[QUOTE
IMHO, there's no need for lateral balance. In an almost-perfect world, maybe, but not by strapping a chunk of weight to a wingtip. Matching the loading of the 2 panels (Weight/Area) and Moments of Inertia would require a lot more work. The panels would also have to be geometrically close to perfect. No warps. [/QUOTE]There is nothing wrong with trying to be perfect though, is there? (opinion respected)
Jay |
Moments of Inertia might cause slightly odd roll behavior, but I seriously doubt anyone could detect a difference measured in single digit percentage of overall weight (a few grams). Warps can be a problem if bad (mostly causing bad stall behavior), but at least they are fairly static regardless of airspeed and don't generally require constant trim changes. Out of balance wings, in my experience, do. I hate to fiddle with trims once I get them set :-) If your experience says different... hey, more power to you. |
I usually take about 1/2 of the imballance out. I'll add some peal and stick color on the opposite wing tip and sometimes place some strip lead into the gap between the skins at the hinge line. I never add more than 2 to 3 grams.
Latest blog entry: Scale and Aerotowing
OTOH there is no need whatsoever to try to match the moments of inertia of the wings (and tail?? ha ha). Unlike a helicopter main rotor a DLG is rigid, and it will rotate about the CG as a solid body, irrespective of the moments imparted by each of the wings (and tail). Neil. |
Roseville, CA
Joined Apr 2009
Still moving along slowly on my build. Got the wings joined , servos in, etc and moving on to the tails. I have the original balsa with film version. Wondering about putting the film on and hinging. Do I cover then tape? Tape then cover? Just cover and use film as hinge? Any pointers on ironing it on? Will be my first time. Have a covering iron.
Belem:
When I had film-covered tails, I used the covering for the hinge. Assuming you're right-handed, cover the left side of the vertical tal and rudder as if one piece. Then, fold the rudder all the way over to the left, with a piece of thin cardboard separating it from the vertical tail. Cover the right side in one piece, straighten it out, and done! You can cover the two separately, and use Scotch tape as a hinge, on the left side only (again, assuming you're right-handed). Do the horizontal tail the same way. Yours, Greg |
| Thread Tools | |
| I got some Fan Fold what to build thread part II started by emoone!!! | Don Sims | Foamies (Kits) | 188 | Jan 23, 2010 08:28 PM |
| Mountain Models Tantrum Partial Build Thread.. | Tram | Parkflyers | 142 | Apr 03, 2004 10:41 PM |
| My Bobolink Build Thread (very Colibri like) | Jim Poor | Hand Launch | 65 | Dec 10, 2003 04:48 PM |
| Laird Super Solution Build Thread! | boomerace | Parkflyers | 178 | Oct 29, 2003 07:20 PM |
| Switchback re-build thread (or What the $#*& was that!) | Biggles604 | Parkflyers | 17 | Jun 23, 2003 09:34 PM |
