Old Jan 25, 2010, 08:40 PM
bobskinner is offline
Find More Posts by bobskinner
Bazinga!
bobskinner's Avatar
Loveland, CO
Joined Aug 2006
I just checked my 2212-06 and it appears that on the one side a couple of magnets are also showing below the bell similar to your pictures Bombay. I removed the bell and the magnets are glued in pretty solid and the motor spins up fine with a prop attached. Are there any other concerns besides appearance that I should be aware of?
bob
bobskinner is offline Find More Posts by bobskinner
Old Jan 26, 2010, 09:02 AM
sonicj is offline
Find More Posts by sonicj
five by five
sonicj's Avatar
Panama City Bch, FL
Joined Jan 2009
bob
if you are using the motor in a pusher fashion, make sure the magnets still clear the base when you push on the motor and turn. if the magnets clear the wire and the stator, there is very little cause for concern with a few misaligned magnets.
-sj
sonicj is offline Find More Posts by sonicj
Old Jan 26, 2010, 09:53 AM
Bazinga!
bobskinner's Avatar
Loveland, CO
Joined Aug 2006
-sj
That would have been my assumption also, thanks sj.
Old Jan 26, 2010, 10:06 AM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
-sj
I would generally agree, but nonetheless, it is a quality control issue. If those magnets slipped before the glue dried there is a potential for a magnet(s) to be thrown when spinning at 2200 revolutions per volt = 11volts x 2200 = 24,200. If they are thrown you are talking about a potentially dangerous situation.
I am a big fan of rctimer and have purchased many products from them on ebay and off of their website. I am also a fan of their presence here and response via email.
I presented the info so that they are aware and so that others are aware...and you can make your own judgement call from there.
RCTimer rocks!!!
Bombay is offline Find More Posts by Bombay
Old Jan 26, 2010, 10:37 AM
capt is offline
Find More Posts by capt
capt's Avatar
Nevada, USA
Joined Sep 2007
Bombay I looked at my 2212/6's and they look just like the top motor in you pic with the bell nice and snug to the base and no magnets hanging out. The two motors you have circled with the mags hanging, are they the 2826 model? I can see the one is so maybe this is confined to the 2826 version?
I know my 2212/06 motors also have a nice plastic ring with slots that the magnets slide into to hold them in place. This is visible if you pull the bell off the windings and look inside.
capt is offline Find More Posts by capt
Old Jan 26, 2010, 11:03 AM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Capt:
Yes, all three motors shown are the 2826-6. I just received these last Friday.
I included a couple of pics for a comparison of the 2212-6 and the 2826-6 motors. I weighed the two (with x-mount and connectors) and they seem to be the same weight (60grams). The 2826 is slightly longer than the 2212. The 2826-6 seems to provide a little more power based on bench tests...albeit at the expense of amp draw.
Old Jan 26, 2010, 12:10 PM
p51p51 is offline
Find More Posts by p51p51
Arizona
Joined Apr 2009
Product Request
Nina, Hello. Could you stock these items? http://www.helibuy.com/5-pcs-low-vol...arm-p-375.html http://www.helibuy.com/5-pcs-2s6s-li...tor-p-376.html Thank you.
RCGroups members I can't post pics for some reason. Tried everything. Could someone help me and post pics of these two items for Ninas benefit? Thanks
p51p51 is offline Find More Posts by p51p51
Old Jan 26, 2010, 12:34 PM
captaingeek is offline
Find More Posts by captaingeek
master of the universe
captaingeek's Avatar
USA, CA, Novato
Joined Jul 2008
Originally Posted by Bombay View Post
Capt:
thanks for this. i hope i get the twisted one with no magnets coming loose.
also concerned about the ESC quality. I ordered 30A combo as well as a 60A for another project im working on. Will definately run a battery through on the bench before they go in the air. dont want to start any fires.
captaingeek is offline Find More Posts by captaingeek
Old Jan 26, 2010, 01:00 PM
sonny1 is offline
Find More Posts by sonny1
Kool Kats Fly RC!! AMA 30462
sonny1's Avatar
United States, CA, Baywood-Los Osos
Joined Feb 2009
Here you go P51, you have to right click the image then "save as" to your PC then attach them. When you hit
Quick Reply" instead click on "Go Advanced", at the bottom is a tab to "Manage Attachments"; that's how to download to RCG. Have any of you guys with bad motors contacted Nina by email or PM; I have found them very willing to replace defective items, hope they get it straightened out for you. BTW: RCTimer does carry this: http://www.rctimer.com/index.php?app=goods&spec_id=90 . Looks similar to the first pic; haven't found a buzzer yet though.
