Old Dec 01, 2012, 09:00 PM
Pez D. Spencer is offline
Find More Posts by Pez D. Spencer
Seattle
Joined Apr 2007
Wow! On Wednesday morning, around 11:00 AM, I ordered 10 D47s from Diamond. So this morning, Saturday, I check my mail and there is a small box from Diamond with not only my 10 servos, but also an eleventh servo that was marked on the invoice seperately as a free servo. So how cool is that. From the east coast to Seattle 72 hours from when I ordered and a free servo to boot. Cool Diamond, Thank you.
Pez D. Spencer is offline Find More Posts by Pez D. Spencer
Old Dec 03, 2012, 11:36 PM
Helitime is offline
Find More Posts by Helitime
Pickering Ontario CANADA
Joined May 2010
Waiting
Waiting for the arm to heal.
Description: Still pretty tender after near 2 weeks. :(
It's been too windy, wet and cold anyway.
Gave me some time to kill. So I decided to do what I could to avoid the dreaded hanger rash. The 2 times I transported it I was afraid it would get broken even though there was nothing much else in the truck. Time to get out the cardboard and hot glue.
Description: The pink styro at the other end was glued in place inside (about 18" from the far end) then that opening was glued closed. Holds the wing in place and the nose of the fuse.Name: SANY0641.jpg
Description: No more worries of hanger rash.Name: SANY0642.jpg
Description: Balances right at the carry handle (hole).Name: SANY0643.jpg
Description: Everthing stays in place through the roll test, the endo test and the shake test. :)  The wing compresses 1.5" of soft foam installed in the far end and clips under a cardboard block at this end. Tail boom is supported and the rudder floats in styro.
Everything goes in through the roof of the little house. (descriptions with pics)
Helitime is offline Find More Posts by Helitime
Old Dec 04, 2012, 04:06 PM
eosglider is offline
Find More Posts by eosglider
Addicted to lift
eosglider's Avatar
United States, FL, Miami
Joined Jul 2010
Attachment 5348538
Attachment 5348559Attachment 5348566Attachment 5348567Attachment 5348568
You're a master cardboardsmith! LOL
And, what the heck happened to your arm?!?!
eosglider is offline Find More Posts by eosglider
Old Dec 04, 2012, 08:22 PM
Helitime is offline
Joined May 2010
Cardboard is good. Keeps most of my birds safe, at home and on the road.
I used to put 5 or 6 planes and 3 heli's in my 2 door Sunfire and go flying. The guy's with capped 1/2 tons couldn't bring as much.
The arm is the result of 20 full on launches in 40 min's by an old innactive guy (newbie) who dosen't know what he's doing.(as noted back a few pages) The pic is after 1.5 weeks, was lots worse right to the top of my arm. Live and learn I guess.
Cardboardsmith/Kerry
(Been called lots worse)
Old Dec 04, 2012, 08:44 PM
ClimaxPilot is offline
Find More Posts by ClimaxPilot
Chesty
ClimaxPilot's Avatar
Reedy Creek, Qld, Australia.
Joined May 2003
Wow that is a serious injury for an RC pilot. Clearly DLG shits all over any discipline, where else could you get an arm like that ! I believe in no pain no gain, had my share of powered, park flyers, heli's, they are now in the RC junkyard and decorating my shed, nothing else is important anymore or ever will be for that matter.
Just need Australia to go silly for DLG now, there doesn't seem to be a very active community down under.
ClimaxPilot is offline Find More Posts by ClimaxPilot
Old Dec 05, 2012, 05:26 PM
Addicted to lift
eosglider's Avatar
Joined Jul 2010
Wow! Must have been due to all the blood rushing to your arm. Thats the only thing I can think of. I have never seen trauma like that caused without an impact of some kind. Incredible.
Old Dec 05, 2012, 06:07 PM
Hanger Rash is offline
Find More Posts by Hanger Rash
Launch low. Fly high ;)
Hanger Rash's Avatar
USA, UT, Alpine
Joined Dec 2010
CG too far forward
My TopSky is nose heave by about 1.5cc. What meathod do you guys recommend to move my CG back by 1.5cc or 15mm?
