Old Oct 03, 2009, 09:57 PM
DeeLuxx is offline
Find More Posts by DeeLuxx
Joined Oct 2009
Help!
JBA .61 does not throttle nicely
Hi there.
Im fiarly new to nitro engines (i have a nitro rc car and thats it) and even newwer to nitro flight.
the other day i went i bought a tidy second hand trainer and a JBA .61 to go with it.
i broke the engine in and everything and it seems to be running fine except that when the throttle is opened quickly then engine dies instantly which is a problem in the air... the engine can also have a temperamental idle and will will sometimes drop off when idling and has a very bad pick up if it has been idling for more than 10 seconds.
Im using a os A3/#6 (hot) glow plug and 15% nitro fuel.
Any help would be greatly appreciated
DeeLuxx is offline Find More Posts by DeeLuxx
Old Oct 03, 2009, 10:03 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Does it lean out and die or load up (rich) and sputter to a stop?
There is a little idle adjustment screw on the side opposite the needle. (in the centre of the throttle arm)
If it is leaning out then open it a tiny bit. If it is going rich then close it a tiny bit. About 1/8 of a turn at a time.
Test and repeat.
Also make sure you are not just trying for too low an idle.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Oct 03, 2009, 10:13 PM
DeeLuxx is offline
Joined Oct 2009
Im guessing it loads up because i had the leaning out problem before.
but in both cases it doesnt even get to full throttle before dying, it just sputters and stops as soon as the throttle is opened quickly
Old Oct 03, 2009, 10:16 PM
pmackenzie's Avatar
Joined Dec 2002
If it "sputters" then it sounds like it is rich, so try turning in the low speed needle.
Pat MacKenzie
Old Oct 03, 2009, 10:57 PM
turk1 is offline
Find More Posts by turk1
turk1's Avatar
Istanbul, Turkey
Joined Aug 2004
Also try to make very little movement during adjustment every time.
turk1 is offline Find More Posts by turk1
Old Oct 03, 2009, 10:58 PM
NZ_Nitro is offline
Find More Posts by NZ_Nitro
New Zealand, Waikato, Hamilton
Joined Aug 2005
I think you should use an OS #8 in this engine, here is my take on this
this could be due to the idle being too rich, you are basically putting out the glow plug by flooding it
another sign of being too rich
rich again however this is also a sign your tank is too high in relation to your carb REMEMBER CENTRE OF TANK TO CENTRE OF CARB IMO ok how to fix it, read the stick on engine tuning then try the following
NZ_Nitro is offline Find More Posts by NZ_Nitro
Reply With Quote  (Disabled)
Old Oct 03, 2009, 11:07 PM
NZ_Nitro is offline
Joined Aug 2005
1 increase the idle rpm until it will stay idling, pinch the tube going to the carb and watch what the engine does, if it improves and speeds up then yes its rich, if it just dies then it was lean, now this just proves what is going on next do this.... open the throttle fully and listen to your engine, if it sounds like a two stroke then slowly increase the main needle until it sounds like a 4 stroke, then slowly turn in the main until it just starts breaking into a clean two stroke sound then back out a fraction from here 2 drop back to an idle and sit for a few seconds
Old Oct 03, 2009, 11:24 PM
NZ_Nitro is offline
Joined Aug 2005
Now as the guys have said above turn in your idle just a little and then try opening the throttle, if it dies move the idle in just a little more and try again you should end up with it having a clean transition from idle to full if the idle is too lean you will see the motor hesitate then speed up to full throttle
Old Oct 03, 2009, 11:27 PM
NZ_Nitro is offline
Joined Aug 2005
NOW LAST THING if you have moved all your settings way off the standard spec see if anyone has a manual
Old Oct 03, 2009, 11:35 PM
NZ_Nitro is offline
Joined Aug 2005
SK seem to be the same as JBA look at page 3 rh side at the top idle starting is 1.5 turns out so it seems
Old Oct 04, 2009, 01:59 AM
DeeLuxx is offline
Joined Oct 2009
Hey thanks for all the useful information!
i did as suggested with the low speed needle and pinched the fuel line to see what would happen. as you'd expect the engine revved higher then eventually stopped.
i turned the needle in and repeated the process until it would just die off nicely and by this time there was a nice smooth transition from idle to full throttle.
i had to turn the low speed needle in quite alot to get this (2-3 turns) which is a bit weird considering it said on the manual that the low speed needle is factory set.
anyway it all works fine now and thanks again for the help!
