Old Jan 29, 2012, 04:41 PM
DBSkyout is offline
Find More Posts by DBSkyout
Will fly for Bourbon
DBSkyout's Avatar
Monroe, Wa
Joined Aug 2005
Did your kit not have the carbon cloth to join the wing?
DBSkyout is offline Find More Posts by DBSkyout
Old Jan 29, 2012, 07:34 PM
davidjensen is offline
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
I used 2 layers of 2 oz glass to cover my center joint on my non disser. I used the carbon on my disser. If done right the carbon works well and there is little weight gained.
davidjensen is offline Find More Posts by davidjensen
Old Jan 29, 2012, 09:21 PM
spotterone is offline
Find More Posts by spotterone
Can you DS it??
spotterone's Avatar
Australia, NSW, Berowra
Joined Aug 2008
There was some carbon in there, but I used it to make sure my throwing peg doesn't rip out. Funnily enough, that stayed put
spotterone is offline Find More Posts by spotterone
Old Jan 30, 2012, 01:08 AM
PLMS is offline
Find More Posts by PLMS
Martin - AKA mr.sneezy
PLMS's Avatar
Joined May 2004
Hmm. Note to self - Use the carbon on the wing join
PLMS is offline Find More Posts by PLMS
Old Jan 30, 2012, 03:48 PM
Sooty100 is offline
Find More Posts by Sooty100
elaporaholic
Sooty100's Avatar
Staffordshire, England
Joined Aug 2004
I have finally got around to starting my rebuild using a new disser wing.
The carbon that came with my wing is only enough to cover one surface of the join. It has not been even been cut on the bias so it seems a bit pointless using it for the join. I have plenty of 68grm glass cloth I can cut on the bias, would this be a better option?
What do you guys think, Paul
Sooty100 is offline Find More Posts by Sooty100
Old Jan 30, 2012, 05:09 PM
Will fly for food
Bellevue WA,
Joined Dec 2003
I have never used carbon on the bias for the center joint. It would be better but much more than needed.
Old Jan 30, 2012, 08:44 PM
ThomasLee is online now
Find More Posts by ThomasLee
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
I'm not a strong thrower, ~50m, used both the carbon on some planes and some 2oz FG on some planes and never had either one fail (yet....)
Bias will make it twice as strong, but I never felt the need to do that yet.
ThomasLee is online now Find More Posts by ThomasLee
Site Sponsor
Latest blog entry: Vibe Assembly Instructions
Old Jan 30, 2012, 10:19 PM
Can you DS it??
spotterone's Avatar
Joined Aug 2008
From memory, I had the same issue. There didn't seem to be enough carbon to cover both sides of the join so I used some fibreglass that I had lying around instead.
Next time, I'll use 2oz top and bottom.
Old Jan 31, 2012, 04:25 PM
Sooty100 is offline
elaporaholic
Sooty100's Avatar
Joined Aug 2004
Thanks guys,
I will go with my glass cloth. Once I have stopped fiddling about with my top drive install.
Old Jan 31, 2012, 06:15 PM
r/cmark is offline
Find More Posts by r/cmark
200 mph club
r/cmark's Avatar
United States, AZ, Fort Mohave
Joined Mar 2005
Topsky Super2 Disser available at Southwest Classic
http://www.rcgroups.com/forums/showthread.php?t=1585352
r/cmark is offline Find More Posts by r/cmark
Old Feb 03, 2012, 12:57 PM
Sooty100 is offline
elaporaholic
Sooty100's Avatar
Joined Aug 2004
I think I have done a better job of my Topdrive this time around after a lot of fiddling about. My wing joint is not so good though, the trailing edge has slipped slightly before the 30 minute expoxy cured
I haven't bandaged them yet and am wondering whether to try seperate the panels and try again.
Old Feb 04, 2012, 06:21 PM
ThermalThief is offline
Find More Posts by ThermalThief
Do it AGAIN! This time BETTER!
ThermalThief's Avatar
WA
Joined Jan 2005
Sooty,
If it was my model I would cut and redo. It would require an unwanted adjustment just to fly straight and if your a right handed launcher even worse.
Great day out with the Disser today.
Last week I added gap tape on the wings which has improved noise on launch.
Removed the tape from the trilerons and added a glued wire to the aileron with etched tube on the trileron side.
At the field I focused on the aileron throws, differential and DR/EXPO settings. This really improved the model for me. It now circles tight and flat where before I was battling a severe nose tuck 1/2 to 2/3 of the way around a thermal turn.
It's getting real good...
ThermalThief is offline Find More Posts by ThermalThief
Old Feb 04, 2012, 06:35 PM
Will fly for food
Bellevue WA,
Joined Dec 2003
Great day in Seattle as well. My disser reached 144' with a 2 to 5 mph wind. The shortened non disser flys great with 3" hacked off the boom. I got a 133' launch with it in lighter winds so the short boom does not affect the launch by much if any. It has a very quiet launch also. Last week in 15+mph winds the disser was fluttering but I could not get it to do so today. Im going to look at my trileron tips and tighten them up some anyway.
Old Feb 04, 2012, 07:29 PM
glidermang is offline
Find More Posts by glidermang
For you guys worried about joining the wing halves, here's a product that works very well for me: fiberglass woven tape from CST (The Composites Store). I have 0.003in.X1.5in.X3 yards. available in various thicknesses, widths and lengths.
www.cstsales.com Look for the banner for Fiberglass Tapes, no less.
Yours, Greg
glidermang is offline Find More Posts by glidermang
Old Feb 17, 2012, 03:41 AM
flying1 is offline
Find More Posts by flying1
you are not paying attention
christchurch New Zealand
Joined Oct 2008
aileron throws in mm
im sure its here somewhere but damed if i can find it, can someone please tell me the aileron throw in mm as degrees are not helping me, thanks.
flying1 is offline Find More Posts by flying1
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
