Old Oct 01, 2012, 11:32 PM
Helitime is offline
Find More Posts by Helitime
Pickering Ontario CANADA
Joined May 2010
Jwmflying Thank you, that's what I wanted to hear and what I had in mind.
Hobbyclub This was part of a larger order but I went back, put one in the cart and checked the shipping(7>21days I wasn't in a hurry) Totals up about $200>210 CDN
NZ7C The shipping cost and time makes it unreasonable to return them based on appearance only but thanks for your input.
Another question. The 4 gram servos I purchased for this bird have 0.8 kg/cm torque. Will this be enough?????????
As a comparison the D47's mentioned many times here, have about 1.4kg/cm
Thanks again
Kerry
Helitime is offline Find More Posts by Helitime
Old Oct 02, 2012, 08:23 AM
Jwmflying14 is offline
Find More Posts by Jwmflying14
United States, CA, Lompoc
Joined Nov 2010
No that won't be enough.
D47's are the minimal I would run on ailerons
Jwmflying14 is offline Find More Posts by Jwmflying14
Old Oct 02, 2012, 08:42 AM
eosglider is offline
Find More Posts by eosglider
Addicted to lift
eosglider's Avatar
United States, FL, Miami
Joined Jul 2010
FYI - Used D47's for sale... Great deal.
http://www.rcgroups.com/forums/showt...&highlight=d47
eosglider is offline Find More Posts by eosglider
Old Oct 02, 2012, 09:56 AM
Helitime is offline
Joined May 2010
Thanks but.
He won't ship to Canada.........??????????????
EDIT: Seems some people want a lower "declared" value, so I was not given the opportunity to purchase.
I wanted to say thanks for the straight answer but the thread was closed.
Old Oct 04, 2012, 10:41 AM
Helitime is offline
Joined May 2010
Has anyone used these servos http://www.hobbyking.com/hobbyking/s...hin_Servo.html
Specs are similar to D47's
THX
Kerry
Old Oct 04, 2012, 10:56 AM
Joined Nov 2010
Those ate no where near the same size or specs.
Also I wouldn't trust anything hobbyking on a DLG
Old Oct 04, 2012, 11:09 AM
ddruck is offline
Find More Posts by ddruck
ddruck's Avatar
Canada, ON, Pickering
Joined Nov 2006
Actually these are good servos, metal gear, I bought 10 of them, very strong, I use them directly in the tail of Easy Glider pro on rudder and elevator and will use a pair in my Versus DLG wing I just got from hobby king. These are made by Vigor and sold outside of Hobby King also. I am going to buy more of these. Only downfall are thin and very short servo leads, can't have everything I guess. They are too tall for the fuse also, even if you cut off the 2 knobs on the bottom but perfect for wings.
Dan
THX
Kerry
ddruck is offline Find More Posts by ddruck
Old Oct 04, 2012, 01:21 PM
Helitime is offline
Joined May 2010
Sorry to disagree but specs.(speed + torque) are identical, I didn't mention size but they are close.
The D47's were snapped up before I could explain that I would not dicker with the seller. I don't want to spend $100 plus shipping etc. just for servo's for this bird. It's my first DLG
Re Hobbyking: My DLG is from Hobbyking (it's a Topsky) I am at about $4>5000.worth of HK products and never a problem.
Thanks for your input
DDRUCK Thanks for your input also. I am undecided on these servos as some of the reveiws are not the best.
Kerry
Old Oct 04, 2012, 06:24 PM
Pickle72 is offline
Find More Posts by Pickle72
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
THX
Kerry
Yep good servos. I used them in 2 of my TS ships and no problems.
Especially for a first time DLGer. They will develop a bit of slop (all metal gear servos do) but for the price they can't be beat.
Pickle72 is offline Find More Posts by Pickle72
Old Oct 04, 2012, 11:21 PM
Helitime is offline
Joined May 2010
Thank you, I thought someone here had used them. I will probably put them in the wings
Kerry
Old Oct 10, 2012, 04:10 AM
Rotozuk is offline
Find More Posts by Rotozuk
Rotozuk's Avatar
United States, CA, Novato
Joined Sep 2003
THX
Kerry
They are not near the quality of a D47 or the Power HD DSM44 servos. The HK servo has a huge dead band and poor centering, and should only be used for crude work, and they do not provide the numbers stated.
How about a digital, metal gear servo with a coreless motor for less money than the D47 or the HK servos?
http://www.alofthobbies.com/dsm44.html
These little servos rock in the Topsky and other DLGs.
Did I mention they are in stock, in the USA and we have FAST and affordable shipping on them, including international? If that is not enough, if you are not happy with them for any reason just return them for a refund.
Yeah, we like these servos that much!
-Wayne
Rotozuk is offline Find More Posts by Rotozuk
Site Sponsor
Old Oct 10, 2012, 05:18 AM
dingb is offline
Find More Posts by dingb
born again slope junkie
dingb's Avatar
warrnambool vic australia
Joined Sep 2009
what shipping cost to Australia?? for 4 off
Dave
dingb is offline Find More Posts by dingb
Old Oct 10, 2012, 07:29 AM
Helitime is offline
Joined May 2010
-Wayne
Anyone familiar with these servos??
Old Oct 10, 2012, 09:01 AM
Addicted to lift
eosglider's Avatar
Joined Jul 2010
Not familiar, but they look ok for this application.
See: http://www.rcgroups.com/forums/showthread.php?t=1724663
You can't beat the price on these coreless MG servos, and Wayne from Aloft is very reputable so I would take the gamble. The only small concern I would have is metal gear wear, but you're not bound to see that for quite a while. The plane more than likely will age faster than those gears.
Just my $0.02
Edit: Just compared these specs to my similar sized Blue Arrow D05010MG's I have in my Alula Evo, and these have 3 times more torque!!! Wow!
See: http://www.servodatabase.com/compare?servos=135,2059
Old Oct 10, 2012, 10:13 AM
Rotozuk is offline
Rotozuk's Avatar
Joined Sep 2003
Dave
Shipping to Australia is showing as $5.41, and typically takes about 1 week. So they would work out to about US $10.60 each. (Price is lower when you buy 4 at a time.)
-Wayne
Site Sponsor
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