XJet is offline
Find More Posts by XJet
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
Welcome to the world of cheap Chinese engines ;-)
XJet is offline Find More Posts by XJet
Old Oct 04, 2009, 02:36 AM
DeeLuxx is offline
Joined Oct 2009
haha yea i guess you get what you pay for.
but i have to admit seeing as i payed only $85 for it, it runs really well
Old Oct 04, 2009, 07:38 AM
Ed Cregger is offline
Find More Posts by Ed Cregger
United States, GA, Ringgold
Joined Oct 2005
Opening the throttle quickly is part of the problem.
Go to a real airport, watch the planes taxiing around. Notice that no one is quickly jamming the throttle to full at any time. Modeling tries to emulate full scale, or used to, practices and has not pursued the use of accelerator pumps in their carbs. You would need an accelerator pump in order to get away with jamming the throttle instantaneously to full without the engine bogging or quitting. Cars have them - but model airplane engines do not. Instead, smooth and easy throttle advance is the norm in modeling. This type of operator behavior has been incorporated into model engines for so long that no one remembers it, except old fuddy-duddies like me.
An engine that will not instantaneously respond to throttle is not considered defective by many manufacturers since that isn't part of the model airplane culture any way.
Now, there are engines that do respond well to quick throttle movements. YS is one that comes to mind, so it is possible to attain. But first you have to realize your engine's ranking in the pecking order of model engines. It is a cheap engine. Cheap engines sometimes have good throttling ability, but most of the time they are just passable.
Then figure in that the engine is brand new (I'm assuming). Engines need break-in time before low speed adjustments can even be considered worthwhile doing. How much running time do you have on the engine in total?
I can tell you right now that 15% nitro with a hot glow plug in a Chinese engine (high compression) is just begging for trouble. You are advancing the glow engine's ignition timing a terrific amount by using either one of these ingredients. Using both at once is really asking for it.
The last factor in the equation is prop size. What are you running for a prop? Very important. Especially with the fuel and glow plug that you are using.
Ed Cregger
Ed Cregger is offline Find More Posts by Ed Cregger
Old Oct 04, 2009, 05:35 PM
XJet is offline
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
BZZZT... wrong answer Ed :-)
Sorry but anyone who flies 3D will tell you that very rapid throttle movements are a part of normal flight.
What's more, a *good* engine can handle these rapid transitions without any problems at all. No carby pump is required -- a good engine will respond instantly to rapid opening of the throttle without hesitation.
The fact that a few manufacturers can do this (OS, TT, Webra, etc) means that it *can* be done -- it's just that the others either can't be bothered investing the time/money to develop a product capable of it or don't have the expertise to do so.
Hmmm... only if you spend your day flying circles ;-)
Sorry but 3D flying is becoming *very* popular these days and is invading the mainstream model-flying culture rather aggressively, just look at all the 3D models you can buy now.
Correct!
Correct again!
See, we can agree on *some* things
Help! ESC does not rememebr throttle range ??!! khaled_abobakr Power Systems 8 Dec 27, 2008 04:01 PM
Discussion Honeybee King 2 Help: Motor Does Not Respond to Throttle Phanixis Micro Helis 4 Dec 22, 2008 01:15 AM
Help! Phoenix 35 does not go full throttle iflytailies Castle Creations 7 Aug 20, 2007 08:36 AM
Help! Help! New Lama 2 does not throttle up jags Coaxial Helicopters 5 Nov 30, 2005 06:00 PM
Rave Even when throttle is high, X.R.B does not fly very high. kenhiraihnl Coaxial Helicopters 1 May 01, 2005 09:31 AM
