Old Apr 20, 2011, 10:20 PM
Rotozuk is online now
Find More Posts by Rotozuk
Rotozuk's Avatar
United States, CA, Novato
Joined Sep 2003
Decided to tackle the topdrive
I went with top drive on my build that is in progress. After popping the very slim servos into the wing I was not sure I still wanted to do top drive, this is a skinny wing, and just barely has room for the servo in the wing. Eventually I decided to stick with the top drive as I need the practice before I tackle installing 4 top drives in my Spider 60 sloper.
Install was not that bad. I studied some other's work, most interesting is the new Topsky wing as it is nearly flush on both sides:
http://www.rcgroups.com/forums/showp...6&postcount=12
Anyhow, my pictures are below.
This is a little tricky to get the hole nice and straight through the foam. It takes some thinking to get it all right. If you are lazy, or having issues with other parts of the build, then I suggest you skip this process. Funny thing is this is easier to do on a molded plane. No foam to mess with.
-Wayne
Rotozuk is online now Find More Posts by Rotozuk
Site Sponsor
Old Apr 21, 2011, 11:06 AM
Yablonsky is offline
Find More Posts by Yablonsky
Yablonsky's Avatar
Aliso Viejo, CA
Joined Sep 2009
Been having bad luck with the Dymond D47 servos....I had a minor rough landing the other day and the gears stripped on the left aileron...I pulled the servo apart and replaced the gears and after putting it back together...the motor just kept running..the servo got HOT....so I pulled it back apart and plugged in and just sitting idle, the motor was going at full spead....I think the logic board is shot....so I replaced with another one I had sitting around...luckily.
In the process, I have a new way of replacing my servos...
Since I have the servos mounted and the wires running through the wing and the servo plug cut off and replaced with a Dean's 4 wire plug....I had to figure out a way to replace the servo without having to solder the 4 wire plug...again....
I cut the wires and had some male-female connectors for the servo/battery plugs...I pulled the connectors out and put them on the wires for the wire harness and servo...similar to a new 3-wire brushless motor...with the bullet connectors...but with just the small thin conectors...I then put shrink tube over them to protect from touching each other...and presto...simple connectors and a fully replacable servo...even easier to service now too...I'll post some pics as soon as I can.
Ken
Yablonsky is offline Find More Posts by Yablonsky
Old Apr 21, 2011, 03:27 PM
MrE is offline
MrE
Find More Posts by MrE
MrE
United States, WA, Gig Harbor
Joined Aug 2007
As/if I strip out my D47's Im switching to Hyperion '09's. Im really likeing my Hyperions everywhere Ive used them so far.
MrE is offline Find More Posts by MrE
Old Apr 21, 2011, 03:35 PM
MrE is offline
MrE
MrE
Joined Aug 2007
Im having some trimming issues with my new Viper. Ive only got a few dozen tosses mostly in bumpy windy conditions so its kind of hard to tell things for sure.
However, today I had better conditions. Very lite wind and some mild thermals passing through.
My quandry is Im having trouble settling on a slow speed trim setting - and holding it there. I tend to porpose and stall a lot if I get it too slow. Going faster seems to be no problem.
Im also getting mixed results on CG tests.
In a 45 degree dive, starting from a slow speed, it stays dead on track with zero pull up. There may even be a hint of tuck down. However, when I roll inverted in level flight, it takes a fair amount of 'down' to maintain level flight.
Does that mean my decalage is off?
Im using a slight amount of reflex (2mm or so) on a launch pre-set with a small amount of UP elevator on a momentary switch. The glider launches and immediately climbs out at a good 80 degrees or so and tracks very straight on the up line once I release the switch.
Any tuning tips greatly appreciated
Old Apr 21, 2011, 03:36 PM
MrE is offline
MrE
MrE
Joined Aug 2007
By the way - cruise setting is ailerons level with the center secion of the wing and thermal setting is about 5mm down flaps.
Old Apr 21, 2011, 03:49 PM
glidermang is offline
Find More Posts by glidermang
MrE:
I will offer my opinions, but be aware: they are opinions, and others will differ.
Given the characteristics you describe, I would try a wee bit of weight to the nose, maybe 5 grams (which is a 25 cent piece, by the way). Re-trim, and try the dive test once more. I would expect a small pull up, which is actually (in my opinion, others will differ) better than straight.
For inverted flight, don't expect a purely neutral setting. The wing is not symmetrical, and the down wash over the tail will be (at least a little bit) different. So, it will behave differently when inverted. You can have a bunch of fun while inverted, but the practical flying is right-side-up.
Launch sounds great. If you try the CG more forward, then you will probably have to re-trim the launch.
In other words, I don't think your results are mixed - they are indicators of being pretty close.
