Old Jun 20, 2012, 05:30 PM
mikeshellim is offline
Find More Posts by mikeshellim
Joined Dec 2002
Closed loop
Originally Posted by slopetrashuk View Post
Well, like I said - Unlucky. My pushrod is holding up fine but I think the rudder would be better with a kevlar closed loop (pull/pull) system inside the boom.
Just two-and-a-bit years late with the reply Andy, is that a record ?
Just finished my own Topsky 2, it has closed loop on both rudder and elevator - that's proper push-pull (no spring return). Was it worth the effort? Yep, it saves quite a bit of weight and looks nicer, plus the linkage is free from the inevitable stiffness of the supplied tube/wire. But it wasn't easy.
More details and pics in blog post:
http://rc-soar.blogspot.co.uk/2012/0...lg-tested.html
mikeshellim is offline Find More Posts by mikeshellim
Old Jul 01, 2012, 05:15 AM
PLMS is offline
Find More Posts by PLMS
Martin - AKA mr.sneezy
PLMS's Avatar
Joined May 2004
My stock push rods seem to be working well (re above post). However I have found that cleaning the pushrod wires with acetone or degreaser then coating them with graphite powder first before inserting them for the final fit is very beneficial. Generally they have about half the resistance of uncleaned unlubed rods. That has applied to all my models with nylon or plastic pushrod tubes over the years...
PLMS is offline Find More Posts by PLMS
Old Jul 01, 2012, 05:17 AM
PLMS is offline
PLMS's Avatar
Joined May 2004
Distributed cells
I just added an image of my 3S battery setup for completeness in my small build image post from back in April. I used three 300mAh Hobbyking Nano-Tech cells that I also use on a micro Blade MCP X heli. Cells that are past flying the heli still support a not so hungry glider servo system no problem. I have two cells packed either side of the tail servos, and only one in the nose to get the right CoG.
http://www.rcgroups.com/forums/showp...postcount=2598
Old Aug 23, 2012, 07:13 PM
ZeroPitch is offline
Find More Posts by ZeroPitch
What goes up, must come down..
ZeroPitch's Avatar
United States, CA, Mission Viejo
Joined Sep 2011
Any suggestions on repairing the rear wing mount blind nut?
It popped loose with slight damage to the fiberglass, but still have most of the nylon bolt screwed into the nut and the nut is still mostly in the right place....
ZeroPitch is offline Find More Posts by ZeroPitch
Old Aug 24, 2012, 05:33 AM
PLMS is offline
PLMS's Avatar
Joined May 2004
If I read you right the nylon screw is sheared off and the thread still in the fus nut ?
If so I'd first try heating up an old jewellers screw driver tip with a flame and melting it into the sheared thread, undo when cool.
Second resort is drill it out with an under size drill bit and clean the remaining nylon out of the thread with a correct size tap.
Hard to give more advice with no photo to look at, but a loose nut may be re-locked in with thin or medium CA, as CA has a real affinity to be soaked into frayed fibreglass. If you get CA inside the thread use the same tapping idea above...
I've also used expoy in the past, by warming it with a heat gun very sparingly to make it runny enough to soak into the glass and fine gaps. It will go off fast that way too so beware.
Old Aug 28, 2012, 03:07 PM
eosglider is offline
Find More Posts by eosglider
Addicted to lift
eosglider's Avatar
United States, FL, Miami
Joined Jul 2010
Not sure if you guys heard, but Hobby King now carries the TopSky 1.0 renamed "Versus".
http://www.hobbyking.com/hobbyking/s...lider_Kit.html
Nice deal.
eosglider is offline Find More Posts by eosglider
Old Aug 28, 2012, 03:44 PM
Pickle72 is offline
Find More Posts by Pickle72
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
Nice!
So is this still made by TS? Did HK license it? Or is it a blatant rip off?
Pickle72 is offline Find More Posts by Pickle72
Old Aug 28, 2012, 04:23 PM
Addicted to lift
eosglider's Avatar
Joined Jul 2010
Originally Posted by Pickle72 View Post
Nice!
Good question. I'd hope they would have licensed it or worked with TS to ramp up their operation by doing volume buys hence benefiting everyone, but who knows. Good question to ask Anthony Hand (HK CEO).
Old Aug 30, 2012, 12:14 PM
ZeroPitch's Avatar
Joined Sep 2011
The nylon bolt head got chewed off but still had the screw indents. Just the wood came loose, so on a whim I pushed some seriously wet Gorilla glue in the hole, slid the plywood back over the hole and screwed the bolt shaft back on after coating with Vaseline. Should have waited till I had a bolt with a head to get some pressure on the glue... feel stupid now cause the PU glue is gonna foam some more :-(. Hope it works out.
What size is that rear nylon wing bolt? Can't find the spare for the life of me...
Old Aug 30, 2012, 12:53 PM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
Www.alofthobbies.com has those nylon bolts four millimeters
JimNM is offline Find More Posts by JimNM
Old Aug 30, 2012, 03:34 PM
ZeroPitch's Avatar
Joined Sep 2011
Thanks Jim (and Wayne of Aloft!) Ran over and picked up a few... Left over glue was still slightly spongy and the screw compressed some, so think I saved it .
Old Sep 17, 2012, 11:11 AM
nicoyenny is offline
Find More Posts by nicoyenny
globemaster
nicoyenny's Avatar
USA, CA, Cypress
Joined Jun 2008
Finished mine after reading ten times this thread (all of it, phew!)
NICE
Mods I am planning:
- Pushrods, definitely will change them fore "something better" no matter what, they will crinkle and twitch somewhere if there is some backforce from the tail surfaces ...
- Dihedral: 6.3 degrees, feels a bit, juuust a bit touchy, might be be, but a little more dihedral might be ok (?)
- Pilot: Needs to update his launching firmware, in the learning curve so far ...
This glider can be addictive !
nicoyenny is offline Find More Posts by nicoyenny
Old Sep 17, 2012, 01:56 PM
davidjensen is online now
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
There is no know cure for the addiction. You will be throwing for the rest of your life
davidjensen is online now Find More Posts by davidjensen
Old Sep 17, 2012, 02:20 PM
thistle2311 is offline
Find More Posts by thistle2311
David Eddy (Dave from CT)
United States, CT, Coventry
Joined Dec 2008
It's a Sickness~
David J is correct. It is truly a sickness. To fully make clear the nature of the condition, you will be "throwing up" until you die!
Dave in CT
thistle2311 is offline Find More Posts by thistle2311
Old Sep 17, 2012, 04:03 PM
globemaster
nicoyenny's Avatar
USA, CA, Cypress
Joined Jun 2008
... on the PLUS side, my wife cannot argue anymore that flying means no exercise, man I was sweating like a flying pig yesterday throwing and throwing ... and walking to get the glider when I landed on uncharted (> 15 ft from me) land ....
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
