rishelman is offline Find More Posts by Rishelman
Old Feb 22, 2013, 01:04 AM
F3K all day
Joined Dec 2011
Rishelman
Sorry!! Do you have a picture? Mine is slightly off, but it still flies fine. You can probably still fly it though unless is horrible (like 15 degrees off)
Old Feb 22, 2013, 07:33 AM
Toledo Ohio
Joined Jun 2008
You can shim the wing to line up with the tail feathers . It will fly just fine that way,
ronmad02 is offline Find More Posts by ronmad02
Old Feb 22, 2013, 08:41 AM
Joined Dec 2012
If it is a paperweight, might as well try to fly it and see if you can trim enough for it to be a plane that flies...how about cutting the rudder off, sanding the carbon fiber, cut the elevetar stab thing off and stick it again, or (I don't know if this is possible) use heat to unstick the boom and rotate it...
You aren't seriously thinking of throwing it out, or are you?
barrosinc is offline Find More Posts by barrosinc
Old Feb 22, 2013, 09:40 AM
Knobbs
Joined Aug 2008
Probably won't throw it out. But I'm gonna have to wait to fix it now, too frustrated, and the wind is really out of my sails. Best options are buying new pod and boom and try to cut my foam tails free, but can't afford right now. Or, find some way to hack off the boom and get it back on straight. Any option means a whole lot more screwing around with something that was basically done. And it will always be a hack job, and heavy, from day one. Just gonna have to calm down and think it through.
Old Feb 22, 2013, 10:03 AM
Gasbags & Gussets
jswain's Avatar
Riverside, Ca
Joined Feb 2009
food for thought
... calm down and think it through.
good move to walk away for a bit....
been there, done that, it will work out ok in the long run.
try to figure out where along the boom the problem is -
- is the boom horizontally straight relative the wing span(measure from tail end of boom to each wing tip)
- is the boom rotated CW or CCW so rudder/elev not verticle/horizontal at the back
- is rudder vs. elevator *only* not exactly 90', not a big deal at all..
I busted a boom off at the back of the pod, put the pod into a solid fixture with wings on and wing tips level to table, stuck a 2" long wood plug into boom break area with *very* slow set (45min)epoxy, then adjusted boom left/right horizontally to equal measure of tail-tip relative to each wing tip , next double checked and adjusted the boom tail-tip up/down = level with wing's bottom, and lastly made sure to adjust the elevator to be level to wingspan(if wing on table is level then elevator tips can be made level too by equal measurement of elevator tips from table surface).
Basically made all three axis's on the boom as straight and level and equal to each other as possible.
After epoxy set, finished up by wrapping the wounded area with single layer of thin CF tow (tiny/thin kevlar fishing line/thread is ok too).
js
jswain is offline Find More Posts by jswain
Old Feb 22, 2013, 12:10 PM
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
Its not that difficult to cut off the tail feathers and reattach them. Don't ask me how I know.
davidjensen is offline Find More Posts by davidjensen
Latest blog entry: Scale and Aerotowing
Old Feb 22, 2013, 04:41 PM
ecenshu's Avatar
Australia, NSW, Meadowbank
Joined Nov 2010
A boom twist can be fixed by slowly heating the boom with a hairdryer and then twisting it back. Do it a bit at a time and don't concentrate the heat and it should be good. It will only work when it is twisted in respect of the wing. If your vertical and horizontal are not square you should remove one and redo it.
ecenshu is offline Find More Posts by ecenshu
Old Feb 22, 2013, 08:03 PM
Knobbs
Joined Aug 2008
I built the tails on the boom first, they turned out good as far as I can tell; 90* to each other, incidence of stab seems right, etc. Then I bolted the wing on the fuse, and glued the boom on so I could get the right relationship to wing/tail. The gremlins came while the epoxy was drying and twisted the boom, I guess. If I can literally heat the epoxy joint and twist it back, maybe it's not that big of a deal. I assumed I would have to do some fairly major surgery, which, I am capable of, just not looking forward to or happy about. I am used to getting at least some time on a new plane before that has to happen.
Rishelman
Old Feb 22, 2013, 11:15 PM
PLMS's Avatar
Adelaide, Australia
Joined May 2004
Rishelman
I've reheated epoxy before to do this some sort of thing. It was on the spars of a slope soarer not a boom though. I used a incandescent lamp to warm the joint up to about 80C, and it goes soft again for a while, then it eventually (say a couple of hours) hardens up again even while hot. The resulting heat cured epoxy is as hard as hell...
If the carbon boom does not soften before the epoxy then I think it may work for you during that soft period.
Martin
Old Feb 23, 2013, 01:31 AM
Will fly for food
Bellevue WA,
Joined Dec 2003
I did just this. I heated the boom to pod joint and twisted the joint straight. Some thin CA and it was done
Old Feb 23, 2013, 10:24 AM
Knobbs
Joined Aug 2008
Guess I'll give it a go. Thanks guys.
Rishelman
Old Feb 28, 2013, 12:16 AM
Knobbs
Joined Aug 2008
well Gents, might have pulled it off. On the advise given here, just heated, and twist. Used my industrial heat gun (gotta be really careful-especially with Monocote) and tried to evenly heat the area where fuse and boom come together. I had made a line on the boom to match the seam on the pod. Once it was as warm as I wanted to risk getting it, I slowly applied counter-clockwise pressure. Watching my line the whole time, it didn't seem to budge. So, a little more heat, until the paint on the pod started to bubble JUUUST a LIIITTTLE bit. Again tried to twist. Nothing. Then, I glanced down at my tails...."WHOOOAH!" They were nearly at a 45* angle, like an "X" in relationship to wing. "What the....". Looked back at my line, still perfectly lined up with pod join seam. I could be way off here, but the only way I could figure this would be the case is if the boom itself twisted. Whatever, I just heated it back up and twisted over and over till it was all square. Hopefully it is still structurally sound. If the weather cooperates, I'll find out this weekend.
Thanks for the tip, didn't work the way I thought it would, but oh well, seemed to work.
Rishelman
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
