Go Back   RC Groups > Aircraft - Exotic and Special Interest > Free Flight
Old Nov 04, 2009, 11:20 AM   #31
I had some time this early am, so I pre-shrunk the Esaki white and the green tissue and began covering. I was able to finish the fuselage and hope to resume tomorrow. I applied the tissue with 50/50 water/Elmers and sprayed with alcohol to tighten the paper. Since the fuselage has major curves, I covered in sections to prevent wrinkles. I will apply 2 coats of clear dope.
scigs30 is offline Find More Posts by scigs30   Reply With Quote
Old Nov 04, 2009, 11:43 AM   #32
Inventor&Genius Extraordinary
tune by tito's Avatar
Very, very Nice job you are doing Scigs30
Best Regards Tito
tune by tito is offline Find More Posts by tune by tito   Reply With Quote
Old Nov 04, 2009, 12:58 PM   #33
Hi Scigs
Your usual high standard. Is this an OOB build or subbed wood? Really good stuff.
Mooney is offline Find More Posts by Mooney   Reply With Quote
Old Nov 04, 2009, 01:25 PM   #34
It is an OOP kit so I subbed the wood. Even when I was younger and built these kits, I did not like the print wood. I don't like the ink showing thought the covering. So I would xerox the parts sheet and sand the ink off the sheet. Then I would glue the xerox copy onto the wood and cut out my parts. This also helped prevent the parts from breaking during the cutting out process.
Old Nov 05, 2009, 09:16 PM   #35
Everything is covered and doped. I printed out the decals tonight and next week put this thing together.
Old Nov 10, 2009, 02:47 PM   #36
Congratulations by your wonderful building, master class !
Regards
stg61abc is online now Find More Posts by stg61abc   Reply With Quote
Old Nov 12, 2009, 12:15 AM   #37
I was off today so I was able to finish the P-40. Final weight is 18 grams. The wheels you see in the picture are the original Comet wheels, I will be using Peck Polymers wheels for flight. Not much time spent on details just want to get this done. I made my own decals. Comet kits are great planes.
Old Nov 12, 2009, 01:34 PM   #38
Well took off this am to fly my P-40, flew right off the building board, no trimming what so ever, no weight or down thrust. Used 3/16 rubber and off she went. I can easily see this plane flying away if not careful.
Coming in for a landing.
Old Nov 12, 2009, 03:56 PM   #39
looks great in the air, how many turns did you wind?
zuggerat is offline Find More Posts by zuggerat   Reply With Quote
Old Nov 12, 2009, 04:07 PM   #40
Sorry, didn't count the turns.
Old Nov 12, 2009, 07:29 PM   #41
Excellent job scigs! I need to take detailing lessons from you. As well as learning how to apply the wing fairings and making a propeller assembly like that. You would get all the extra points for looks if you ever compete.
Kev
kevin matthews is offline Find More Posts by kevin matthews   Reply With Quote
Old Nov 13, 2009, 11:15 AM   #42
Scigs, please explain the "trim tab" on the left wing. It looks like it's fixed at 90 degrees; for turn adjustments? Your Dauntless had the same think, I think.
howell
gwinhh is offline Find More Posts by gwinhh   Reply With Quote
Old Nov 13, 2009, 11:49 AM   #43
The trim tab from what I understand was used initially for indoor flying to control the turns so the plane would not fly into the walls. Now there are many theories and beliefs as to which way a plane should fly outdoors, right or left circles. I am no expert but I tend to just keep doing what works best for me. I have never had any issues with flying to the left so I will continue to do so. Trust me, I am not smart enough to invent the little turn tab. This came from the old guys at Scale Staffel back in the day, Walt Mooney, Bill Hannan and others. I like the plane turning in left circles as it climbs into the sky, probably because that is what I was taught. I am sorry, but I wish I had a better answer.
Old Nov 13, 2009, 05:18 PM   #44
I don't CARE about theories, beliefs, aerodynamics, etc. I just want my planes to fly. You learned from the masters, that's for sure. I'll try it on mine; I would guess the size governs the tightness of the circle. And the turning effect depends on speed, I would think.
thanks
howell
Old Nov 13, 2009, 06:55 PM   #45
SSP#14 aspirant
Soar_dude's Avatar
Man I wish mine would come out as nice looking as yours! My Nesmith Couger flies well but it looks like a wrinkled mess next to your results!
Soar_dude is offline Find More Posts by Soar_dude   Reply With Quote
Hanger 9 P-40 build problem R/CReef Fuel Warbirds 3 Aug 29, 2005 07:24 PM
LEG P-40 Build Questions Keith R. Slope 3 Aug 21, 2005 03:28 AM
L.E.G. 48" P-40 Build jdcook54 Slope 186 May 30, 2005 12:36 PM
Hobbico P-40 Build question Tommy D Indoor and Micro Models 2 Feb 28, 2005 10:43 PM
FanFold P-40 Build J Morgan Foamies (Kits) 72 Sep 07, 2004 11:08 PM
Bored? Want to fight?
Join the RCGroups clan!