Hanger Rash is offline Find More Posts by Hanger Rash
Old Dec 05, 2012, 06:22 PM
PLMS is offline
Find More Posts by PLMS
Martin - AKA mr.sneezy
PLMS's Avatar
Joined May 2004
Rudder patch
Some time back I broke the rudder on my TS2 Disser. It actually happened over a few rough landings where I missed catching the wing as it went by during a wind gust.
After considering just buying a new rudder from the local importer I decided I had nothing to loose by a DIY repair first. I'm glad I did as it came out OK.
I used two carbon patches left over from the cloth supplied in the kit, along with thin finishing epoxy form Hobbyking. The patches were wetted then blotted till nearly dry with paper towels, then placed and covered with thin mylar shiny side down (as a release film). I have a zip-loc bag of lead shot that I use as a weight while it cures over night, but I place a layer of sponge foam between the bag and the mylar to even the pressure out better.
Flew the DLG with the repair and it's fine, CoG is still where I had it before so the extra gram or two did not seem to matter.
The bonus is that I doubt the rudder will snap in that spot ever again, and I think they should be reinforced there a bit better from the factory.
Martin
PLMS is offline Find More Posts by PLMS
Old Dec 05, 2012, 08:01 PM
davidjensen is offline
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
Cg your ship at 76 to 78mm and see how you like it. 82 to 84 is way to far back
davidjensen is offline Find More Posts by davidjensen
Old Dec 05, 2012, 08:15 PM
USA, UT, Alpine
Joined Dec 2010
Thanks Dave. I wasn't clear. My CG is at 60mm and I want to know the best way to move it back to 75mm.
I am thinking of just taping a penny on the boom so I can move it around. I won't be using this ship in any contest so I will just play with the CG and see what I learn.
But if I wanted to ever make it permanent, I know I would have to stick some ballast inside the ship somewhere. I am just not sure the best way to do that.
Old Dec 05, 2012, 09:44 PM
Chesty
Joined May 2003
My apologies to Wayne from ALOFT hobbies. He sent me a free replacement servo and I forgot to send him a thank you.
Thanks Wayne, great service
Kerry
Grrr, setup these servos in my Vesus wing last night, bench tested ok, epoxied in, go to fit pushrods, plug in servos to centre and this horrible noise starts coming out of one !!!
Ripped the bastards out and fit D47's, unimpressed considering the apparent failure rate.
Old Dec 05, 2012, 10:19 PM
Helitime is offline
Joined May 2010
Don't know if it's related but when I went to centre mine with a servo tester they all did strange things, jittering and jumping. I wondered if my tester was no good for digital servos so I tested with a receiver and they were fine.
At least until one started jittering with light pressure on the aileron.
Old Dec 06, 2012, 03:10 AM
PLMS is offline
PLMS's Avatar
Joined May 2004
I usually ballast models on the CG point, but that won't help you move the CG rearwards. Can you move you batterys or receiver back ?
I used lead golf club tape (it's very thin) to balance my wings laterally, but I think it would wrap around the boom near the tail easily too for a CG adjustment.
My CG is 76mm from LE incidentally, found by flight testing. 80mm was too far for mine.
Old Dec 06, 2012, 06:35 AM
USA, UT, Alpine
Joined Dec 2010
Thanks PLMS - I don't golf so I never would have known that. I will give it a try.
I should have checked the CG before I permanently installed the battery and servo tray. I usually have the opposite problem of being too tail heavy so I just went ahead and installed them and found out too late.
I am at a place now that I really need to get to know and recognize when the CG is off while flying, so this tape idea will give me a chance to experiment.
Old Dec 06, 2012, 07:12 AM
PLMS is offline
PLMS's Avatar
Joined May 2004
This was my method of dealing with a slim fus and the batteries. They are the small micro-heli cells for an mcpX or a FBL100 heli. The cells are loose but connected together in series to make a 3S 'pack'. This means I can slip them individually between other things like the RX and servos to adjust the CG.
Also, I didn't use a servo tray, I did the 'shoe-goo stick the servo down' method. This gives me more room to fit gear either side of them (like a lipo cell or two).
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 09:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 11:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 05:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 08:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 10:34 PM
