Old Mar 31, 2011, 01:46 PM
lando211 is offline
Find More Posts by lando211
fly the pants off it!
lando211's Avatar
Joined Jan 2009
I dont care that my hobbywing card doesnt work. I changed the timing and it did not help.
lando211 is offline Find More Posts by lando211
Old Mar 31, 2011, 06:28 PM
tarheal63 is offline
Find More Posts by tarheal63
tarheal63's Avatar
United States, TN, Murfreesboro
Joined Mar 2010
Originally Posted by lando211 View Post
http://www.rctimer.com/index.php?gOo...0&productname=
This is the esc in question. It has a crazy jerking pulse on the motor on start-up. I have checked all joints and even tried all timings. Also tried all the start-up modes and super soft was the most jerky. So I took another rctimer 30amp and it didnt do it. So then tried the 40amp on a different motor and the same problem happened. So it is the ecs for sure. Another issue is it will not link with my hobbywing card?
I too am having the same jerking pulse on the start up, and the shaft gets VERY hot when that happens. They have told me they are sending new bearings as it is kind of noisy too once it does start, but this leads me to suspect that the motor is suspect. I don't have a programming card for the esc, so I will try to work it with the transmitter. My motor is a 2212-6. Did changing the timing fix the pulsing?
tarheal63 is offline Find More Posts by tarheal63
Old Mar 31, 2011, 06:38 PM
lando211 is offline
lando211's Avatar
Joined Jan 2009
no it did not change the jerking. I dont think its the bearings. This is the motor I am using http://www.rctimer.com/index.php?gOo...0&productname=
Old Mar 31, 2011, 07:15 PM
tarheal63's Avatar
Joined Mar 2010
So it sounds like I have a bad motor. I will need a replacment.
Old Mar 31, 2011, 07:35 PM
lando211 is offline
lando211's Avatar
Joined Jan 2009
what ESC are you using?
Old Mar 31, 2011, 08:18 PM
tarheal63's Avatar
Joined Mar 2010
I bought the 2212-6 30A esc combo off of epay. It is my second one, the first was flawless. It has the RC Timer logo on it. Pretty generic. Here is a short video of the behavior I am talking about.
RCTimer 2212-6 Motor problems (0 min 26 sec)
When it is stuttering, it gets too hot to touch. I emailed the company to please send me a new motor. I just got this thing yesterday.
Old Mar 31, 2011, 09:09 PM
rc crashburn is offline
Find More Posts by rc crashburn
SUPERB RC CRASH MASTER
rc crashburn's Avatar
Houston, Texas USA
Joined Aug 2004
nice video
I have no idea as to the best way to trouble-shoot something like that.
I have a BL motor that will not even turn.
Just shimmys & jitters.
Could it be the esc or the motor that is bad?
Nothing gets hot or even smells burned.
Sorry, no camera right now.
Even if the motor free-turns good, then it remains suspect?
Do you guys usually just swap the motor and esc till the faulty component is isolated?
rc crashburn is offline Find More Posts by rc crashburn
Old Mar 31, 2011, 09:22 PM
tarheal63's Avatar
Joined Mar 2010
I tried this one on a different ESC with the same results, this tells me the motor is bad.
Old Apr 01, 2011, 12:44 AM
Wrench66 is offline
Find More Posts by Wrench66
Chino Renegade oh-gee, yo
Wrench66's Avatar
United States, CA, Chino
Joined Feb 2008
By the video, it's not anything more than a connection issue, Tarheel.
IF you want to try and fix it:
Since the motor does the same thing with a different esc, I would resolder the plugs on the 3 motor wires but before that take a multimeter set to continuity and check each of the three motor connectors two by two. Most likely you will find one lead that is dead......either by a bad solder joint (hope!) OR an open wind inside the motor (bad, boo! ) More than likely it's a bad solder joint at the connector....xxfingers crossedxx
Good luck!
--Ray
Wrench66 is offline Find More Posts by Wrench66
Old Apr 01, 2011, 05:34 AM
lando211 is offline
lando211's Avatar
Joined Jan 2009
could be a bad joint Thats what I checked first with mine. Then tried many different ESC then found one that was good for the motor. Crazy, as one other ESC that I had did the same thing, then the last one I tried was perfect. It is crazy.
Nina what do I need to do with the ESC? Thanks!
Old Apr 01, 2011, 02:57 PM
Houston, Texas USA
Joined Aug 2004
My motor was twitching & spinning erratically so in my case I pulled the ESC out as you did and substituted a known good one.
The motor now spins properly.
Hoping that you get your bad motor replaced without too much hassle!
Old Apr 01, 2011, 04:03 PM
tarheal63's Avatar
Joined Mar 2010
They were very quick in responding and they are sending a replacement ASAP. Great service from these guys. I will continue purchasing from them. It is nice to find a responsive vendor off shore. I highly recommend these folks.
Old Apr 01, 2011, 08:16 PM
rctimer is offline
Find More Posts by rctimer
rctimer's Avatar
Hong Kong, Pok Fu Lam
Joined Sep 2009
Dear Sir,
Sorry for bother you.
You have bought the ESC30A on 18/May of 2010, is it right? it is about one year.
Awaiting for your information.
rctimer is offline Find More Posts by rctimer
Site Sponsor
Old Apr 01, 2011, 09:13 PM
lando211 is offline
lando211's Avatar
Joined Jan 2009
no, I just got the 40 amp ESC. order number 20110308180027 Thanks! email lando211@yahoo.com
Old Apr 04, 2011, 06:43 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi Nina/Frank,
I put in another order yesterday. Please confirm that the missing UBEC that I paid for and did not come in my previous order of February 12, 2011 #20110212230016 will be added to this order April 3, 2011 #20110403150026.
Thanks and Cheers,
Jim
Vote for my Bro Joe here: Quadrocopter and Tricopter Mega Link Index
Originally Posted by rctimer View Post
Dear jesolins,
Sorry for any inconvenience.
We may arrange resend ASAP, or arrange resend with your next order.
Plesae send the enquiry to our webmail.
And deeply appreciate for your understanding.
Frank
jesolins is offline Find More Posts by jesolins
Discussion Do N E Other KIWIS use this forum? SlopeKing Slope 34 Apr 18, 2008 06:29 AM
Video What I used to fly before RC planes robertbick Fuel Plane Talk 12 Mar 23, 2008 02:10 AM
For Sale Extreme Flight Yak 55SP-E (1 NIB & 1 Used) - REDUCED PRICE !!! jatt5abdaa Aircraft - Electric - Airplanes (FS/W) 2 Dec 11, 2006 08:27 AM
What determines a micro? we have 1/64th RC cars? rojoyinc Micro Cars 1 May 18, 2002 10:34 PM
Sept 1, 2002 RC Airshow Fort Worth,TX teamrcpilot Electric Flight Events 0 Jan 29, 2002 11:12 AM