Sonny
sonny1 is offline Find More Posts by sonny1
Old Jan 26, 2010, 04:31 PM
p51p51 is offline
Arizona
Joined Apr 2009
Thanks Sonny
Yes I tried exactly like you said, again, no work. For some reason I can't click on manage attachments. If anyone would like to try & help please PM me and I'll give you a temp password to me acct., maybe you can figgure it out. (RCG members 1yr or longer with many posts). I have posted several pics so I know how. I don't use quick reply. But the reason I wanted to post the pics was for Ninas benefit. Thanks again Sonny! The reason I wanted the pics is because I am going to make RC Timer my primary source for all my rc needs. The communication that Nina provides is the best of any of the non US vendors. After reading the last couple of posts about replacing a POSSIBLE bad motor, I can see how GREAT the customer service is. I would rate their Customer Service similar to Jeff at Heads Up RC (fastest shipping ever)and Rob over at ADC hobbystore(Best motors and Best customer satisfaction) Basicly no more Hobby City!
Old Jan 26, 2010, 07:19 PM
cptdragn is offline
Find More Posts by cptdragn
If it flys,I can crash it
cptdragn's Avatar
USA, AL, Fairhope
Joined Jul 2007
There are a number of ways to attach a photo to your message but for me, the easiest has been to click on the little paper clip next to the smiley face and browse the photos on your computer, click the one you want and then on the open button. It will place it on the pop up and you hit upload. Thatís pretty much all there is to it.
cptdragn is offline Find More Posts by cptdragn
Old Jan 26, 2010, 07:51 PM
sonny1 is offline
sonny1's Avatar
Joined Feb 2009
I heartily agree with your assessment of Jeff at Heads Up RC; every online vendor could learn the "right way" to do business if they emulated him. The link I posted above is for a lipo monitor that RCTimer sells and looks just like the one pictured. You also might consider posting a question about your problems with attachments here: http://www.rcgroups.com/site-suggest...omplaints-259/ . They should be able to help you there without your giving your password to anyone.
Old Jan 27, 2010, 12:14 PM
p51p51 is offline
Arizona
Joined Apr 2009
I'm back!!
Thanks sonny and cptdragn. Switched to Google Chrome. Everything works Oh and thanks J T G
Old Jan 27, 2010, 03:50 PM
sonny1 is offline
sonny1's Avatar
Joined Feb 2009
Just received my latest order; placed on 1-19-10, received today; that's 8 days from China to my door, pretty good especially considering the free shipping!
Old Jan 27, 2010, 06:48 PM
p51p51 is offline
Arizona
Joined Apr 2009
Order update
Wow you really lucked out! I placed my order the Fri before you (prolly didn't go through till Mon) USPS and HK POST said it left on the 23rd, so maybe tomorrow? Just got motor mounted, and found it was easy to put Rx under canopy. That way I can see the "bind" led
Discussion Do N E Other KIWIS use this forum? SlopeKing Slope 34 Apr 18, 2008 06:29 AM
Video What I used to fly before RC planes robertbick Fuel Plane Talk 12 Mar 23, 2008 02:10 AM
For Sale Extreme Flight Yak 55SP-E (1 NIB & 1 Used) - REDUCED PRICE !!! jatt5abdaa Aircraft - Electric - Airplanes (FS/W) 2 Dec 11, 2006 08:27 AM
What determines a micro? we have 1/64th RC cars? rojoyinc Micro Cars 1 May 18, 2002 10:34 PM
Sept 1, 2002 RC Airshow Fort Worth,TX teamrcpilot Electric Flight Events 0 Jan 29, 2002 11:12 AM
