Old Oct 27, 2012, 03:14 PM
Helitime is offline
Find More Posts by Helitime
Pickering Ontario CANADA
Joined May 2010
A quick note about the supplied control tubes for the tail. RE: Nothing sticks to them ie:C/A, epoxy etc.
It has been mentioned that 2mm heat shrink can help but it does not stick to the teflon tube even with CA applied. I confirmed this but found that if I give the teflon a light sanding before adding the CA I cannot get the heat shrink to move. Many are purchasing etched tubes for about $20
Helitime is offline Find More Posts by Helitime
Old Nov 02, 2012, 06:15 PM
thistle2311 is offline
Find More Posts by thistle2311
David Eddy (Dave from CT)
United States, CT, Coventry
Joined Dec 2008
Topsky CG Location
Where are you folks setting your CG on the Topsky? I have my TS2 Disser around 68mm from the leading edge. Wondering if I should push it further back.
Dave in CT
thistle2311 is offline Find More Posts by thistle2311
Old Nov 05, 2012, 08:55 AM
Helitime is offline
Joined May 2010
Dave in CT
Hi Dave
Suggested CofG for my TS1 is 78>84mm, not sure if the Disser wing is the same but it should be close. Can't comment on where I like it as I just finished my build last night
Kerry
Old Nov 07, 2012, 10:11 PM
Helitime is offline
Joined May 2010
Another one ready to fly
After weeks of slow building, my first DLG is ready to test fly. Many thanks to everyone here for the information I needed to complete this build. I can honestly say that without the info in this thread or linked from here I would not have finished with the same bird. I tend to make them strong and sturdy so I would have had a 20 oz DLG
Some details
AUW= 302g or about 10.65 oz
2s 300 mah lipo 17g, can be moved about 1.5" fore and aft (moves CofG from 78>82mm)
10g lead shot and epoxy in the nose
Max flaps is only 30 deg. (my first top drive) The ailerons are faced with bias ply F/G cloth and I have a patch of glass around the ail. horn. I read that top drive tends to cause delamination at the ail. horn and didn't want to go there.
I had mismatched C/F spars on the wings so I used the supplied C/F on top of the wing to try to hide this. I then used a heavier than supplied F/G cloth on the bottom of the wing. Hard points where installed along with the C/F tubes.
Boom was cut 2.5" and slotted for the fin. I could not get the C/F tow to stay in place so I used a 1/4" strip of C/F cloth and "clamped " it with stretch wrap to prevent the slot from growing.
Instructions say 644mm from wing TE to LE of fin, I am only 580mm
Everthing is set up on the TX as per info found here, all throws are per specs.
Some pics
Description: Almost ready.
Description: Ready for hard points.
Description: Hard points installed.
Description: 1 penny for lateral balance. Epoxy added later.
Description: Removeable horz. stab.
Description: Top drive with F/G reinforcement.
Description: Gap seals. Home made, 6ml polyester attached with 3M77 spray adhesive.
Description: Throwing peg.
Description: Completed tail.
Description: "HOWHIGH" installed ahead of the wing saddle.
Description: Sample of the heavier F/G cloth I used along with the supplied C/F.
Top battery is 350mah, 34g and almost fits.
I will use the smaller 300mah at 17g and room to slide.Held in position and adjusted with 2 small blocks of foam.
Old Nov 07, 2012, 11:09 PM
Helitime is offline
Joined May 2010
Topsky CG Location
Dave in CT
Originally Posted by Helitime View Post
Hi Dave
Kerry
I have since read 75>80mm and the HK file lists it at 70>80mm
I need to sort this out before I test fly.
EDIT: Topsoaring web site says 78>84mm
Old Nov 10, 2012, 01:10 PM
flying1 is offline
Find More Posts by flying1
you are not paying attention
christchurch New Zealand
Joined Oct 2008
I have the viper and am settling at around the 79 / 80 point wich is working nicely, too far forward is easy to fly and set up but makes the model poor at indicating lift, too far back and i spend all my time recovering from stalls. It takes quite some time and calm days to get it all set up to your liking.
flying1 is offline Find More Posts by flying1
Old Nov 13, 2012, 06:23 PM
Helitime is offline
Joined May 2010
One of my NEW DSM44 servos has the jitters.
