Old Mar 05, 2012, 10:14 AM
stickybeatz is offline
Find More Posts by stickybeatz
stickybeatz's Avatar
USA, AZ, Phoenix
Joined Apr 2010
I got the Topsky 1. Any tips on making the horizontal stab removable?
stickybeatz is offline Find More Posts by stickybeatz
Old Mar 05, 2012, 11:22 AM
davidjensen is offline
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
I'm getting consistant with my launches now. Over the weekend I got 146', 153' and 156'. The TS 2 Supper is holding up well and so far no flutter.
davidjensen is offline Find More Posts by davidjensen
Old Mar 05, 2012, 01:13 PM
glidermang is online now
Find More Posts by glidermang
stickybeatz:
It's not designed for that, part of the easy-for-beginners aspect.
Other people market tail mounts, including ASK (www.RCBuilder.com) and occasionally Oleg (www.olgol.com). They come with the appropriate, nylon bolts and are already threaded. Scuff up the TopSky boom, and they glue right on. You will save weight and reduce drag, for a price of around $25 or so. I recommend either the carbon or stainless steel push rods from ASK as well, as a glueable substitute for the standard issue TopSky push rods.
You can also lay a layer of lite plywood on the TopSky mount, and thread it for what ever bolt you have. Drill the holes, cut the threads, then hit the threads with thin CA. Once it sets, cut the threads a second time. Many do this or something similar.
Yours, Greg
glidermang is online now Find More Posts by glidermang
Old Mar 05, 2012, 01:21 PM
USA, AZ, Phoenix
Joined Apr 2010
Originally Posted by glidermang View Post
stickybeatz:
Yours, Greg
Thanks, Greg!
Old Mar 05, 2012, 05:27 PM
jasonafriedman is offline
Find More Posts by jasonafriedman
F3K all day
Joined Dec 2011
Make sure to post a picture of the removable stab, i would like to see that
jasonafriedman is offline Find More Posts by jasonafriedman
Old Mar 05, 2012, 08:38 PM
Will fly for food
Bellevue WA,
Joined Dec 2003
The stock build has a removable stab.
Old Mar 06, 2012, 12:41 AM
USA, AZ, Phoenix
Joined Apr 2010
Got everything done except for setting up the linkages and the throwing peg. It is probably the ugliest build I have ever done, but hopefully it will fly alright
Old Mar 06, 2012, 08:44 AM
F3K all day
Joined Dec 2011
Nice plane stickybeatz
Old Mar 06, 2012, 08:46 AM
ThomasLee is online now
Find More Posts by ThomasLee
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Wow that was quick!
ThomasLee is online now Find More Posts by ThomasLee
Latest blog entry: Vibe Assembly Instructions
Old Mar 06, 2012, 09:18 AM
Pickle72 is offline
Find More Posts by Pickle72
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
Looks like you have the poor thing in an interrogation room! LOL
Looks good from here.
Matt
Pickle72 is offline Find More Posts by Pickle72
Old Mar 06, 2012, 09:47 AM
silentwarrior is offline
Find More Posts by silentwarrior
silentwarrior's Avatar
USA, AZ, Phoenix
Joined Apr 2010
Looks good there Sticky. When we gonna take it out to get it trimmed?
silentwarrior is offline Find More Posts by silentwarrior
Old Mar 06, 2012, 10:55 AM
USA, AZ, Phoenix
Joined Apr 2010
Thanks guys! I'm gonna set up linkages and the throwing peg tonight. I've gotta take Myles to Karate class on Thursday but I'll probably bring it with me to work and start trimming it out on my lunch break or something. Did you fix your pod yet, Silent? I've got some extra glass and finishing resin if you need it.
Old Mar 06, 2012, 12:02 PM
USA, AZ, Phoenix
Joined Apr 2010
Yea it's repaired, not the way Donnie wanted me to do it but it worked I mixed up some epoxy, put on my plastic glove, and dabbed a little on my fingertip, and rubbed a thin layer on the inside and outside. stiffened it up good with the 1st aplication but put a 2nd layer on just to be on the safe side. Flies nice again Took it out last night for a few out at Coyote Basin, couldnt' find any lift tho. I figured out that the pod coming loose was what was causing my glider to loop and roll in that termal on Sunday. Since it was behind the elevator servo, the rocking of the pod made the push rod move.... note to self, don't try to fly a broken pod'd dlg :P
Old Mar 08, 2012, 06:47 PM
Belem is offline
Find More Posts by Belem
Foam flogger
Roseville, CA
Joined Apr 2009
My TS 1.0 showed up in the mail yesterday. Beautiful, and intimidating as I've not built anything other than a few foam park fliers.
I'm currently reading thru the entire thread, but I'm only on page 75 so far. Few quick questions so I can order some stuff while I continue reading.
Are the D47s still the favorite servo for this build?
Lipo or Nicd? Sizes?
If I go lipo and D47 do I need a voltage regulator?
Current preferred epoxy? And do I need more than one type?
Thanks for any and all help.
Belem is offline Find More Posts by Belem
Old Mar 08, 2012, 07:10 PM
ecenshu is offline
Find More Posts by ecenshu
ecenshu's Avatar
Australia, NSW, Meadowbank
Joined Nov 2010
D47 servos do not need a regulator when running on 2S, however check that your receiver can handle it!
I used Hyperion 240 cells in series as I had some lying around from an Eflite SBach I fly.
Laminating epoxy is the preferred choice, I've used 30 min regular epoxy for a complete dlg in the past but it is quite a lot thicker so it does't soak as nice and isn't as easy to work with compared to laminating epoxy.
ecenshu is offline Find More Posts by ecenshu
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