Yours, Greg
glidermang is offline Find More Posts by glidermang
Old Apr 21, 2011, 04:11 PM
JONBOYLEMON is offline
Find More Posts by JONBOYLEMON
Full disclosure, not sponsored
JONBOYLEMON's Avatar
United States, UT, American Fork
Joined May 2002
Dumb question.... What servos are on the tail, and do you have ANY play in the linkage.
Sorry if it seems obvious and I dont know your level of DLG experience, but it does not take much to make a DLG not fly right. My TS was a new machine with digitals on the tail...
JONBOYLEMON is offline Find More Posts by JONBOYLEMON
Old Apr 21, 2011, 07:47 PM
MrE is offline
MrE
MrE
Joined Aug 2007
Originally Posted by glidermang View Post
MrE:
Yours, Greg
Thanks Greg! I'll try a bit more nose weight and see what that gives me.
Bingo Jonboylemon! Im using D47's all around running direct off a 2S 320 lipo.
When I first finished the plane, centering was virtually perfect with maybe 1mm of play on the bench. Now after a few dozen tosses over maybe 2 hrs of flight time, Ive got about 2-3mm of play in the elevator and about the same in the rudder. The tail servos are no longer centering very well.
That could easily explain the difficulty Im having setting a good slow trim.
The aileron servos still seem to be doing a good job though.
Dang it! I cant really afford all new digitals right now. Plus, that means I need to add a regulator!
What micro digitals are you guys using? Ive been planning to try the Hyperion DS-09scd.
By the way, Ive got lots of powered plank experience and I spent several years TD and slope flying many eons ago. This is my first hand launch bird ever and my first glider in over 20 years.
Old Apr 21, 2011, 07:58 PM
gopherhunter is offline
Find More Posts by gopherhunter
excelling at mediocrity
gopherhunter's Avatar
Franktown, CO. USA
Joined Mar 2009
MrE,
JR 285 is the gold standard. http://cgi.ebay.com/JR-DS285-Digital...50795426547295
The DS09 is the gold standard for flaperon servos.
John
gopherhunter is offline Find More Posts by gopherhunter
Old Apr 21, 2011, 09:35 PM
MrE is offline
MrE
MrE
Joined Aug 2007
Thats a great price on those JR servos! They are about $8 less than the Hyperions.
Im wondering why the JR's are the gold standard for elev/rudder though? The Hyperions are lighter, smaller, have 50% more torque and have bearings instead of bushings.
Old Apr 21, 2011, 10:26 PM
like.2.fly is offline
Find More Posts by like.2.fly
Mike M.
like.2.fly's Avatar
United States, UT, Eden
Joined Jan 2010
...Im wondering why the JR's are the gold standard for elev/rudder though? The Hyperions are lighter, smaller, have 50% more torque and have bearings instead of bushings.
The Hyperion 09's are too tall to fit in most pods, but are very thin and fit well in wings. Just the opposite for the JR 285's. They are short and fat, so work great in pods but not in wings. We are still waiting for the one magic servo that does both jobs equally well.
like.2.fly is offline Find More Posts by like.2.fly
Old Apr 21, 2011, 11:52 PM
MrE is offline
MrE
MrE
Joined Aug 2007
I hadnt looked at the sizes close enough.
Thanks!
Old Apr 22, 2011, 05:38 PM
MCH27t is offline
Find More Posts by MCH27t
Impatience is a virtue
MCH27t's Avatar
Denver, Colorado
Joined Nov 2008
Finished building the T2S today. I'll give it some maiden tosses tomorrow. Mine is a fairly straight forward build with a few minor mods. Mods include:
- Top drive
- RC Builder stab mount, pushrods, and control horns
Electronics are:
- Airtronics 2.4 5ch Rx w/o case
- DS09s in the wing
- HS 45s under the hood
- Lipo and regulater from RC Builder
My build is probably a bit heavy, but still came in at 9.9 oz
Should be a good day tomorrow
MCH27t is offline Find More Posts by MCH27t
Old Apr 22, 2011, 06:07 PM
Franktown, CO. USA
Joined Mar 2009
The sky is not our limit. It's our playground.
- Top drive
Electronics are:
- DS09s in the wing
Mike nicely done! Next is an easy 3 weeks before joining us at the next contest.
Bring it down (up) to The Ranch and we'll help you get dialed in...
9.9 oz is not a bad weight around here. We usually have some wind.
The Taboo I flew at our last contest is 10.5 oz. I reach for it every time unless there is very little wind.
And an awesome SD10G to boot! All Good! Question for you on that: Is your transmitter subject to the update/recall? This is vitally important for us to know. Disastrous results can be expected (ask me how I know).
We wish you all good with the maiden tomorrow!
John Jonke (and your Mile-High DLG Brothers)
Old Apr 22, 2011, 07:02 PM
MCH27t is offline
MCH27t's Avatar
Denver, Colorado
Joined Nov 2008
Thanks John
My SD 10 is upgraded, updated and good to go. Although the SD10 problems seem to have been fairly limited, I've no desire to bring anyone's plane down
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 07:20 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