I noticed that when I apply very slight pressure on the aileron the servo jitters like mad.
Don't know if it could be fixed or not but not this one,as I willl have to grind it to dust to get it out.
Kerry
Old Nov 13, 2012, 09:17 PM
Rotozuk is offline
Find More Posts by Rotozuk
Rotozuk's Avatar
United States, CA, Novato
Joined Sep 2003
Kerry
Kerry,
I had one do the same thing to me recently. Shoot me an email and I'll send you a replacement. Sorry for the trouble!!
-Wayne
Rotozuk is offline Find More Posts by Rotozuk
Site Sponsor
Old Nov 14, 2012, 12:31 AM
Helitime is offline
Joined May 2010
Originally Posted by Rotozuk View Post
Kerry,
-Wayne
Email sent. Thanks for the offer but I don't think I will have anything to return
Nice to know your on top of these threads and ready to help though.
Kerry
Old Nov 14, 2012, 03:46 AM
ClimaxPilot is offline
Find More Posts by ClimaxPilot
Chesty
ClimaxPilot's Avatar
Reedy Creek, Qld, Australia.
Joined May 2003
Some details
Is this the Versus from HK ?
EDIT : Sorry, just looked further back to where you started posting and noticed you'd ordered from HK, so it is a Versus.
I'd say that the Versus is actually made by Topsky, they are way to similar
ClimaxPilot is offline Find More Posts by ClimaxPilot
Old Nov 14, 2012, 06:44 AM
Helitime is offline
Joined May 2010
You are correct sir. The Versus is a Topsky"1". Lots of good info here.
Kerry
Old Nov 14, 2012, 09:18 AM
ddruck is offline
Find More Posts by ddruck
ddruck's Avatar
Canada, ON, Pickering
Joined Nov 2006
A guy who has both DLGs side by side offered his comparison here in the Versus thread. HK Versus came up on top, seems they make it a bit better.
http://www.rcgroups.com/forums/showp...&postcount=162
ddruck is offline Find More Posts by ddruck
Old Nov 14, 2012, 01:15 PM
Helitime is offline
Joined May 2010
Wow. Good service from Aloft Hobbies, Wayne is sending me a replacement servo no charge. I didn't even contact him to complain, he saw my post here about the jittering servo and is replacing it.
Thanks Wayne
Kerry
Old Nov 14, 2012, 02:04 PM
Rotozuk is offline
Rotozuk's Avatar
Joined Sep 2003
You got lucky.. I happen to check the Top Sky thread from time to time.
Site Sponsor
Old Nov 18, 2012, 12:41 AM
Helitime is offline
Joined May 2010
Maiden Flight(s)
Finally got a chance to give it a try. This is my first DLG and my first launches.
Started with a couple javelin throws to check trims. After some small adjustments it was time to have a go at discus launches. I started with a couple 3/4 turn stationary throws which were almost vertical and not high enough to register on the "Howhigh". As I was throwing so high, I stopped using the launch preset (up ele.) and finally got a reading 47' Next toss was 62', then 90' The balance of the readings where 83',75' and 90' again.
It would have been very obvious to anyone watching that I didn't know what I was doing. Mixed in with the above "readings" were several vertical "loop" throws as well as one that came out of my hand early while I was thinking about my feet it was near horizontal but straight through the top of some 8' trees. The branches slowed it right down and turned it straight up at about 20' and it just missed the ground pulling full up ele. after the stall.
The wind picked up to about 10 kph so I packed it up as I didn't have a lot of room in a small school yard. Hope to get it out to the club before we freeze over.
In summary
I NEED A LOT OF PRACTICE !!!!
I had a blast!!!!!!!!!
I got sore finger tips.
Kerry
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
