Go Back   RC Groups > Aircraft - Exotic and Special Interest > Free Flight
Old Oct 08, 2009, 01:05 AM   #16
Had some more spare time tonight to work on my airplane. I added 1/32 sheet where the bond paper was supposed to go and used soft 1/16 wood for the nose. The wood does not add much weight, the fuselage now weighs 4.2 grams. This would be a great flyer right out of the box. Still have to add the exhaust and nose block and build the wing and tail surfaces and off to covering.
scigs30 is offline Find More Posts by scigs30   Reply With Quote
Old Oct 08, 2009, 01:18 AM   #17
races cars,crashes planes
racedouge1's Avatar
A picture is worth a thousand words, you've got skills
douge
racedouge1 is offline Find More Posts by racedouge1   Reply With Quote
Old Oct 08, 2009, 02:31 AM   #18
You almost have to cover the way you do, scigs, with the way the sides are constructed. The nose looks great with all the planking, a good place to add clay if needed.
Kev
kevin matthews is offline Find More Posts by kevin matthews   Reply With Quote
Old Oct 08, 2009, 05:13 PM   #19
The fuselage is done minus some fine sanding up in the nose area and scalping of some of the formers. The final weight is just over 6 grams.
Old Oct 08, 2009, 05:33 PM   #20
Inventor&Genius Extraordinary
tune by tito's Avatar
Nice Work you have done, Amazing.
Best regards Tito
tune by tito is offline Find More Posts by tune by tito   Reply With Quote
Old Oct 08, 2009, 06:30 PM   #21
It looks real clean.
Old Oct 08, 2009, 07:12 PM   #22
That would be the Elmers glue.
Old Oct 09, 2009, 12:53 AM   #23
hklam's Avatar
Scigs30,
Excellent work and weight too for the P40. How did you do the balsa cone spinner? care to elaborate?
I am currently still working on my P51 peanut scale, and currently stuck at the nose spinner section.
hklam
hklam is offline Find More Posts by hklam   Reply With Quote
Old Oct 09, 2009, 01:19 AM   #24
Believe it or not, I have not carved my own spinner since I was about 14. I just start with a soft square block, carve to rough shape with my X-Acto knife. Then I sand with my sanding block until it is the right shape.
Old Oct 09, 2009, 10:22 AM   #25
Trying To Takeoff
salat's Avatar
Send a message via ICQ to salat Send a message via MSN to salat Send a message via Yahoo to salat
here plan and templates of this plane on my site in case someone iterested:
http://academodel.ru/plans/comet/P-4...er%20Shark.pdf
scigs30, what wood you used for fuselage? I'm building WestWings Spitfire of about same size, but wood seems bit heavy, it is over 5g already and that without any planking..
Kostya
salat is offline Find More Posts by salat   Reply With Quote
Old Oct 09, 2009, 12:32 PM   #26
I use C grain 4-6lb from Easy Built for the formers and keels, great stuff. For the 1/16sq. I use Midwest balsa.
Old Oct 09, 2009, 12:49 PM   #27
I start with a soft square block, locate the center on the back end, carve to rough shape, screw a mandrel for my Dremel tool into the center, chuck it up in the Dremel, and using a sanding block refine the shape of the spinner with the tool turning at moderate speed. The whole process takes a few minutes. Then all you have to do is hollow out the spinner. Sometimes I glue a circle of 1/64" plywood on the back of the spinner if the balsa is particularly soft.
kittyfritters is offline Find More Posts by kittyfritters   Reply With Quote
Old Oct 09, 2009, 01:40 PM   #28
I'm glad you told what kind of wood you use for formers and keels scigs. My small Hellcat, 16 1/2" wing-span keels and formers are made from A/B grain 4 to 6 lbs. It flys, I don't know how long it will keep it's shape, it seems strong enough to last.
Old Oct 19, 2009, 12:10 AM   #29
Comet P-40
That old Comet kit brings back memories. I bought one for 25 cents when in the 7th grade ,took it to school set on the window ledge and stared at it all day. I did not try flying it just to look at. 20 years ago I bought another Comet P-40 it still sets in it's rightfull place on the bookshelve. Will try to post a picture if I can. Logair
  • Name: DSCF0814.jpg
logair8452 is offline Find More Posts by logair8452   Reply With Quote
Old Oct 21, 2009, 05:15 PM   #30
Logair, You P40 looks great. Thanks for sharing.
Well today I finished with all the building, just have to order some green Esaki tissue. The weight is just over 14 grams as shown. The Guillows P40 next to it is 27 grams and it does fly. The landing gear will be permanent and not as shown in the pictures, that is why it is a little crooked.
Hanger 9 P-40 build problem R/CReef Fuel Warbirds 3 Aug 29, 2005 07:24 PM
LEG P-40 Build Questions Keith R. Slope 3 Aug 21, 2005 03:28 AM
L.E.G. 48" P-40 Build jdcook54 Slope 186 May 30, 2005 12:36 PM
Hobbico P-40 Build question Tommy D Indoor and Micro Models 2 Feb 28, 2005 10:43 PM
FanFold P-40 Build J Morgan Foamies (Kits) 72 Sep 07, 2004 11:08 PM
Bored? Want to fight?
Join the RCGroups clan!
